N3251w red light only no image
  • mmoore5553
    • Oct 2013
    • 171
    I got this monitor / LCd for free. It has an issue though. I have attached pictures. I have 81.4 volts on d8. I checked zd4 and it shows 704 with diode check. So i assume that is right as i checked other zenor diodes and shows the same. I then checked q7 and appears fine. I could not see any caps that are bubbled . Where do i go next ?
    I have a multimeter and ready to use it. I turn it on and it just shows a red light. All the caps look good.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4981
    • New Zealand
    Re: N3251w red light only no image
    I see one bulging capacitor. If the rest are the same brand they're probably all bad. Check\replace at least all the output capacitors.
    -David VanHorn
    • mmoore5553
      • Oct 2013
      • 171
      I seen that and did not know if it was budged or not. I can not even read what type of cap it is.
      • Fubar701
        • May 2014
        • 7
        Sorry to barge, trying to start a thread but it doesnt allow me to, seeing if I can even comment
        • Agent24
          I see dead caps
          • Oct 2007
          • 4981
          • New Zealand
          Desolder it and then read what it says. You'll have to anyway to replace it.
          -David VanHorn
          • mmoore5553
            • Oct 2013
            • 171
            I just order a kit with all of the caps in them. As you said i will have to replace them anyways.
            http://www.ebay.com/itm/230738469284
            • Agent24
              I see dead caps
              • Oct 2007
              • 4981
              • New Zealand
              That'll work too
              Just something to bear in mind in future, while that seller looks OK, and he says he uses good quality capacitors, some eBay sellers do not, or may use fakes (knowingly or unknowingly).
              -David VanHorn
                He is good, he is a friend of mine that I help out getting the good caps for the kits when he started the business.
                • mmoore5553
                  • Oct 2013
                  • 171
                  That is good to know Budm. Nice to see you around. Well i finally got the caps but took awhile. I replaced just that one as it looked buggered. I still have a red light and nothing on the screen. I do not here the transformer or anything trying to kick on. Not sure where to look at this point.
                  I am open to ideas.
                  Should i go ahead and replace the other caps then ?
                  • mmoore5553
                    • Oct 2013
                    • 171
                    I did find this on the web but I am confused on what to look for.
                    • mmoore5553
                      • Oct 2013
                      • 171
                      Also found this
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4981
                        • New Zealand
                        Do the whole kit and replace the lot, if one was visibly failed the rest are likely in bad condition even without visible signs of failure. If you don't have an ESR meter then you should just replace the lot. If it still doesn't work you can at least start troubleshooting knowing the capacitors are OK.
                        -David VanHorn
                        • mmoore5553
                          • Oct 2013
                          • 171
                          I have replaced all Caps and still in the same boat. Just red light when I plug it in.
                          • mmoore5553
                            • Oct 2013
                            • 171
                            Just wondering if anyone has any ideas what to check next. Thanks.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4981
                              • New Zealand
                              As this PSU seems to have APFC I think you can try budm's trick of checking voltage on the main filter capacitor.
                              Measure the voltage across this capacitor and then press the power button. If the voltage increases you know at least that the startup signal is getting through to the PSU and that the PFC circuit is working.
                              Post the voltages you get before and when pressing the button.
                              Be careful when doing this, since you're working on the hot side of the PSU which is connected to the mains. If you have alligator clips for your test leads, use them.
                              You should also probably check the 5v Standby rail to make sure it is actually supplying 5v.
                              -David VanHorn
                              • mmoore5553
                                • Oct 2013
                                • 171
                                I wish i had alligator clips for my multimeter. I will just use the leads. I assume you are talking about the big blue capacitor ? I was looking for the 5v standby and not sure where that is at on this board. Any advice ?
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4981
                                  • New Zealand
                                  Yes the big blue one lying on its side. The main filter cap is almost always the biggest one on the board, closest to where the mains supply comes in.
                                  Do the output connectors on the board have any markings next to them that might indicate which pins are for which voltages?
                                  -David VanHorn
                                  • mmoore5553
                                    • Oct 2013
                                    • 171
                                    I do not see any voltages listed at all yet. I do have 167 volts across the cap. I can not hit the button to turn it on. I plugin the power cord and tv goes directly to red light. I can not hit the button while it is laying down and me trying to hold leads on it.
                                    • mmoore5553
                                      • Oct 2013
                                      • 171
                                      Closer inspection I see it looks like these too are burnt ? It tests fine but not too sure. What do you all think
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4981
                                        • New Zealand
                                        Yeah those look bad alright. Q4 definitely and maybe D7 as well.
                                        Are you testing in-circuit? That is unlikely to give correct results. Desolder and test both out of circuit, likely they have both gone open circuit.
                                        167 volts while in standby sounds OK.
                                        -David VanHorn
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • learnmore
                                          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                          by learnmore
                                          Hello Community!
                                          CASE DETAILS
                                          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                          Tried inserting firmware on USB and left it in for a few hours, but no change
                                          03-03-2024, 09:49 AM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • usyusy
                                          H96 Pro Plus android TV box only shows blue light
                                          by usyusy
                                          H96 Pro Plus only shows blue light when connected to charger (tried a few even dc supply 5v), no powered-on and no display. However DC Supply showed 100mA or 110mA usage. any suggestion or clue from fellows will be appreciated.,.regards
                                          H96 Pro Plus
                                          CZ-S32-V3 (DDR4)
                                          2016-12-15(A15)...
                                          10-12-2023, 11:13 PM
                                          Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                          by sam_sam_sam
                                          I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                          I also have back when Light of America had these light bulbs available for yard lights
                                          The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                          While the Lithonia lighting fixture has all most certain bulb failure
                                          So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                          I have only had this light fixture for not more than a year if it...
                                          07-02-2023, 03:45 PM
