N3251w red light only no image
  • mmoore5553
    • Oct 2013
    • 171
    Re: N3251w red light only no image
    I was testing in circuit. They are bad. I am unsure how to find the correct part. i know I will probably replace all on that side. q4, d7 , and q3. How do i find out what part i need ?
      Is your board FSP212-3F01?
      If it is, it is known to have bad transistor and Zener diode.
      http://s807.photobucket.com/user/bud...tml?sort=3&o=1
      Unless I have bad eyes, the diode and the transistor do not look like it burnt up to me, if they are, that would have blown the main AC fuse.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5036
        • New Zealand
        I suspect you'll have to try reading the part numbers off the side of the devices. The schematic is useless in that respect and has no part numbers, unfortunately
        Unless you can find another TV that uses the same PSU and has a decent schematic. I have looked for another but can't find one so far.
        Going by http://s807.photobucket.com/user/bud...ml?sort=3&o=16 it looks like Q4 is an AP04N70BF
        You'll have to figure out D7 though. What does it say on it?
        -David VanHorn
          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:20 PM
        • learnmore
          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
          by learnmore
          Hello Community!
          CASE DETAILS
          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
          Tried inserting firmware on USB and left it in for a few hours, but no change
          03-03-2024, 09:49 AM
        • Jaime Morillo
          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
          by Jaime Morillo
          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
          The TV was stuck on the logo and I couldn't access the update menu.
          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
          The image result was good, but the image is inverted.
          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
          08-18-2025, 11:38 AM
        • usyusy
          H96 Pro Plus android TV box only shows blue light
          by usyusy
          H96 Pro Plus only shows blue light when connected to charger (tried a few even dc supply 5v), no powered-on and no display. However DC Supply showed 100mA or 110mA usage. any suggestion or clue from fellows will be appreciated.,.regards
          H96 Pro Plus
          CZ-S32-V3 (DDR4)
          2016-12-15(A15)...
          10-12-2023, 11:13 PM
          Lithonia Lighting versus Light of America Compact Fluorescent product quality
          I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
          I also have back when Light of America had these light bulbs available for yard lights
          The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
          While the Lithonia lighting fixture has all most certain bulb failure
          So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
          I have only had this light fixture for not more than a year if it...
          07-02-2023, 03:45 PM
