Dell W4200HD
  • Ltank
    • Jun 2013
    • 776
    Dell W4200HD
    Set has a good picture and sound but there is a occasional flicker in the piture. I measuredthe Ysus and it is steady. Everything looks good. I can not find any kind if a schematic or service manual. The blink is fast don't know if it has to do with the scan boards or power or main board. I hate to return it to them with it not solved. Do I give it back to them and tell them to wait untill it just dies? Advice? Help?
  • capkid
    • Oct 2010
    • 1339
    Re: Dell W4200HD
    When I can't find a service manual for my particular TV model, I do a lookup on ShopJimmy to see if I can find a close match by parts search. It looks like the 42MF230A/37 is fairly close (not sure if an SM exists for 42MF230A/37). There may be other possible matches. You might even find a solution by Google searching or searching the forum by using one of those matches.
    LG Plasma Mal-Discharge Correction Service
      Re: Dell W4200HD
      try checking Vs/Va as it blinks, is it steady?
      • Ltank
        • Jun 2013
        • 776
        Re: Dell W4200HD
        Steady
          Re: Dell W4200HD
          What about Vsc, and Ve? (On the Y- and X-main boards respectively.
          • Ltank
            • Jun 2013
            • 776
            Re: Dell W4200HD
            Tested all voltages while flickering was visable on screen using Fluke 87 meter
            Va, Vcc, Ve, Vs and Vset were stable with .4vdc with slight variations.
            The Control board LJ92-00990A did have a Led blinking for the Vsync. was on steady on. Shop Jimmy does not have it they have a later version
            LJ92-00990D would it work in its place?
            With a Vsync led blinking, what would be the cause? Sync coming in? Sync going out? Sync in the board?
            Thanks Guys
            • Ltank
              • Jun 2013
              • 776
              Re: Dell W4200HD
              Pic of Board
                • 31197
                Re: Dell W4200HD
                omfg!
                that thing was designed by a crack addict!
                i hope it has some fans on the case!!!
                • Ltank
                  • Jun 2013
                  • 776
                  Re: Dell W4200HD
                  Not a single fan, only heat sinks!
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • Akhlz001
                    by Akhlz001
                    09-20-2025, 07:15 PM
                  • master3112
                    by master3112
                    07-29-2025, 01:55 PM
                  • F R 2568
                    Dell Latitude 5420 does not start (no post) need help to find the reason why
                    by F R 2568
                    Hello all,
                    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                    If the laptop is only connected to the AC adapter (battery removed):
                    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                    The power/battery...
                    01-08-2025, 05:45 AM
                  • diamon
                    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                    by diamon
                    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                    Pictures of these boards:
                    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                    Dell...
                    02-28-2024, 12:51 PM
