Samsung UN65CU8000F Change board settings
  • EazyBone
    • Jun 2023
    • 1309
    • United states
    The board in this TV originally is BN 94-18058M. This is the model straight from the factory. When I look this up it shows the model for the 55-in is what the board should be for. But I matched the numbers and everything and it should work.
    I put the new board in the TV and I have a small line around the bottom left and bottom and the colors are off I assume the board is set up for a 55-in. I am currently in the service menu but I do not know where to navigate or how to change the board from 55 to 65.
    Is this even a possibility and how do I do it please.
  • Diah
    • Feb 2013
    • 6357
    first just match yours chassis No which it is 65K6AU0SB from the list
    • lotas
      • Jan 2016
      • 4554
      • Russia
      It won't help, you need to transfer from the old spi flash 25Q80 (T-con) board, it contains all the settings of the above panel, you may also have to rearrange the position resistors...​
      • lotas
        • Jan 2016
        • 4554
        • Russia
        Your panel
        • EazyBone
          • Jun 2023
          • 1309
          • United states
          Originally posted by lotas
          Your panel
          But this won't help at all? The boards match numbers..
          • lotas
            • Jan 2016
            • 4554
            • Russia
            What about the old board? Where is its original motherboard?
            • EazyBone
              • Jun 2023
              • 1309
              • United states
              I can move a chip if necessary.. this board was dead though so is that going to matter? Which chip is it
              • EazyBone
                • Jun 2023
                • 1309
                • United states
                The symptom was no red light, no voltage going to panel.
                • Diah
                  • Feb 2013
                  • 6357
                  MAN what are you talking... my first post just do it look on your photo
                  65K6AU0SB OPTION NONE
                  after change you need hard reset
                  • lotas
                    • Jan 2016
                    • 4554
                    • Russia
                    Well, if you don’t know where the original motherboard is, then I don’t know if this procedure will help or not (maybe it has the same characteristics from “55”) Look at this one, what is the marking on it?
                    • Diah
                      • Feb 2013
                      • 6357
                      sorry both of you are going to damage the replacement boards... no need to change any parts.... the value of all sizes are saved in the firmware... just change the register will write the correct data, have fun.
                      • EazyBone
                        • Jun 2023
                        • 1309
                        • United states
                        Yes Diah I changed the tv. When you say hard reset, do you mean factory reset from service menu? Or is there a different option. I have no issue trying things.
                        And lotas I have the original main board yes. There is a picture of 2 boards and that is a picture of the board with heatsink off
                        Edit Diah sorry I answered you in my head not neglect. I did a reset and it still shows model un55cu8000
                        • Diah
                          • Feb 2013
                          • 6357
                          make the change here in this photo
                          restart then log in again SM to check your change at same page take effect... yes... then do hard reset from service menu
                          • lotas
                            • Jan 2016
                            • 4554
                            • Russia
                            Try doing this on pages 4-25 - 4-29.(Their settings are the same...)
                            • EazyBone
                              • Jun 2023
                              • 1309
                              • United states
                              That's where I made the change. In the photo at service menu it shows the new panel but it still shows old model number and TCON for 55.
                              Picture in post 12. This is after a hard reset.
                              • nomoresonys
                                • 12104
                                • U.S.
                                maybe you need to make the change then save it or initialize something.
                                • Diah
                                  • Feb 2013
                                  • 6357
                                  just follow pdf lotas upload from page 57 to 61 regards yours Tv label
                                  • nomoresonys
                                    • 12104
                                    • U.S.
                                    Yes it's pretty simple when it's all spelled out in pdf. looks like old lotus came thru
                                    • EazyBone
                                      • Jun 2023
                                      • 1309
                                      • United states
                                      So I did the writing type for panel and get success but the rest of the PDF isn't in here. There is no spot for sw model or model code at all anywhere that I see. Front color was the only thing I could change.
                                      • lotas
                                        • Jan 2016
                                        • 4554
                                        • Russia
                                        I still have a long way to go before you.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • JDC
                                          by JDC
                                          ONN 100012588
                                          Long answer:
                                          07-15-2022, 07:39 AM
                                        • DynaxSC
                                          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                          by DynaxSC
                                          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                          The behaviour is also really very strange, i.e.:
                                          • The disk shows always up in BIOS - so it is recognized, so far so good
                                          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                          02-23-2025, 01:33 PM
                                        • Nicktronic
                                          Samsung Power Supply Board BN44-00874F
                                          by Nicktronic
                                          Hey everyone,
                                          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                          Anybody...
                                          03-17-2025, 06:20 AM
