LG 50PC3D Issue
    Re: LG 50PC3D Issue
    Do you have a Harbor freight near you? They have a usable DMM for about $4 most days... nothing special but will get the job done...
    • notatvrepairguy
      • Apr 2014
      • 40
      Re: LG 50PC3D Issue
      Doesn't sound familiar so I don't think so.
      I'm ok with the $20 Radioshack version if it will do the job. I might just return it after I'm done, hahahhaha.
      Do you need more info or anything to help me figure out what to test?
        Re: LG 50PC3D Issue
        Looks OK but note battery not included.
        • notatvrepairguy
          • Apr 2014
          • 40
          Re: LG 50PC3D Issue
          Noted! I'll bring some batteries home with me.
          Would you mind writing up a quick and dirty plan for what I'm testing and how to do it?
          Or do you have any references I can use?
          I'm not completely dumb when it comes to this stuff, just don't want to cause any damage or anything. I'm sure I can figure it out if you can get me pointed in the right direction.
          Thanks!
            Re: LG 50PC3D Issue
            Page 180 ~ 181
            Use DC 500V range, red probe in Volt/Ohm, black in COM of multimeter.
            • notatvrepairguy
              • Apr 2014
              • 40
              Re: LG 50PC3D Issue
              Ok thanks, that definitely helps me understand where I'll be testing.
              In regards to the actual testing, would you mind confirming what I'm thinking?
              You asked me to test the VScan, I assume this is the VSC ?
              I understand how to setup the meter, but where do I put each probe on the actual board?
              It looks like there are 2 VSC TP (test points?) in that photo.
              Do I put red probe on one TP and black to a ground on the frame or housing of the TV?
              Sorry for being so needy, just want to make sure I'm doing it right the first time!
              I'll be home in about 2 hours and will be able to get some results.
                Re: LG 50PC3D Issue
                You put the red or black on different ones, order doesn't matter for now, if you get a negative result just ignore that.
                VSC = Vscan on LGs.
                • notatvrepairguy
                  • Apr 2014
                  • 40
                  Re: LG 50PC3D Issue
                  Excellent, thank you again.
                  I'll report back with readings in a couple of hours.
                  Anything else I should check while I'm doing the VScan?
                  • notatvrepairguy
                    • Apr 2014
                    • 40
                    Re: LG 50PC3D Issue
                    Also, I found out we do have a Harbor Freights close to me!
                    They have this for $5, WITH batteries!
                    http://www.harborfreight.com/7-funct...ter-69096.html
                      Re: LG 50PC3D Issue
                      Yep that's what I'm talking about - it's an OK meter considering it's only $5.
                      • notatvrepairguy
                        • Apr 2014
                        • 40
                        Re: LG 50PC3D Issue
                        Ok! I'm pretty sure I did it right, and nobody/nothing got hurt!
                        I am getting readings at 113-115. You mentioned 150 should be a normal value, sounds like we're barking up the right tree!
                        What is your next recommendation? Thanks for all the help!
                          Re: LG 50PC3D Issue
                          150V is for a newer panel; can you check what your panel is rated?
                          It is written on the label: N.A. / -Vy / Vsc / N.A. / Vzbias
                          • notatvrepairguy
                            • Apr 2014
                            • 40
                            Re: LG 50PC3D Issue
                            I can't find a label that matches those exactly, but I did find this :
                            MODEL : PDP50X3####
                            Rating
                            Total Max Watt : 500W
                            Max Volt(---___) : 5.25V/61Va/200Vs
                            Max Amps : 4.0A/2.2A/2.0A
                            • notatvrepairguy
                              • Apr 2014
                              • 40
                              Re: LG 50PC3D Issue
                              Oddly enough there is a second label that's similar, and appears to be older by the looks of it.
                              MODEL : PDP50X3####
                              All Voltage : DC (---___) 5V
                              Va : 60V VS : 192V
                              120 / -200 / 120 / N.A / 93
                              Max Watt : 400W (Full White)
                                Re: LG 50PC3D Issue
                                Your Vscan is OK then.
                                Can you check -Vy too?
                                • notatvrepairguy
                                  • Apr 2014
                                  • 40
                                  Re: LG 50PC3D Issue
                                  (-)185-(-)187 on the -Vy
                                  • notatvrepairguy
                                    • Apr 2014
                                    • 40
                                    Re: LG 50PC3D Issue
                                    Not sure what else I can test, let me know if you have any other ideas.
                                      Re: LG 50PC3D Issue
                                      Can you see the points marked Vset_up or Vset_dn (adjustment points)
                                      Note original points down (a marker across the screw will help locate it) and then try adjusting Vset_dn then Vset_up - see if the picture changes.
                                      There is no "correct" setting - you can't test them with a DMM unfortunately.
                                      • notatvrepairguy
                                        • Apr 2014
                                        • 40
                                        Re: LG 50PC3D Issue
                                        I see them, and marked them.
                                        How much adjustment should I be trying?
                                        Baby steps? Quarter turn? Half turn?
                                        What should I expect from up or down?
                                        • notatvrepairguy
                                          • Apr 2014
                                          • 40
                                          Re: LG 50PC3D Issue
                                          Also, should I be making these adjustments while the set is powered on, or off?
                                          • rounin
                                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                            by rounin
                                            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                            🛠 Original Issue
                                            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                            04-19-2025, 01:18 AM
                                          • ugamazing
                                            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                            by ugamazing
                                            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                            12-17-2024, 07:05 PM
                                          • shahnld
                                            Lenovo legion 5 pro startup issue
                                            by shahnld
                                            Good day Experts
                                            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                            08-24-2025, 12:31 PM
                                          • ahmarzo
                                            Acer laptop battery draining issue
                                            by ahmarzo
                                            Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                            Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                            08-02-2025, 06:39 AM
                                          • elmark
                                            HP 15-cw1002ua strange keyboard issue
                                            by elmark
                                            HP Pavilion 15-CW1002UA
                                            S/N 5CD0251CBC
                                            P/N 7KE54EA
                                            Hello guys!
                                            I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                            It powers on OK and has no other issues except the following:
                                            • CAPS LOCK does not work at all
                                            • Fn button toggles Flight Mode
                                            • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                            • (with SHIFT pressed: 't%' and 'y^' respectively)
                                            I initially thought it was a keyboard malfunction (internal short, etc.),
                                            but when I press and hold...
                                            06-27-2025, 01:10 AM
