Now, for whatever reason it turned off and won't turn back on lol. Oh boy. Well I'll get back if I can get it on again lol
Samsung UN65CU8000F Change board settings
my way don't answer questions not forward to me direct as quote.. but now i feel there are lost heads in this threat.... when you change one value reboot then change the other... some value are being false remarked when they depending on other value as True remarked in OSComment
You said do the PDF, it doesn't have all the stuff on it like shown in the PDF. I did reset it, the panel type stays normal the model number doesn't change. Now no turn on. Gonna break it down again in a bit.
Thx all for now, I'll be back with updates laterComment
regards to yours Tv label i wrote... not the value in pdf to export it LOL... so or so you and lotas was on the way to brisk it by parts exchange and now you are.done.... so don't blame me i was on the right track always.Comment
Yep, it's not even annoying anymore it's just laughable how you are always correcting me and are SO wrong lotus.
I didn't export the value of the PDF. I was sitting in the service menu and it just shut off. I'm saying besides the panel value which I input, and did factory resets after. Nothing changed... And I never blame anyone here. All help is appreciated.
And lotas I may attempt that now that the board won't start.. will be a few days but I'll write back on hereComment
I figured this out. The solution was absolutely simple
You send a command to the TV with remote.
Press Info, settings, 3,1,4 then hit exit and unplug tv.
This does some screen correction command. Something I think many here will find useful.Attached Filesif you find these attachements useful please consider making a small donation to the site
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
The models launched in 2018 and 2019 respectively.... -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
• Have obtained Samsung schematic & service documents - Can upload if helpful.
• Have read ALL applicable threads
• C1818 and CP820 replaced as low hanging fruit
• CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
• VCC pin (18) of PFC... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
- Loading...
