Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
LG 42LN540V LED Backlight Flickering After Replacement When Connecting The Screen
  • RetroComputingGrotto
    • Aug 2023
    • 108
    Originally posted by Davi.p
    Can you explain a bit? have you fractured the panel?
    My hand shook when attempting to reflow the driver IC and a couple of solder balls appeared to the side of the IC so I killed it - all adding to experience as like I say, these small BGA chips were not around on the TVs I repaired 25+ years ago at College.
    At the end of the day for £24 I got two days of experience and knowledge of how a modern day TV works compared to the old CRT ones and the comments from all you guys in invaluable to me - much better than any expensive training course. I've kept what I can for spares and labelled the board and LEDs up with the make/model of TV they came from.
    I've got a load of MIDI keyboards and wall mounted speakers to repair for our Music department to keep me busy now!
    • EazyBone
      • Jun 2023
      • 1390
      • United states
      Well here's the first confirmed case.
      Rip tv
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4647
        • Italy - Milan
        You made a big mistake, i never suggested you a reflow and especially i told you driver ic, not processor, i mean backlight driver ic, it is on the power board.. you could have asked info..
          • Aug 2023
          • 108
          The TV was replaced 2-3 weeks ago so this was purely a learning/training exercise - even if it had been successfully repaired, there is currently no use for this TV and £24 for a couple of days self learning/training a 12 year old TV worth bugger all is a bargain as any kind of training course would cost more than double that per hour!
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4647
            • Italy - Milan
            If you reflow random, which type of training is?
              • Aug 2023
              • 108
              #26
              Reflow training.
              How do you get experience of reflowing ICs when you have no ICs to reflow - the answer is to reflow things and learn from it. Just like soldering, how do you practive soldering, you solder things. How do you learn to drive a car, you drive an actual car. How do you learn to play a piano, you practice on a piano no matter how badly someone like yourself tells you you're rubbish and need to play better - how can you play better without playing badly to begin with and practice to make perfect?
              How would you suggest I learn to reflow IC's - watch youtube vidoes of someone else doing it? That's not gaining any experience at all, just knowledge. Ive seen people do it countless time but without actually doing on on worthless items that are destined for eWaste/WEEE how else will I gain experience? You may have a bespoke Electronics Servicing Virtual Reality headset with a virtual soldering iron and hot air reflow workstation (I assume that's how you've gained your vast knowledge and experience, as that's the only alternative I can think of rather than actucal PCBs) but I don't have the luxury of such a VR system so I will stick to gaining knowledge and experience by using physical PCBs.
              You wont like this, but some people buy faulty TVs like the one I had (and other such items like mobile phones and iPads) from eBay so they can practice randomly reflowing and soldering/desoldering different components to gain experience in doing it so when it comes to doing it for real they have some idea of what to do and what not to do.
              • Ado02
                Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                by Ado02
                We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the Intel® Iris® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                12-16-2024, 02:33 PM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
              • survivalbloke
                HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
                by survivalbloke
                SN: 8CG0213H8W
                ProdID 3C311UA
                This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
                05-08-2025, 12:21 PM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
