Grey/Gray Screen
  • Yingus
    • Apr 2014
    • 12
    • England
    Grey/Gray Screen
    Hi, A friend of mine has a LG 47 inch 3d smart tv, their son kicked a ball and it hit the tv, The screen did not break but now all it shows is a gray/grey screen, Any ideas ?
    I spelled Grey 2 ways because some countries spell it different
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: Grey/Gray Screen
    If the tv turns on and has backlight on but no picture usually means the screen has a short in half of the screen. You can test buy disconnectig one of the t con ribbons that go to the panel and turn it on half the screen should show a picture. Then swap them and disconnect the other side and see if you get a picture. If you don't get a picture each time on each side of the screen then the side you leave hooked up and no picture displays had a short in it.
    • R_J
      • Jun 2012
      • 9623
      If a ball was kicked at the screen, my moneys on the screen being broken.
      • Yingus
        • Apr 2014
        • 12
        • England
        But there is no visible damage and the tv lights up but with just a plain grey picture, So i would assume it's ok but i am not usre.
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Nah--Screen will be stuffed for certain! A spare-parts set now.....
          The actual screen part is a sandwiched layer of glass with a plastic film that is only 1mm thick, and not supported very well--Even carrying roughly or a gentle knock with these newish sets can break them!
          There doesnt always appear any visible damage on the face of the screen--even under strong light or backlight...
          Football in it--Death to it for definite!
          TELEFIX
          • Yingus
            • Apr 2014
            • 12
            • England
            OK, Thank you for the answer, It is very much appreciated as always.
            • SteveNielsen
              Retired Tech
              • Jun 2012
              • 2327
              BTW, according to dictionaries both spellings of grey/gray are acceptable.
              • Mad_Science
                Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
                by Mad_Science
                I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
                03-01-2024, 05:05 PM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
              • toddw65
                Sanyo DP5834 - Gray Screen
                by toddw65
                Hey All,
                I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
                Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
                Thanks,...
                10-31-2024, 10:37 AM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
