The Swap-Shop Thread....
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    There's a fair few guys I see regularly on this Forum repairing TV sets and like them I have accumulated lots of boards and parts etc.
    --As part of my last job, Ive accumulated probably half a garage load of boards from LCD's and Plasmas, all sorts of makes/models...
    But--often don't have the board or part that I need for a specific repair....
    Sooo....
    My ideas was to start a thread listing my wants in a hope that you may have what I need and I have what you need, so we may swap.....
    My current needs are a Mainboard for a Panasonic TH-42PX80B
    And believe it or not, a Mainboard for a Panasonic TH-37PX80B
    --both have different faults, both I have failed to find.
    Both M.B's are TNPH0711.
    TELEFIX
  • SlickClick
    • May 2011
    • 91
    Re: The Swap-Shop Thread....
    I have 1 Good TNPH0800 Mainboard and one that is from an out-door unit so shows signs of surface rust...
    The other is from a TC-P42C2 that fell off the wall; it has a TNPH0831 but the coaxial connector is ripped off of it and I have removed that box from the board but still have it so it can be properly matched...
    Looking for a few power supplies and Z-sys boards for LG based plasmas...
    • SlickClick
      • May 2011
      • 91
      Looking For:
      Pioneer -AXY1059- PSU
      Vizio/LG -6870QZH004B- Z-Sys Board or STK795-820/821 or LG Compatible
      Fujitsu/Panasonic PSU -NPX563MD 1C-
      Zenith/LG -6870VM0424A- PFC Board or other compatible
      I have Panasonic parts I have 2 of each one set is out of a unit that got hit with a baseball the other had a good screen and what seems to have been an outdoors set; you will see in the photo of the SC board and the buffers together that there is some bad resistors and such and the buffers could be ok... this set of parts is for parts only and the other with the bad RF box is the only 1 i have and that is the issue with it... as photoed.
      • joehezzer
        • Jul 2012
        • 251
        • England
        i have a few bits will have a look tomorrow
          Got all the bits for a PS42B450 Samsung except the Y-buffer, X- and Y-main boards.
          I've also got a main A/V board for an LG plasma, 42PC1D but may work with other models.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Currently--off the top of me 'ed as it were.....
            I have all the internal boards for a Samsung PS-43C450.--Scrapped that on Saturday--broken PDP--Bloody thing looked new too!
            All boards for a Sams. PS-42C450--couple of sets of those....
            Boards from a Sams. PS-50C summit or other....
            G type Panasonic 42" and 50" sets--complete contents--various models, The ones with combined PSU/X-SUS and buffers/Y-SUS, from sets with broken PDP's...
            Got lots of nice goodies--All I want as swap for a board or two--Is a Mainboard or two suitable for me two Panasonic PX80 sets!
            So--IF anyone has a Mainboard,--TNPH0711 (I know there are a few variants--but I'll take a chance) Tell me what board you need, and I'll look through all my stuff.....
            --Chances are, I'll have summit, must have scrapped 500 odd sets over the last year or so.....
            ---Please however, bear in mind I'm in the UK, and shipping may be a deal-breaker, also I'm not into selling boards, Just swapsies at the moment......
            TELEFIX
            • sordids999
              • May 2013
              • 2149
              • uk
              hi guys looking for a EAX61531909(2) EBT61232821 main board for a Lg32ld490
              thanks
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Mainboard for a Sharp 32" wanted...
                LC-32GD8E 32" LCD TV, Board type--
                KD890 XD890WJN2 KD890WE06
                Seems I'm having a fair number of Mains these days giving me grief....
                TELEFIX
                  What's up with the Sharp main board? I think I've fixed one of those before...an easy fix.
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Fault is--
                    Turn on, green STDby light, stay on for 4-5 seconds, no Backlight, No BL-ON, No BL/Dim,
                    then relay click off at PSU, BL supply sinks down slowly from 24V.
                    Removing BL-on and BL-Dim from plug, shoving 4v up 'em, turn on set, get backlight instantly the 24V is there--until set shuts down again after 4-5 seconds.
                    The PS-On (1 and 2) both fall together at same time relay clicks.
                    The three voltage-regs on underside of M/B seem to perform as expected, pin 2 active and gives supply on pin 3 --until set turns off.....
                    One reg.--I think the 3.3V is active whether set on or off.
                    Disconnected the T-Con and the 'common-interface' boards-- no difference.
                    TELEFIX
                    • joehezzer
                      • Jul 2012
                      • 251
                      • England
                      • mintminty59
                        • May 2014
                        • 17
                        • wales
                        Alastair I have a 42 Inch Panasonic Vera Plasma with 10 LED Blins, its a complete TV with all boards and a good screen. Perhaps you can help with me 2 LG's
                        • mintminty59
                          • May 2014
                          • 17
                          • wales
                          Got model number its a TH-42PX60B
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            Ah--A PX60B, I know that chassis...
                            Those LG's you have, doubt there's any hope for 'em to be honest--Once the tabs fail or are damaged--thats basically it for em--unless you can pack them and get the connection back--But in your case, they are all corroded too.....
                            --Best you can do with 'em is sell off the parts TBH....
                            TELEFIX
                            • mintminty59
                              • May 2014
                              • 17
                              • wales
                              Alastair I would Like to chat to you, being as we are local to each other about TV's on one of the LG the conectors are ok, just some corroded resistors and a bad track. This is one I want to fix as its a 3d model. But a chat be nice as I am getting really into this and you seem a man in the know. Dont worry I am not after loads of free repair tips lol
                              That panasonic has been a bit of an pita. I got as far as taking out PSU to have a gander for soemthing obvious. As I am an electronic engineer by trade and I have worked mostly on projectors for myself and MOD for work.
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                With the corroded track--IF its on the flexible Mylar film between the board and the panel--thats basically the end of it.
                                If its on the PCB board--maybe it can be bridged out depending on your soldering skills and its size....
                                The resistors--well, thats another issue, Are they actually faulty or physically damaged? Being part of the panel--its often not possible to find the schematic to determine the values.
                                As to a chat--sure, give us a shout on the weekend.....
                                TELEFIX
                                • mintminty59
                                  • May 2014
                                  • 17
                                  • wales
                                  How do I get in touch , send me a PM
                                  • mintminty59
                                    • May 2014
                                    • 17
                                    • wales
                                    No the broken tracks are on the PCB between 2 resistors and a pad where a resistor was meant to go for a different configuration probably but was not installed. The resistors ends are corroded to the point there open circuit. If I put an iron on them they would probably turn to dust. I have the value of the resistor as its 1K (102) writen on it but the caps are a different kettle of fish.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Looking for a mainboard for a Samsung UN40C6300 and the joining plastic part between the stand's neck and the TV itself. There is only one mainboard on Ebay and it's $140 shipped.
                                      The board number is BN94-03366G or any of these are equivalent: BN94-03366N,
                                      BN94-03366B, BN94-03366K, BN94-03366Q, BN94-03366U, BN94-03366V, BN94-03366Y, BN94-04492B, BN94-04492C.
                                        You know it would be really neat if there was some way to organise this. I was thinking of two things, one thing is finding TV parts (so a TV parts search engine) and the other thing is trading TV parts. Users could submit what they have and what they want. I think money should stay out of it though; too many issues dealing with returns etc.
                                        Maybe when I get some time I'll implement them. Bit busy now with unrelated projects.
                                        • SACR
                                          Panasonic Plasma TH-P42X28K A-Board @ Mainboard Schematic needed
                                          by SACR
                                          I need Schematic A-Board @ Mainboard for Panasonic Plasma TH-P42X28K. Code : TNPH0842. I want to replace 1 MLCC but I don't know values (capacitance & voltage) & codes. Can someone help me? Thank you...
                                          11-20-2023, 11:53 PM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here๐Ÿค”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting ๐Ÿ˜‚.
                                          11-20-2024, 08:52 PM
                                        • rui4892
                                          panasonic TX-47AS650E solarized and mirror image after change mainboard.
                                          by rui4892
                                          hello everybody.
                                          my previous post disappeared, perhaps due to the server transition... but let's move on...
                                          I bought a similar board on ebay but this one is programmed for the 48FHD panel, my panel is 47FHD... in the service manual I can't find information on how to change it... or what to change... thank you.โ€‹
                                          11-27-2023, 04:48 AM
                                        • Mirenia
                                          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                          by Mirenia
                                          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                          I replaced it, but ever since, the touchscreen no longer works โ€” and honestly, Iโ€™m running out of ideasโ€ฆ
                                          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I havenโ€™t been able to determine under which circumstances this happens.
                                          The touchscreen also doesnโ€™t work in UEFI/BIOS, although itโ€™s enabled...
                                          03-30-2025, 06:47 AM
                                        • orcic
                                          MASTER TL240 and new mainboard LW36BKC01
                                          by orcic
                                          I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                                          The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                                          After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                                          Now I have some doubts about how to connect the new mainboard to the old power supply.
                                          First of...
                                          05-12-2023, 08:10 AM
