Samsung LA40F81BDX problem
  • Begbie
    • Oct 2013
    • 16
    Ive got a curious one here. I have a LA40F81BDX it was a great TV until it has suddenly developed a screen problem. I have checked the PS for the regular problems (bad caps) but to no avail, I have also changed out the T-Con board and had no luck. It appears everything is working fine (sound, etc) and on pressing the menu button the screen does change to a different image.
    I just need to know what else to try or if I am wasting my time. Thanks!
    • 31294
    Re: Samsung LA40F81BDX problem
    could be a bad vram.
    if it's bga your in trouble, but if it's tsop you may find a compatable chip on a scrap board to swap over.
    could be something else too - but ram is the most unreliable type of chips.
      So it shows just lines on the screen and no image on the back ground?
      How many ribbon cables it has between the T-CON and the LCD panel? I would try having one ribbon cable connected one at a time to see what you get on the screen.
      • Begbie
        • Oct 2013
        • 16
        IT definitely has two. I will try this and let you know.
          Not vram IMHO as image is not perfectly even (image slightly fades.)
          Probably panel defect.
          • Begbie
            • Oct 2013
            • 16
            OK there is four ribbon cables between the TCon and the panel. On removing them each in turn I get very similar results to the existing problem although the vertical patterns are slightly different and in one instance the half the panel is all white.
              I agree with Tom.
              • Begbie
                • Oct 2013
                • 16
                Thanks guys
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
                • THXFX
                  samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                  by THXFX
                  Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                  I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                  When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                  What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                  I check capacitors and diodes and didn't find any short IN MAINBOARD.
                  Measured all power supply...
                  03-20-2024, 03:21 AM
                • mmccomputer
                  problem with replacing lcd screen
                  by mmccomputer
                  I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                  otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                  If anyone has any information on the subject...
                  12-15-2024, 03:44 PM
                • Chrissygizmo
                  samsung galaxy ao2s very temperamental after screen replaced
                  by Chrissygizmo
                  Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                  Ive eventually managed to get it on and working but it's very temperamental...
                  The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                  05-26-2024, 12:05 AM
                • jimjoe123
                  LCD TV Green/Pink screen problem
                  by jimjoe123
                  I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                  Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                  Then each time...
                  02-23-2020, 01:29 AM
