lg42ld450 no picture / startup fault
  • daphney
    • Feb 2014
    • 93
    i have the above tv & it has sound ok but when turn on i get as seen in pics & rightside gets dimmer until almost same as left this takes 20secs maybe was working fine til came in & was like this it turns on & off fine but i dont see lg lifes good screen & cant access menu cant see any burnt or bubbled caps.
    any ideas where to start looking?
    thnx as always for the help
    Re: lg42ld450 no picture / startup fault
    I would say there's a good chance you have a bad LCD panel there. Maybe you have a tab bond issue. You can try unplugging one of the two ribbon cables going into the panel from the T-con board. If you get half a picture that pretty much confirms shorted bad panel.
    • daphney
      • Feb 2014
      • 93
      i have unplugged ribbon on side that stays black & other side works fine so panel is dead then & no repair possible?
      thnx for u help as always
        That confirms a panel fault - you can try see if you can find a shorted ceramic capacitor on the panel boards, but it is probably not fixable (gate or source driver IC failure, bonded to panel.)
        • daphney
          • Feb 2014
          • 93
          would it be just 1 cap on the panel board? i had a quick look & 4 buzz from 7 on dead side will look properly later there all the bigger 1s
          sorry i no that prob dont help
          thnx
            Most of the time, the cap appears shorted but when removed it is OK, it is the chip (driver IC) on the ribbon which has shorted in that case; it will not be a repairable fault. It would be rare to find many caps shorted at once but one bad driver IC could make a lot of caps look bad.
            • daphney
              • Feb 2014
              • 93
              i think i may have found the culprit cap is c112 on board connected to panel but i cant find on schematic i got from net any1 no what value of this is?
              thnx as always
                If it is in a similar place to other capacitors you may be able to remove a good one and compare, otherwise you will have to find a cracked screen to match against.
                • mmartell
                  • Oct 2013
                  • 3189
                  Doesn't sound like he's verified that is the problem. Wouldn't it be ok to remove it and run the set to see if the bad half of screen works ?
                  • daphney
                    • Feb 2014
                    • 93
                    i have removed c112 from board & it buzzs both ways theres 2 boards for screen 1 for left & right so would the good side have same caps? so i could try with 1 from there? & mayb measure to see what i need?
                    or is it safe to start tv with c112 missing just to see if works?
                    thnx as always
                      You could try that, could you supply a clear photo of the area around the bad cap and one of the whole half of the panel.
                      I would not advise running it without the cap present as damage to the screen is possible.
                      • daphney
                        • Feb 2014
                        • 93
                        hope these are clear enuff best i could do
                        pic 1 area of removed cap 2 board from middle of tv 3 from left side
                        thnx as always
                        • tibimakai
                          • Jan 2012
                          • 3680
                          In the first picture, there is a burn mark?
                            Photos aren't really clear enough; it looks like your camera needs more light (that's why the image looks fuzzy), so try perhaps opening a window or taking the panel out into sunlight, we need to see the writing next to each capacitor and the blue traces.
                            Also investigate that burn mark as it looks like Tibi may have a point there... that does look a little iffy... could just be flux or something more severe.
                            • daphney
                              • Feb 2014
                              • 93
                              the burn is were i used flux pen on cap before removed wasnt there before i will try & take some better pics later & upload
                              thnx as always
                              • daphney
                                • Feb 2014
                                • 93
                                here are some more pics its the middle on black side of screen so last pic is middle on good side of screen just incase it helps hope these are clearer
                                thnx as always
                                • mmartell
                                  RCA Virtuoso RHOS581SM-D Picture Fault
                                  by mmartell
                                  Picture looks stretched out and it looks like every other vertical line is not being drawn though hard to see that in the pics.
                                  I've disconnected each half of the panel and the fault remains exact save for the disconnected side being white.
                                  The original complaint was the tuner stopped working so the main was replaced however the new and old board exhibit the same picture defect.
                                  Nothing is getting hot and pushing on the panel drivers effects no change in the picture.
                                  So with that does anyone know how to enter the Service Menu on this...
                                  02-05-2022, 10:53 AM
                                • Tr0ll
                                  by Tr0ll
                                  Original T-con:
                                  First replacement T-con:
                                  10-07-2023, 07:48 PM
                                • JJAAMM
                                  by JJAAMM
                                  Problem
                                  07-06-2023, 06:01 AM
                                • TR103
                                  by TR103
                                  - it keeps rebooting
                                  01-22-2025, 04:12 PM
                                • Mgiffune
                                  by Mgiffune
                                  06-09-2024, 10:28 AM
