hitachi 32HDT21M cycles through colours
  • jwilliams1967
    • Apr 2014
    • 54
    • uk
    Hi I have the above plasma which was kept in storage for a year.
    When I switched it on it cycles through colours on the display continuously accompanied by a high pitched whine which changes tone with the colours and gets louder the longer I leave the set on. I have no display apart from this . Ive have had a quick look and cannot see anything obvious. Also worth noting that this set worked fine before going into storage.
    Please can somebody offer some guidance .
    many thanks
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Re: hitachi 32HDT21M cycles through colours
    seeing as it's been in the cold maybe check for cold/broken solder joints on the back of the board?
    • jwilliams1967
      • Apr 2014
      • 54
      • uk
      thanks for the quick reply. I will check this out. this is the first plasma I have had dealings with and didn't want to go in blind so to speak.
      • R_J
        • Jun 2012
        • 9623
        I found this for a 32HDT20, does this tv have a seperate controller?
        Symptom: DEEP BLOOD RED IMAGE, HUM FROM PLASMA DISPLAY, NO OSD OR VIDEO
        Cause: CHECK 8 PIN DIN CORD FOR BENT PIN AND 8 PIN JACK ON BOTH UNITS FOR OPEN CONNECTION
        • jwilliams1967
          • Apr 2014
          • 54
          • uk
          yes it does . thanks for that. will check this
            Consider the possibility of loose connectors or moisture ingress.
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Vestel based...?
              TELEFIX
              • Jaime Morillo
                Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                by Jaime Morillo
                Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                The TV was stuck on the logo and I couldn't access the update menu.
                I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                The image result was good, but the image is inverted.
                The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                08-18-2025, 11:38 AM
              • wolf1976
                hitachi 50hk5600 problem with display
                by wolf1976
                hi
                i have the above tv and the display starts distorts the display at only in applications like you tube
                after and on the didital channels
                now without connect the antenna only the image of itsselfs tv i have the image i have in attach
                i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
                can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
                09-13-2025, 02:26 PM
              • edugimeno
                (old) LG 32lk330 cycles Backlight 3 times and then OFF
                by edugimeno
                Hi!! I have been given this old TV set.
                When I hit the power button, the BL (as you know this is a CFL backlight) turns on, video works fine as I can see the LG logo show off, but the backlight starts going on-off for 3 times, when it gives up and turns completly off
                This set has a inverter board on the top right corner. This inverter (or the tubes, I don't really know) buzzes very loudly during the second that the BL stays ON. I have posted a video, turn your volume UP!
                https://fileport.io/9EdfmD5qtEaw
                I have checked voltages at the PS
                All normal voltages...
                12-11-2023, 01:28 PM
              • massimomax
                Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                by massimomax
                Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                spero che qualcuno può averlo per riprogrammare eprom. grazie
                Post in English !!!
                I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                02-28-2025, 07:27 AM
              • dragometin
                Hitachi 40HYC42
                by dragometin
                TV Model: Hitachi 40HYC42
                Power Supply: 17IPS71
                MainBoard: 17MB95M
                Panel: VES400UNDS-2D-NO3
                When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                Is there any variants on 17IPS71 power supply's?
                UART output pins 10 and 12 on scart connector:
                Code:
                12:24:04.595
                08-08-2024, 05:53 AM
