Vizio M470VSE turning off
  • tibimakai
    • Jan 2012
    • 3680
    I'm trying to repair my neighbors TV. It's a thin LED smart TV.
    TV can be turned on with the remote, or the side switch.
    It will turn on showing the Vizio V logo on the screen for a couple of seconds and then it turns off. Same goes to the Vizio logo in the bezel, turns white and while the screen is on, it will stay on. When the TV turns off, the logo will turn off too.
    I have measured all the voltages at the PS and all the voltages are OK, until the power shuts off.
    Just in case, I have tested all the heatsink mounted transistors, and diodes and they are not shorted.
    25V goes to the LED driver board.
    I have tested for shorted FETs and diodes on the LED driver board, they all seem fine.
    LEDs get 52V on both rails. I have tested all the test point going to the LEDs and they are all pretty much the same, 9.75-9.84V.
    I have opened up the screen, to look at the LEDs, all of them light up.
    Not sure what else can I check.
    It could be EEPROM problem? If it would be EEPROM, I would expect to find them for sale on some sites, but I haven't seen any for sale.
    Any input would be appreciated.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Vizio M470VSE turning off
    Nobody has any experience with these TVs?
    No ideas what to look for?
    • tibimakai
      • Jan 2012
      • 3680
      I have done some measurements and to my eye, they all look good, except some voltages on the LED driver board, which I don't know what they should be.
      Here they are:
      Power supply main connector:
      Power On= 3.3V
      AC_OFF_DET= 0.01V
      REG_12.5V= 12.46V
      BL_ON/OFF= 2.94V
      ERWM/IPWM= 1.64V
      Power Supply output to the LED Driver board:
      25V= 25.2V
      L_Det= 0.4V off
      L_Det= 0V on
      LED Driver board:
      Vcc= 5.01V
      V12= 12.03V
      PWM 1,2,3,4= 2.52V
      Fault= 2.5V on
      Fault= 0V off
      Test2= 0.8V
      Test2-out= 5V
      Test3= 0.002V
      BL_ON= 2.94V
      PDim= 1.64V
      PDim_2= 2.52V
      Output to LEDs:
      VLED1= 59.6V
      VLED2= 59.6V
      CsOUT1-7= 9.8V
      The only difference that I'm noticing is the test points differences. I can't find Test1. I remember when I have repaired my Sony 3D TV, the test point differences showed the problem, that it was the driver board.
      Could it be the same thing here too?
      You guys need a picture?
      I'm attaching a shopjimmy picture for now.
        • 31077
        try running it with the led driver unplugged.
        if it wont start, try removing just the "fault" wire.
        • tibimakai
          • Jan 2012
          • 3680
          I don't think there is a fault wire, those test points are on the PCB itself.
          I don't remember if I have tried it without LEDs, yet, but I will try it out.
          • tibimakai
            • Jan 2012
            • 3680
            Replaced the mainboard and it's working great.
              Hmm, that is strange since the voltages as posted looks normal.Did you check those voltages again to see if they are the same before?
              • tibimakai
                • Jan 2012
                • 3680
                It was my neighbor's TV and I had to rush with it, didn't have time to work on it.
                There also over 100 Deg. in my garage.
                In my opinion, it was an EEPROM problem.
                I have purchased the board to shopjimmy's confirmation. Sent an Email to them and they said, that it is a mainboard issue, what I'm describing.
                  That is very nice of SJ to give you the info.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I may try this, with my other TVs.
                    • blscurlock
                      • May 2014
                      I am having the exact same problem with this model. I have checked the ps and found it to be normal. I will replace the mainboard and post if it fixes this problem for me.
                      • howardc64
                        Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                        by howardc64
                        Problem
                        Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                        Model & Board Pics
                        Conflicting Spec
                        Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                        https://www.shopjimmy.com/vizio-gj-2k1...
                        10-10-2024, 01:16 PM
                      • osrex
                        LED DRIVER KEEPS DYING
                        by osrex
                        Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                        i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                        i have no datasheet at all for the LED lights, all i have is its length.
                        long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                        as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                        05-05-2025, 03:36 PM
                      • Pipolups
                        Corsair K70 LUX RGB dying LEDs
                        by Pipolups
                        Hi there !
                        I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                        Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                        10-08-2024, 11:58 AM
                      • charif
                        Audio Driver for Thomson P14C4BK128
                        by charif
                        Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                        I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                        The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                        Here are the details:
                        • Model: Thomson P14C4BK128
                        • Operating System: Windows 10 64-bit
                        If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                        Thanks in advance for your help!
                        04-30-2025, 05:41 PM
                      • bohaboha
                        how to install gl usb2.0 uvc camera device driver on windows 10
                        by bohaboha
                        Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                        but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                        any help?
                        01-26-2025, 08:33 PM
