LG 50PC3D Issue
    Re: LG 50PC3D Issue
    A small turn, forgot to mention, the best thing to do is run the TV while doing it looking in a mirror, looking for any changes in the picture. You can turn it on/off a lot of times but it gets extremely tedious.
      Re: LG 50PC3D Issue
      Nothing very noticable, definitely not "fixed".
      When adjusting the down, I could get some sparklies to show up. That's about all I could notice.
        Re: LG 50PC3D Issue
        Been messing with it more, nothing makes any difference other than the down.
        The lines, split screen, and pink are still present and don't really change when making adjustments.
          Re: LG 50PC3D Issue
          I'm sorry but I don't know what is causing your problem then. An oscilloscope would be necessary. My guess would be some fault with the Y-sustain but I'm not certain at all.
            Re: LG 50PC3D Issue
            Seeing as I just bought a YSUS off of ebay, would you recommend that I return it and get another one?
              Re: LG 50PC3D Issue
              The fault between your Y-SUS boards is the same?
                Re: LG 50PC3D Issue
                I'm not sure what you're asking.
                I was getting a black screen, could very faintly see the image, with black spots all over.
                Replaced YSUS with part from ebay, which resulted in the image you see in the original picture.
                I assumed it was buffers, as they are recommended to be replaced as well, but after installing the new buffers there is no noticeable change.
                  Re: LG 50PC3D Issue
                  You had an image with faint black spots? Like a warming up lava lamp? Normally, I would call that a Z-sustain fault.
                    Re: LG 50PC3D Issue
                    Well it is no longer an issue with this new YSUS board. From my understanding the ZSUS is related to backlight issues.
                    The screen was always "lit" up, it was lacking color would be a better description.
                      Re: LG 50PC3D Issue
                      The Z-sus can cause a variety of faults. Any chance you took a photo of the original fault?
                        Re: LG 50PC3D Issue
                        Unfortunately no I don't. Didn't even think about it until after I saw the lines and pink hahaa.
                        I do have the old board though. Would it be worth my time to put it back in?
                        On the same note, what would I be seeing if the buffers were bad?
                          Re: LG 50PC3D Issue
                          Bad buffers cause vertical lines repeating down the panel but with NO visible panel data; you have a visible image even if it is distorted. I think the Y-sustain is bad.
                            Re: LG 50PC3D Issue
                            How would you know there are vertical lines if there is nothing visible on screen?
                            I'm definitely seeing vertical lines, pink hue, and the split screen.
                            I'll go ahead and contact the ebay seller about returning or exchanging the YSUS.
                            Any thoughts on what's causing the split screen or pink? Are they related?
                              Re: LG 50PC3D Issue
                              This is what you have, right?
                              https://www.badcaps.net/forum/attach...7&d=1398479559
                              If you could not see the Mazda? logo, you would have bad buffers, but since you can, something else is wrong.
                              https://www.youtube.com/watch?v=jOUQ...direct=1&t=25s and
                              https://www.youtube.com/watch?v=OIDqrQGmngU
                              These older LG plasmas are nasty to debug.
                                Re: LG 50PC3D Issue
                                Well that's a bummer.
                                Sounds like I should go ahead and throw in the towel, try to minimize the cost damage.
                                Unless you have any other ideas?
                                The first folks to reply in this thread mention the control board, are you still feeling like that is not an issue here?
                                I'd really like to get this working, but if it's just gonna be running in circles and spending $, then maybe it's time to bail.
                                  Re: LG 50PC3D Issue
                                  The ebay seller is going to let me return the YSUS.
                                  He did not have any others to do an exchange, so I'll be getting my $ back minus shipping.
                                  Would you recommend that I try another YSUS? Or just move on?
                                    Re: LG 50PC3D Issue
                                    Any other thoughts here? I'm hesitant but ready to give up unless there is anything else I can try!
                                    Thanks so much for all of the help so far, I've learned so much!
                                      Re: LG 50PC3D Issue
                                      Sorry to keep bumping, just looking for opinions on whether I should call it quits with this TV or attempt anything else.
                                      I appreciate any ideas/thoughts!
                                        Re: LG 50PC3D Issue
                                        I don't have any good suggestions right now, sorry.
                                          Re: LG 50PC3D Issue
                                          Ok, no problem. I should be able to return the parts I've purchased and only be out the shipping costs.
                                          At least I learned a lot!!
                                          On a side note, do you have a brand or model that you strongly recommend when purchasing a used TV?
