Trying To Fix: Samsung UN50TU7000 - Weird Fading Screen then Red blinking light
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Picked this up to resurrect.
    When I plugged it in it comes on for about 1 minute... after a minute the screen blacks out and I gets blinking red lights on the power button.
    I read that a common issue with this model is a failed BGA so I ordered a replacement on eBay.
    Sometimes the TV would produce an expanding blob on the screen before going black.
    See Video here
    20240916_211200_1.mp4
    I ordered a replacement board off of eBay and installed it tonight and got the same behavior.
    Did I get another defective board or is there an issue with the panel?
    After unplugging the TV for about 2-3 minutes the TV comes back on again for a while only to do the same thing again.
    Thanks for the assist.
  • EazyBone
    • Jun 2023
    • 1352
    • United states
    I have had 4 of these tvs, every one was a panel short.
    Sounds like the panel if it does it with new boards also. I don't feel a board would do that.
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      Thank you EzB. I have always known a panels to have hard shorts. Either it was shorted or it wasn't.
      This is the first time of me seeing a screen do this. And what makes things more mysterious is the 'short' goes away (at least for a while) after you unplug and reconnect the TV from the mains.
      Could this really be a dying capacitor or resistor on the panel boards?
      Edit to add:
      The replacement board was used as well so I couldn't immediately rule it out.
      • EazyBone
        • Jun 2023
        • 1352
        • United states
        I honestly don't know. When it comes to small tvs the time I invest is very small. Maybe more advanced people here could tell you, I'm basically a novice that can get around with common problems.. but I'm 0/4 on these 50 inch samsungs and they either had lines that turned into rebooting or some version of that.. so that's all I'm going off of. I just can't see two boards doing the same weird ass thing.. I see more every day but shit who knows.
        ​​​​Ands it's specifically the 50 inches, I have 55s and 65s etc etc and I've repaired them but 50 is no go.
          • 12241
          • U.S.
          can you post a picture of the screen "blob"?
          • KYBOSH
            • Oct 2011
            • 581
            • Unknown
            As requested.
            The picture doesn't do it justice.
            If you are able to see the video you'll see how it appears like an ever expanding blog of ink and then the screen goes to black.
Name:	Screenshot 2024-09-17 at 10.23.44 AM.png
            • EazyBone
              • Jun 2023
              • 1352
              • United states
              It's better to post videos from YouTube Link. People don't want to download your files is why he is asking for pictures. Viruses do still exist. At least I think that's why.
                • 12241
                • U.S.
                Notorious problem with MANY MANY samsungs. Some have been able to recover with resets, but in probably most cases for a short time before it comes back, I try the simple one first, unplug tv, hold power button on tv down for 30 seconds, wait 5 minutes and retry. Can also try different forms where you leave it unplugged for a day or 12 hours or 6, and also some were successful with factory resets. On some of my old lcd tvs in the past I would get similar rolling blobs of black and it was due to the tab bonds becoming loose, which I made workable again with shims or tape which was easier with the old tvs because they had a nice big metal frame to work with. Not sure if it would work as well if at all with the newer tvs tho.
                  • 12241
                  • U.S.
                  Here's an example of the tab bond issue I referred to: https://www.youtube.com/watch?v=vCExlSnG4yY
                  • EazyBone
                    • Jun 2023
                    • 1352
                    • United states
                    That videos awesome. Had no clue about that. OP I'd be curious to see if this does anything for you. Learning something new. Thx sony
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4432
                      • Italy - Milan
                      Kybosh, you are talking about changing board and failing BGA without naming it, more than this are missing photos of the boards, at least main and tcon if any, a very simillar defect is due to bad mosfets in tcon power section but more probably bad ceramic cap in recent sets
                      • Diah
                        • Feb 2013
                        • 6425
                        this is disorder at the gate transistor in panel ..the reason are MB panel driver.. try hard reset from service menu... or upgrade the firmware then again hard reset from S.M
                          • 12241
                          • U.S.
                          +1, sounds like a winner, try that.
                          • CapLeaker
                            Leaking Member
                            • 8297
                            Agree with that too! It's not the main board's fault.
                            • KYBOSH
                              • Oct 2011
                              • 581
                              • Unknown
                              Sincerest apologies Davi. I forgot the forst rule of badcap club!
                              • KYBOSH
                                • Oct 2011
                                • 581
                                • Unknown
                                ​Thank you for this Diah. Problem with this soln is the screen would not stay on long enough to navigate thru the service menu to reset it right? Ive never been done it before.
                                • KYBOSH
                                  • Oct 2011
                                  • 581
                                  • Unknown
                                  Thanks for this Sony. I'll see about the power button reset before i look into a service menu reset (which would be difficult to do with a blacked screen).
                                  • KYBOSH
                                    • Oct 2011
                                    • 581
                                    • Unknown
                                    Anyone know which Key Combo you need to press to enter into the Service Menu for the TU7000 series?
                                    I have found a list of 13 possible combinations ....
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4432
                                      • Italy - Milan
                                      Ok, but you did not tell wich board you've changed, the main board? Can you remove the heatsink shield and place a good very bright photo of it? (preferably near 2000x2000), i see the tcon circuitry is integrated with that and needs voltage injecting, so a bench psu is suitable..
                                      but in case you have changed it maybe the fault is in screen's strip boards, especially tiny caps, so you need to locate wich pins connects the 15-17v rail to the panel, and inject some voltage gradually to these until the bad cap turns hot and locate it.. i will tell you how larer..
                                      this is a difficult task, the other alternative maybe easier, is to use the tv long enough until the working state shortens until the bad cap turns completely shorted and you can easily locate it with multimeter.. bye
                                      • Diah
                                        • Feb 2013
                                        • 6425
                                        even if there are 20 ways of combination to inter service menu... but the tv in standby and try one by one.
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • Sam Scarbo
                                          Brother DCP-L2540DW scanner/printer - only showing blinking screen in LCD.
                                          by Sam Scarbo
                                          I got this broken printer from my brother who got it from the street. He asked me to help to fix it.
                                          I need help on fixing this machine.
                                          Issues/Observations:
                                          1) When connected to power, it's not working. Only showing blinking screen on the LCD. See pics 1 and 2. It is blinking every 2 seconds.
                                          2) I pressed the buttons on the control panel to see if there is any response. The "Options" button can turn off the LCD screen, and then press hold the power button for about 1 second can turn the blinking screen back on again. Other than...
                                          10-19-2023, 10:32 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • ahoonid
                                          MacBook Pro A1398 L2013 weird jumping screen.
                                          by ahoonid
                                          Hey everyone.
                                          I have a 820-3787-06 board from a MBP A1398 which has a screen issue. The problem starts with a bit of noise just like old TVs when booting and when the OS is on, screen jumps are added to the little noise on the screen. The jumps are millisecond and go back to the original place.
                                          Since there's a little crack in the corner of the screen, I thought it has to be the display. But to my surprise it wasn't since I tried it with a fully functioning screen.
                                          The same issue isn't happening with an external display. I did a gpu/cpu stress test on external...
                                          02-07-2024, 05:56 AM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
