Philips 55pfl5766/f7 Software crashes
+ More Options
Posts
  • Diah
    • Feb 2013
    • 6400
    they are fine.. yours replacement are in bad shape
    • x_orange90_x
      • May 2015
      • 727
      That's what I'm leaning toward. Haven't heard back from the seller since I told him this board had heat damage. There were not pictures of the bottom in his listing. Think I now know why 🙄
      Edit: I sent the picture of the heat damage to the seller and this was the reply:
      To be honest, that does not look good at all. I had 3 of these from a walmart return pallet I bought of new sets with broken screens. I unboxed them my self. But anything is possible. I will ship the power supply out as soon as the USPS opens back up tomorrow but I do not think it will help.
      If it does not just let me know and I will take care of it.
      I did call P&F tech today and he told me that it would/did not cross. But with the same panel and tcon I thought it should work. I could have a different software version though.
      • Diah
        • Feb 2013
        • 6400
        let give try with this replacement... list all voltage with its pin name on the PSU socket at time it is on
        • x_orange90_x
          • May 2015
          • 727
          You want me to check voltages with what I currently have, correct? My power supply and the "new" main board?
          • Diah
            • Feb 2013
            • 6400
            yes... most important the pin name as you have on the PSU print chart
            • x_orange90_x
              • May 2015
              • 727
              There isn't a Pinout chart on either side of the board that I've seen or recognized...
              • x_orange90_x
                • May 2015
                • 727
                Yea there is no chart anywhere on either side calling out the pins for that connector. Likewise I cannot find a schematic on Google. The seller is shipping the power supply today, so I should have it within a couple days.
                • Diah
                  • Feb 2013
                  • 6400
                  post clear photo on this jumpers area they have sign
                  • x_orange90_x
                    • May 2015
                    • 727
                    Underside added as well 😁
                    • Diah
                      • Feb 2013
                      • 6400
                      so the jumpers from the top are the print chart.... plug every things on and list the voltage as jumper name / measurements on the jumpers )
                      • x_orange90_x
                        • May 2015
                        • 727
                        Just ground to chassis and touch red probe anywhere on jumper?
                        • Diah
                          • Feb 2013
                          • 6400
                          yes
                          • x_orange90_x
                            • May 2015
                            • 727
                            yes
                            Here ya go:
                            J614 RESET - 3.31V
                            J615 ALL +3.3V - 3.31V
                            J609 AMP +13V - 14.38V
                            J616 P-ON-H2 - 3.28V
                            JS652 P-ON +21V for UHD - 19.8V
                            J605 BL-SW - 172mV
                            J603 01013-C - 0.00mV
                            J606 BL-ADJ - 155.1mV
                            I did not check J610 GND because I thought that might be a bad idea 😬
                            • Diah
                              • Feb 2013
                              • 6400
                              Here ya go:
                              J614 RESET - 3.31V
                              J605 BL-SW - 172mV
                              its look like in standby mode right now
                              • x_orange90_x
                                • May 2015
                                • 727
                                The seller shipped the power supply and I should get it by Friday. Do you think though that it's a main board issue not telling the power supply to turn on? If it is the main board that's the issue then trying the new power supply would be pointless. Power supplies doing have firmware so I really do doubt that it's a compatibility issue..
                                I do believe he has a couple more main boards as he said he bought 3 of these TVs at once.
                                • Diah
                                  • Feb 2013
                                  • 6400
                                  yours PSU right now with this reading working in Standby mode.. yours system Android.. so the PSU at such system always warm start... not cold start as other system like vidaa or Linux or web OS
                                  i have doubt if the other PSU will change some things... we wait and let see
                                  • x_orange90_x
                                    • May 2015
                                    • 727
                                    I received the power supply yesterday. Absolutely no change. Has to be a faulty main board. I contacted the seller again and he refunded my money and told me to keep both boards. I found another board and ordered it already. It should arrive next week, so I'll be back when it shows up.
                                    • Diah
                                      • Feb 2013
                                      • 6400
                                      this free of charge MB time you fix first the keys.... if no change,,, then Reflow the SoC only.... dont worry on the SoC it will able to receive heat 280"
                                      • x_orange90_x
                                        • May 2015
                                        • 727
                                        I considered reflowing it, and I might try that tonight just for fun. The burn on the back is what I'm more concerned about. It got HOT and therefore may be damaged, or the solders might not melt right. Even if it works I'll be sticking with the new one because who knows how long this would last. It is, for the sake of diagnostics and knowing what actually was wrong, worth trying though. My new board should arrive Monday according to FedEx.
                                        • x_orange90_x
                                          • May 2015
                                          • 727
                                          Got the new board today, and in fact, they sent me the whole kit with power supply, tcon, and ribbons/wires! I couldn't use the tcon because the ribbons to the panel were slightly smaller, so I left mine installed.
                                          And... IT'S ALIVE!
                                          It's updating now, which I'm sure is to the latest Android version... But it's not a Hynix chip so I think I'll be fine.
                                          Edit: it updated to Android 9 and it's up and running now, but it wants to update to 11... I don't see an option to disable automatic updates 😬 I'm still leery about it updating as 11 caused issues for so many people.
                                          • EvazX
                                            ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                            by EvazX
                                            I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                            Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                            For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                            However, after some time, the replacement motherboard...
                                            08-25-2025, 06:09 PM
                                          • spice_disc
                                            Vizio TV M50-C1 reboot cycle and static on screen
                                            by spice_disc
                                            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                            09-08-2024, 02:37 PM
                                          • Modelvincent
                                            Philips 46FPL8605 reboot sometimes
                                            by Modelvincent
                                            I'm still having a problem with my philips 46FPL8605 TV.
                                            It works correctly most of the time, but sometime, the screen goes black, the ambilight led do some scrap, then after some seconds the audio shutdown and the TV restart.
                                            After that, my freebox pop says me that the HDMI has been disconnected.
                                            This is not a temperature problem, sometimes, it appears just after startup, sometime after 1 hour. Sometimes it reboots 1 ou twice in 4 hours, sometimes it's 4 time in less than than 1hour...
                                            I've build a...
                                            03-21-2023, 10:49 AM
                                          • Francesco Valsecchi
                                            r9 290 "black screen"
                                            by Francesco Valsecchi
                                            hello i bought a faulty radeon r9 290 (black screen) to learn to fix gpu's, when it arrived i mesured resistances on 3.3 v and 12v both on the pcie connector and cables i have no idea on how to recognize 1.8v pex and 5v but i checked all inductors and none had a dead short only one was 55 or 140 ohms i don't really remember and i assumed it was memory i installed it on the pc and it delivered no image, not even a backlight so i installed it as a secondary graphics card using the igpu as primary, both device manager and gpu-z only showed the igpu so i assumed it was acutally a no detect even tough...
                                            08-18-2025, 06:44 AM
                                          • ictc
                                            Lenovo IdeaPad S145 boot when cold than crash after feew minutes
                                            by ictc
                                            I received this laptop, which initially boots into Windows normally, but after a few minutes, the system freezes with no display and no response except for power button. When this happens, power consumption rises to about 1A (without the battery connected), and the CPU becomes noticeably hotter compared to when the machine is operating normally.
                                            I have already tried removing the additional RAM module, which initially showed some promise, but the issue persisted after a reboot. I also attempted replacing the BIOS, but this did not resolve the problem.
                                            When the system crashes,...
                                            01-31-2025, 11:29 AM
