Philips 55pfl5766/f7 Software crashes
Got the replacement board today and installed it. The tv still does not work.. I can hear the power supply staying on now instead of power cycling, but I get no sound, no lights, nothing. The only difference between these boards is the EMMC chip in which the replacement is NOT a Hynix which I thought would be beneficial.
My power supply board looks IDENTICAL to the sellers (originally he had them listed as a kit but separated for me). The only difference between the power supply board is the very last digit. Mine is "BAD1R0F01 02 2" and his is "BAD1R0F01 02 3". I doubt they have to match.
The only thing that happened between this tv functioning and not functioning was my attempt at heating the eMMC on the original board. I have no idea what's going on here and I'm ready to kick this thing 😡
Edit: I did find a difference. C657 is on his board but not mine. There is a place on my board for it. Would this cause an issue? Could I simply install the missing cap?Last edited by x_orange90_x; 11-09-2024, 07:50 PM.Comment
I guess it doesn't matter.. I agreed the missing cap. No different.
Only issue with the main board I got is the volume down bottom doesn't click when pressed. I supposed it could be broken/stuck in.. but I doubt that would be the issueComment
I thought installing that missing capacitor would take care of it nope. Do you think the stuck Volume Down button could be preventing the tv from turning on?Comment
I've asked the seller to send me the power supply that goes with this main board. Either it's going to work, or it isn't. If it does not then there has to be an issue with the main board I received.
Btw, I checked the voltage of the capacitor I installed and it is reading correctly, so there is at least voltage to that point.Comment
I know "pfl" series is from many years ago, easily the board you ordered sat unused for long time, since those voices about bad naming of hinyx flash chips, maybe it had long time to oxydize it too, too bad solder to hope to recover it.. only reballing or another board.. as.you see the.smaller the balls, the more the problemsLast edited by Davi.p; 11-10-2024, 12:57 AM.Comment
Check the button with a multimeter to see if it is leaking, as well as the others, if it shorts or has a leak, then because of this the TV may not turn on, since it cannot execute two commands at the same time.Comment
Edit: I did find a difference. C657 is on his board but not mine. There is a place on my board for it. Would this cause an issue? Could I simply install the missing cap?Comment
Davi.p: the new board does not have a Hynix chip. Also, the seller said there's board were pulled from a brand new tv that was cracked.
Lotas: I considered simply removing it from the board, but if I did that the seller surely wouldn't take it back if I asked to return it. It definitely seems plausible that it COULD prevent the tv from turning on because with other tvs before I've tried forcing resets and such by holding input and power, power and volume, etc and the TV would not turn on with a combination being pressed. As for checking with a multimeter I'm not sure how. It is soldered on by 4 points and I don't know how to check that.
Diah: not sure what you mean. All connectors are labeled the same and fit correctly. The Wi-Fi board is separate and plugs in via a cable, which I have tried leaving unplugged to no avail. Buttons are part of the board, not a separate PCB so I don't think that would be an issue. Both models have identical features. I've come to the conclusion that the F7D being a later serial number (ME7) is just an updated revision with alternate eMMC manufacturer because of previous high failure rate?
The seller did say he would send me his power supply tomorrow to try. Unless me heating up the old eMMC caused a short that damaged my power supply, I don't see how it could be an issue of incompatibility. ShopJimmy sells 7 or 8 different board kits for this tv and they all contain the same model power supply that under known models lists ALL revisions. That implies a single power supply is compatible between all revisions. Interestingly though, the power supply they sell has the C657 capacitor whereas mine *did not*... But because I added it I don't think that's the issue.
I'm leaning towards it actually being the stuck button because it makes the most sense. I gotta I could just start checking the resistance between the solders and comparing it to the other buttons.Comment
I read back the first post, now on relax i can focus better maybe, i would to know, when you heated the rom, have you cool it down 100% before turning it on?
i forgot.. the board must be cool 100% due to thermal protection
About the stuck keys, i considered you had the remote too, so the local button do not have to interfere, but maybe you repair for home business and you have not the remote, so this changes..
PS: noticed now you last photo... and this would be brand new?! Compliments to the seller.. this cpu has very bad balls and fried!!Last edited by Davi.p; 11-10-2024, 03:16 PM.Comment
And ya, between the heat discoloration and stuck button there no way this came from an even remotely new set 🙄Comment
by EvazXHello everyone,
I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
However, after some time, the replacement motherboard...08-25-2025, 06:09 PM -
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo -
by ModelvincentHi,
I'm still having a problem with my philips 46FPL8605 TV.
It works correctly most of the time, but sometime, the screen goes black, the ambilight led do some scrap, then after some seconds the audio shutdown and the TV restart.
After that, my freebox pop says me that the HDMI has been disconnected.
This is not a temperature problem, sometimes, it appears just after startup, sometime after 1 hour. Sometimes it reboots 1 ou twice in 4 hours, sometimes it's 4 time in less than than 1hour...
I've build a...03-21-2023, 10:49 AM -
hello i bought a faulty radeon r9 290 (black screen) to learn to fix gpu's, when it arrived i mesured resistances on 3.3 v and 12v both on the pcie connector and cables i have no idea on how to recognize 1.8v pex and 5v but i checked all inductors and none had a dead short only one was 55 or 140 ohms i don't really remember and i assumed it was memory i installed it on the pc and it delivered no image, not even a backlight so i installed it as a secondary graphics card using the igpu as primary, both device manager and gpu-z only showed the igpu so i assumed it was acutally a no detect even tough...
by alro7779Hello, guys!
The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601... - Loading...
