Philips 55pfl5766/f7 Software crashes
  • Davi.p
    • Sep 2009
    • 4265
    • Italy - Milan
    #101
    i want to spend few words about the first attempt..
    Reflow is not an exact art, i'm working on a lcd tv with evenly spaced horizontal lines on video, i made a full reflow with flux and the right movement of the main chip on tcon.. now i have no more image!! You don't know how much nervous i am.. this is not the first one..
    the first was also a Philips with common problem at the processor balls, it was 70% of times working, after the reflow.. totally shut off!!! f... off...
    • Diah
      • Feb 2013
      • 6343
      Originally posted by x_orange90_x
      I don't see an option to disable automatic updates 😬 I'm still leery about it updating as 11 caused issues for so many people.
      read here on Philips
      • x_orange90_x
        • May 2015
        • 702
        Originally posted by Diah
        I'll double check, but I didn't see an Auto Update option. My gui looks completely different from that. I went to Settings -> Device Preferences -> About and did not see it there, nor was it under System Update.. That goes directly to checking for updates. I disconnected from WiFi after the notification popped up, so I think for now as long as it's not connected it will be okay.. Do you know of any hidden settings menus that might contain the option?
        • Diah
          • Feb 2013
          • 6343
          impossible .. at user menu there should be automatic update on / off..
          • x_orange90_x
            • May 2015
            • 702
            Okay I'll check when I get home. So IF there is an option, should I factory reset it again to clear the pending update? Or would that result in it applying the update?
            • Diah
              • Feb 2013
              • 6343
              yes you can factory reset first with out internet connection
              • spice_disc
                Vizio TV M50-C1 reboot cycle and static on screen
                by spice_disc
                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                09-08-2024, 02:37 PM
              • Modelvincent
                Philips 46FPL8605 reboot sometimes
                by Modelvincent
                I'm still having a problem with my philips 46FPL8605 TV.
                It works correctly most of the time, but sometime, the screen goes black, the ambilight led do some scrap, then after some seconds the audio shutdown and the TV restart.
                After that, my freebox pop says me that the HDMI has been disconnected.
                This is not a temperature problem, sometimes, it appears just after startup, sometime after 1 hour. Sometimes it reboots 1 ou twice in 4 hours, sometimes it's 4 time in less than than 1hour...
                I've build a...
                03-21-2023, 10:49 AM
              • ictc
                Lenovo IdeaPad S145 boot when cold than crash after feew minutes
                by ictc
                I received this laptop, which initially boots into Windows normally, but after a few minutes, the system freezes with no display and no response except for power button. When this happens, power consumption rises to about 1A (without the battery connected), and the CPU becomes noticeably hotter compared to when the machine is operating normally.
                I have already tried removing the additional RAM module, which initially showed some promise, but the issue persisted after a reboot. I also attempted replacing the BIOS, but this did not resolve the problem.
                When the system crashes,...
                01-31-2025, 11:29 AM
              • aidanmo
                Philips 43PUS7506/12 - Loud blown out sound
                by aidanmo
                I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                I thought maybe the speakers got damaged, so I replaced them - no dice.
                • Using the internal speakers, it always happens.
                • Using the headphone jack, it never happens.
                • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                02-28-2025, 03:13 PM
              • reessi
                LG 42LC55 - Fixed power fault caps, now NO input on HDMI & VGA, also freezes & B/L !
                by reessi
                This TV had the well known power supply issue, took ages to turn on etc until one day it never turned on, I removed and tested all output caps on the PSU with an ESR meter and replaced the ones I've marked in blue on the photo (they are the new ones).
                After this it turns on fine but no signal is displayed when selecting VGA or HDMI 1 & 2 but the laptop always correctly sees the tv and brings up the name and resolution...
                My new flatmate assured me the hdmi's had previously worked after waiting a long time for the TV to turn on but he...
                04-30-2021, 04:28 AM
