Hi... If i understand the french posts, i think the problem will happen again (unplugging a tv from wall never repaired a tv set, guaranteed!).. but if the set is 6 months old, i don't know why not to invoke the warranty!
Hisense stuck in Colors cycle like test pattern.
This topic has been answered.
yes its now out from service menu after it sitting long time out of wall so its complete discharge.... don't worry it will not happen again unless if you play with service menu... so keep it.Bonjour.
Bonnes nouvelles. J ai laissé le téléviseur débranché toute une nuit. Et ce matin la Tv a redémarrée normalement. Je suis retournée dans le menu service et tout était OK. Du coup Je pense que je n avais pas modifier les paramètre mais que la Tv a buggé. En 6 mois de service, je n avais jamais rencontré de probléme avec ma Tv.
Encore merci. Bonne journée.
to some one don't know Hisense if its with out Wall connected over 5 hours will reset and back to last state when it was working... and this the service center will advised in first place .Comment
by ProttHello fellow Badcappers,
I have a Surface Pro 7 that's turning on (CPU heating up, USB powered, LCD powered) stuck on a boot logo. BIOS should be correct (ME cleaned, worked in a different S7Pro), no shorts. Only thing that seems a bit weird is the pattern in which the SSD chip is heating up. Is that normal behaviour? Rest of the SSD is 10 degrees colder.
I have replacement SSDs, but it's quite a hassle to reball and install them, so I would like to avoid doing this step if possible.
Thank you!1 Photo -
by StuntHi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
screen that's it and stuck there. I left it until the following day and i still...09-02-2025, 01:51 PM -
by thesameThe tv is stuck in service mode, i have unpluged it for several times, tryed to power it separate from remote , tryed some reset method using menu button and 4725 typed twice in a row to enter or disable the service mode but it didn't work. The board has no damaged components, could it need a fresh firmware or the emmc could be dead?...
by toty79Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
As per Hisense tv title LTDN50K220WSEU stuck in standby
PSU rsag.820.5687 HLL 4855WF
Main rsag 7.820.5842
I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages... -
by ojmcBackground:
- Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
- I replaced all 6 of the backlight LED strips with these replacements: amazon
- The TV worked again perfectly for ~2 weeks.
- After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
- Loading...
