hitachi 32HDT21M cycles through colours
    Hi I have the above plasma which was kept in storage for a year.
    When I switched it on it cycles through colours on the display continuously accompanied by a high pitched whine which changes tone with the colours and gets louder the longer I leave the set on. I have no display apart from this . Ive have had a quick look and cannot see anything obvious. Also worth noting that this set worked fine before going into storage.
    Please can somebody offer some guidance .
    many thanks
    Re: hitachi 32HDT21M cycles through colours
    seeing as it's been in the cold maybe check for cold/broken solder joints on the back of the board?
      thanks for the quick reply. I will check this out. this is the first plasma I have had dealings with and didn't want to go in blind so to speak.
        I found this for a 32HDT20, does this tv have a seperate controller?
        Symptom: DEEP BLOOD RED IMAGE, HUM FROM PLASMA DISPLAY, NO OSD OR VIDEO
        Cause: CHECK 8 PIN DIN CORD FOR BENT PIN AND 8 PIN JACK ON BOTH UNITS FOR OPEN CONNECTION
          yes it does . thanks for that. will check this
            Consider the possibility of loose connectors or moisture ingress.
              Vestel based...?
              TELEFIX
