panasonic TX-47AS650E solarized and mirror image after change mainboard.
  • rui4892
    • Mar 2017
    • 57
    • Portugal
    hello everybody.
    my previous post disappeared, perhaps due to the server transition... but let's move on...
    I bought a similar board on ebay but this one is programmed for the 48FHD panel, my panel is 47FHD... in the service manual I can't find information on how to change it... or what to change... thank you.​
  • William1967
    • Nov 2017
    • 217
    • Netherlands
    Replace the eeprom on the mainboard with the eeprom from the defective mainboard, maybe it helps.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4542
      • Italy - Milan
      Yes , and after it make a service config reset
      • SACR
        Panasonic Plasma TH-P42X28K A-Board @ Mainboard Schematic needed
        by SACR
        I need Schematic A-Board @ Mainboard for Panasonic Plasma TH-P42X28K. Code : TNPH0842. I want to replace 1 MLCC but I don't know values (capacitance & voltage) & codes. Can someone help me? Thank you...
        11-20-2023, 11:53 PM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
        11-20-2024, 08:52 PM
      • Mirenia
        Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
        by Mirenia
        I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
        I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
        In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
        The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
        03-30-2025, 06:47 AM
      • orcic
        MASTER TL240 and new mainboard LW36BKC01
        by orcic
        I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
        The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
        After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
        Now I have some doubts about how to connect the new mainboard to the old power supply.
        First of...
        05-12-2023, 08:10 AM
