LG 50PC3D Issue
    Re: LG 50PC3D Issue
    Panasonic PZ80. FHD 1080p, 2008 models, 42" 46" 50" and 58". One very common issue - and very easily fixed. Otherwise fantastic TVs.
    • notatvrepairguy
      • Apr 2014
      • 40
      Re: LG 50PC3D Issue
      Quick update, not sure if it matters at this point though.
      I undid all of the repairs I've done on this TV as I'm going to return the parts I bought.
      I also wanted to see what the original problem was, and see if I was even on the right path.
      So, the photo on my first post shows the results of a new YSUS and both YDRV/Buffers.
      With the old YSUS and old buffers I'm seeing a black/white image that flickers.
      Audio works.
      I have it laying down so I can't really get a idea of full screen image, just the edge I have hanging off the table.
      No color at all. Doesn't appear to be split screen. The lines "might" still be there, but they aren't moving nearly as much or at all.
      Any last ditch ideas? Maybe I was replacing all the wrong parts?
      I checked the voltages on the YSUS, they are very close to the new one I tested yesterday.
      • notatvrepairguy
        • Apr 2014
        • 40
        Re: LG 50PC3D Issue
        Just wanted to say thanks again for all of the help on this.
        I'm going to return these parts and see if I can sell the TV for parts.
        • audiofreak19
          • Apr 2013
          • 556
          • usa
          #64
          Re: LG 50PC3D Issue
          Hey notatvrepairguy. I would try the main logic control board. I wanna say I have seen somewhere on here where someone had a very similar issue and it was the main logic control board. But I saw your post about not having color when you out the old boards back in and it might be a combination of the y sus being bad and the logic board. I would as a last chance get the logic board while you still have the y sus and try both of them together. At least the logic wasn't expensive so you won't be out a lot if it doesn't work.
          • notatvrepairguy
            • Apr 2014
            • 40
            Re: LG 50PC3D Issue
            Thanks for chipping in, but I'm ready to give up on this one. It's an 8 year old set, and as much fun as it was to try these repairs I'm done throwing $ and parts at it. Knowing my luck the next board is gonna fail in a week or two and I'll just be running circles around it.
            I'll see if I can get $50 for it as a parts TV!
            • audiofreak19
              • Apr 2013
              • 556
              • usa
              #66
              Re: LG 50PC3D Issue
              That's cool. You should have no problem getting that for it.
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                🛠 Original Issue
                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                by ugamazing
                I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                12-17-2024, 07:05 PM
              • elmark
                HP 15-cw1002ua strange keyboard issue
                by elmark
                HP Pavilion 15-CW1002UA
                S/N 5CD0251CBC
                P/N 7KE54EA
                Hello guys!
                I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                It powers on OK and has no other issues except the following:
                • CAPS LOCK does not work at all
                • Fn button toggles Flight Mode
                • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                • (with SHIFT pressed: 't%' and 'y^' respectively)
                I initially thought it was a keyboard malfunction (internal short, etc.),
                but when I press and hold...
                06-27-2025, 01:10 AM
              • Simone Vergani
                Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                by Simone Vergani
                I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                To assist with troubleshooting, I'm attaching two power circuit schematics:
                • Power
                03-05-2025, 02:25 PM
              • wizard13
                Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                by wizard13
                I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                I have checked the forum and the available documentation but could not find a solution specific to my issue.
                • Brand & Model: Dynabook Satellite Pro C50D-B-100
                • Part Number (P/N): PYU13E-00C00PFR
                • Serial Number (S/N): 22028896H
                • System Configuration (SC): A1PYU13E1127
                • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                • Power Input: DC 19V –
                02-28-2025, 02:43 AM
