Philips 55pfl5766/f7 Software crashes
  • x_orange90_x
    • May 2015
    • 759
    I received this tv stuck in a boot loop and was able to get it working after letting it sit and reboot several times. Whenever I try do things in the settings it will crash back to the main screen, lock up, or reboot itself. I tried doing a Reset on it and after it rebooted nothing was changed. The Google account used was still present, and the downloaded apps were all still there. I can sometimes get further into settings such as setting up my wifi, not most times it will crash and reboot. I even manually removed the Google account and it CAME BACK after rebooting the tv. Before it rebooted one time it popped up a message about Storage being low. Yesterday I was away from home and came back to it powered on and stuck on the Androidtv loading screen.
    I've read that the last update to Android 11 messed up a lot of these TVs. I can't seem to find any firmware for it online. If I could find it, I would try flashing an older build. Anyone have this model or a similar one that they've encountered these issues with and possibly resolved?
    Attached is a pic of the software information.
  • Diah
    • Feb 2013
    • 6540
    edit... its correct just for yours country.... but if you tell the chassis no you could downgrade it from android 11 to 10
    • x_orange90_x
      • May 2015
      • 759
      I'm not sure which number it would be, so I've attached a picture of the sticker.
      • Diah
        • Feb 2013
        • 6540
        try hard reset , unplug it from wall socket for 1 minute.... press the joystick and pull it down... keep it in theis position... plug the tv back to wall t, release the pressing you did only after the front LED change color from white to green.... leave it it could reboot 2-3 time even you can hear start Melodie of first setup.
        • x_orange90_x
          • May 2015
          • 759
          I will try this, thank you. I press in the joystick and pull it toward the front of the tv, correct?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4532
            • Italy - Milan
            try emmc reballing if possible..
            • Diah
              • Feb 2013
              • 6540
              sorry this method will not work on your set, you need to do it from recovery.
              1- at setting go to the page of were you show it the info,,, at build inf click on it 0-10 time to enable developer option, go to to the developer option and check USB adb. connect your set with yours router and remark the IP address... from PC which it should connected to same router you can run ADB .
              adb connect XXXXXXXX ( yours TV IP )
              after it connected send
              adb boot recovery
              read more how to install ADB on PC and its command.
              • x_orange90_x
                • May 2015
                • 759
                adb boot recovery
                I tried getting into settings to enable ADB, not any time I press a button on the remote the tv freezes or reboots. I had an idea to remove the batteries and put them into an old Magnavox remote I have.. Sure enough the Magnavox remote works the tv AND while using it the TV isn't freezing or rebooting. However, I still cannot remove the original Google account saved on it, and likewise Reset on settings does NOT reset anything.
                I'm assuming this means the software is still corrupt, and it doesn't play well with it's own Bluetooth remote especially.
                Edit: nevermind that, it's back to rebooting again even with the other remote. I guess I have to try and get it back to where it stays on and functions so I can get it connected to the PC.
                • Diah
                  • Feb 2013
                  • 6540
                  you still can use air mouse with it if you open the setting menu
                  • x_orange90_x
                    • May 2015
                    • 759
                    I got it connected but it's not entering recovery like expected.
                    When I send the adb reboot recovery command the tv reboots normally right back to the home screen. I tried twice and it still doesn't enter recovery.
                    • x_orange90_x
                      • May 2015
                      • 759
                      It acts like it's stuck in a READ ONLY state. No changes are saved after rebooting. Wi-Fi connection, account, even Developer Mode gets reset after rebooting the tv.
                      • Diah
                        • Feb 2013
                        • 6540
                        the best things right now use TTL adapter to capture the boot Log to know what are going inside..
                        • x_orange90_x
                          • May 2015
                          • 759
                          I unfortunately don't have one of those or the knowledge of using it. Looks like my only option is to buy a replacement main board and hope it's not updated
                          • Diah
                            • Feb 2013
                            • 6540
                            then try to log in SAM press fast “062596”, directly followed by the “INFO/OK” there you will see if there are error buffer register and option to clear them.... to get out from SAM press exit
                            and also you have other Option Factory mode you can make hard reset and clear operation hours etc... from the “menu/home” press “1999”, directly followed by the “Back/Return” button
                            • x_orange90_x
                              • May 2015
                              • 759
                              What is SAM? Do I do that from the Home screen as well?
                              • Diah
                                • Feb 2013
                                • 6540
                                SAM = Service Alignment Mode you can with it , Operation hours counter (maximum five digits displayed).,, Software version, error codes, and option settings display.,, Error buffer clearing.,, Option settings.,, Software alignments (White Tone).,, NVM Editor.,, Set screen mode to full screen (all content is visible).
                                Factory mode ,,, To perform extended alignments.
                                Specifications ,,, Displaying and or changing Panel ID information.,, Displaying and or changing Tuner ID information.,,,Error buffer clearing.,,,,Various software alignment settings.,, Testpattern displaying. ,, Public Broadcasting Service password Reset.,,,etc
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4532
                                  • Italy - Milan
                                  Anyway the fault is between the soldering of BGA chip set, has it EMMC chip or tsop48 nand flash?
                                  • Diah
                                    • Feb 2013
                                    • 6540
                                    Deleted abusive post by Diah. No more warnings for this behavior.
                                    • x_orange90_x
                                      • May 2015
                                      • 759
                                      I attempted to enter those codes but the damn thing won't stay on long enough to do anything now. I can barely get the home screen to load before it reboots. I'll try it again later.
                                      I'm skeptical to buying a replacement board too because the chances of this happening again seem pretty high given the widespread failure after the last update.
                                      • Diah
                                        • Feb 2013
                                        • 6540
                                        for help to keep it long stay on freezing the chips on mainboards
                                        • EvazX
                                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                          by EvazX
                                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                          However, after some time, the replacement motherboard...
                                          08-25-2025, 06:09 PM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • Modelvincent
                                          Philips 46FPL8605 reboot sometimes
                                          by Modelvincent
                                          I'm still having a problem with my philips 46FPL8605 TV.
                                          It works correctly most of the time, but sometime, the screen goes black, the ambilight led do some scrap, then after some seconds the audio shutdown and the TV restart.
                                          After that, my freebox pop says me that the HDMI has been disconnected.
                                          This is not a temperature problem, sometimes, it appears just after startup, sometime after 1 hour. Sometimes it reboots 1 ou twice in 4 hours, sometimes it's 4 time in less than than 1hour...
                                          I've build a...
                                          03-21-2023, 10:49 AM
                                        • Francesco Valsecchi
                                          r9 290 "black screen"
                                          by Francesco Valsecchi
                                          hello i bought a faulty radeon r9 290 (black screen) to learn to fix gpu's, when it arrived i mesured resistances on 3.3 v and 12v both on the pcie connector and cables i have no idea on how to recognize 1.8v pex and 5v but i checked all inductors and none had a dead short only one was 55 or 140 ohms i don't really remember and i assumed it was memory i installed it on the pc and it delivered no image, not even a backlight so i installed it as a secondary graphics card using the igpu as primary, both device manager and gpu-z only showed the igpu so i assumed it was acutally a no detect even tough...
                                          08-18-2025, 06:44 AM
                                        • gretti
                                          MSI Z370-A Pro, works but does not power off or reboot and USB issues
                                          by gretti
                                          I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                                          The MSI BIOS included the ME firmware for the board. The size...
                                          10-16-2025, 02:14 AM
