Memorex MLT3221 Red power LED pulsing
    I just purchased this TV. when power is applied I get a pulsing flash from the red power led. but the TV won't turn on. the person I purchased it from just replaced all of the caps. not sure where to go from here. what to test?
    Re: Memorex MLT3221 Red power LED pulsing
    Check D10 diode, this is the exact same power supply I have for a Polaroid 32".
    The first PS that was in the tv wouldn't turn on so I got a replacement ps that also end up failing after doing some research I found the first PS had a bad D10 diode.
    Also I replaced the Q16/Q17 N-channel transistors as they are notorious for going bad if the 10uf 450v caps have failed.
      I checked D10 in circuit and it checks out ok. low ohms one way and high the other way. how would I check Q16 /Q17. would I check them in circuit.
        I just noticed this on the bottom of the power board. not sure of this is normal or if someone made a modification.
          I was tested on the primary side and came across D7 the part number is HER207 it is testing low ohms both directions.
            so I have ordered a replacment diode. is there anything else I should test before installing new diode and connecting power to the tv?
              replaced D7 and still get the same results. the front led blinks red and tv won't turn on. I at the same time ordered a full working power supply and tested the tv with that and TV works. I would like to figure out what is bad on this board. no 5 volt standby.
                is it possible to take this power supply and run it with out the other boards. I would like to trouble shoot the 5volts missing.
                  If the +5VSTBY is not working, you can run the power supply board by itself since +5VSTBY is an always on power supply so you can troubleshoot that +5VSTBY without having the board connected to anything else. Or you are talking about +5V (swithced).
                    hello i noticed you tested Memorex MLT3221 power supply how would i check D10 in circuit . thank you
