Samsung UN65CU8000F Change board settings
  • EazyBone
    • Jun 2023
    • 1363
    • United states
    Now, for whatever reason it turned off and won't turn back on lol. Oh boy. Well I'll get back if I can get it on again lol
    • Diah
      • Feb 2013
      • 6614
      my way don't answer questions not forward to me direct as quote.. but now i feel there are lost heads in this threat.... when you change one value reboot then change the other... some value are being false remarked when they depending on other value as True remarked in OS
      • EazyBone
        • Jun 2023
        • 1363
        • United states
        You said do the PDF, it doesn't have all the stuff on it like shown in the PDF. I did reset it, the panel type stays normal the model number doesn't change. Now no turn on. Gonna break it down again in a bit.
        Thx all for now, I'll be back with updates later
        • Diah
          • Feb 2013
          • 6614
          regards to yours Tv label i wrote... not the value in pdf to export it LOL... so or so you and lotas was on the way to brisk it by parts exchange and now you are.done.... so don't blame me i was on the right track always.
          • lotas
            • Jan 2016
            • 4908
            • Russia
            All settings
            and the changes are stored in eeprom 24C512, if you can't start it, then move it from the old board.
            But the native eeprom also stores its native keys, and these keys must correspond to the keys that are in the emmc.
              • 12323
              • U.S.
              #26
              Yep, it's not even annoying anymore it's just laughable how you are always correcting me and are SO wrong lotus.
              • EazyBone
                • Jun 2023
                • 1363
                • United states
                #27
                I didn't export the value of the PDF. I was sitting in the service menu and it just shut off. I'm saying besides the panel value which I input, and did factory resets after. Nothing changed... And I never blame anyone here. All help is appreciated.
                ​​​​​And lotas I may attempt that now that the board won't start.. will be a few days but I'll write back on here
                • EazyBone
                  • Jun 2023
                  • 1363
                  • United states
                  #28
                  I figured this out. The solution was absolutely simple
                  You send a command to the TV with remote.
                  Press Info, settings, 3,1,4 then hit exit and unplug tv.
                  This does some screen correction command. Something I think many here will find useful.
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • ohren
                    by ohren
                    09-08-2023, 05:24 PM
                  • C152Heavy
                    by C152Heavy
                    Summary for TL-DR readers:
                    • VCC pin (18) of PFC...
                    01-11-2023, 02:53 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
