Panasonic TC-P50S2 Snowy Picture
  • rlhowelljr
    • Apr 2014
    • 30
    Re: Panasonic TC-P50S2 Snowy Picture
    Yes the new board will probably be the best solution as my soldering skills are not the best and will be unable to obtain an oscilloscope. Do you know a good place to get a new board will be? Will there be any adjustments to make after changing the board or will simply swapping for a new one be sufficient?
      With a modern Panasonic panel such as this, simply locating a 50" series 2 board (TC-P50G2, TC-P50V2, TC-P50S2) with the same part number and suffix should be OK. You need to avoid getting a 3D board (TC-P50VT25 comes to mind) or a 25 series board as it will likely be different. Also you can't use a 42",46",58",65" board without considerable modifications, so best to avoid those.
      • rlhowelljr
        • Apr 2014
        • 30
        Thank you for all of your help tom66. I will try to locate a replacement board.
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          Did you try and look for a cold solder joint?
          Proud owner of dozens of broken TV's and many,many,many boards.
          Our website and passion:http://hollenhundshepherds.com/
          • rlhowelljr
            • Apr 2014
            • 30
            There are a couple of part numbers on the board. Can you tell me which to use? Also, where can I find the prefix? I think it is a TNPA5105 but no prefix.
            • tw2005
              • Oct 2011
              • 6458
              The first shot is the SC board.
              The second is of the SU board bolted/connected to the SC board.
              Could be a very hard board to source.
              TXNSC1LQUU, TNPA5105AB
              Panasonic
              TC-P50S2 TC-P50U2, TX-P50S20B, TX-P50U20B
              Edit: TXNSC11FEK50 is another part number.
                I'm pretty sure the C2 is no go due to being 720p panel?
                Can try some diagnosis there is a schematic, I am thinking it is the init-field FET that is not being driven correctly, best to have a scope but can see what is possible with a multimeter.
                • tw2005
                  • Oct 2011
                  • 6458
                  Fixed. Cheers
                  Should have picked that, copy/paste straight from SJ without checking they had it correct, which obviously they don't.
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    #29
                    I can check Monday when I'm back from dog seminar. I might have that board.
                    • rlhowelljr
                      • Apr 2014
                      • 30
                      Checked online and can only find a repair kit for that board. The kit says it is for most problems with the SC board but lists blinking fault codes which mine did not have.
                      could this work?
                      "The Panasonic TXNSC1LQUU SC Board Component Repair Kit includes all necessary components to repair common failures on the main SC board. Symptoms include will not turn on and power light will blink 4, 5 or 7 times."
                      Specifications: Kit Includes
                      Description Quantity Board Location
                      Transistors 8 Included With Kit
                      Resistors 3 Included With Kit
                      Diodes 1 Included With Kit
                      Integrated Circuits 1 Included With Kit
                        That will probably not fix this problem unfortunately.
                        • rlhowelljr
                          • Apr 2014
                          • 30
                          this board seems pretty tough to get for a TV that is less than 4 years old.
                            It's a common failure and Panasonic panels are sold in lesser numbers and are more resilient to being broken unlike Samsung panels so it's rarer to find a cracked one for parts use.
                            • rlhowelljr
                              • Apr 2014
                              • 30
                              I am going to try to call Panasonic tomorrow to see if they will sell me the board. Not sure if i will have any luck with them since i am not an "authorized repair center"
                                You can often buy the board through something like Sears or a parts distributor but you would be looking at a stupid price ($300+) in most cases.
                                • rlhowelljr
                                  • Apr 2014
                                  • 30
                                  well that would not help for little more I can buy a new TV.
                                    Hence why I call it a stupid price, I really do not know how these companies sell any boards at those prices. Maybe to warranty companies only.
                                      • 31289
                                      the snow is probably a bad cap letting ripple/noise into the processing circuits.
                                      i'd replace all the small electrolytics - if that dont fix it, try the large ones.
                                        There is probably a small lytic around the set-up ramp generator responsible for setting the ramp timing, or a ceramic cap. For a failure that would be my bet but locating it could be hard without a scope.
                                        • rlhowelljr
                                          • Apr 2014
                                          • 30
                                          Checked on the sears site they list a RFR-PTS-164 as a substitution but does not list a price. will check with them tomorrow also.
                                          • FZG
                                            Panasonic AG-1000B VHS player with bad picture quality
                                            by FZG
                                            Hello!
                                            I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                            Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                            I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                            Also, what mechanism is this?
                                            Any feedback is appreciated!...
                                            05-06-2024, 07:16 AM
                                          • Bazfletch3
                                            Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                            by Bazfletch3
                                            Hi all
                                            While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                            I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                            From there I envisaged that the backlighting wasn't working, however...
                                            01-08-2024, 10:18 PM
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • mar1in
                                            Panasonic TH-55AS670A no picture no sound
                                            by mar1in
                                            I've got this Panasonic TV here with the following symptoms:
                                            * Standby Light is solid RED
                                            * Turning on using the Button on the TV (long press) would change LED to blinking GREEN
                                            * After a couple of seconds, LED is solid GREEN and without picture or sound.
                                            I've tried a couple of things before tearing it apart:
                                            * Resetting using various combinations of powerbutton and volume buttons pressing down while booting.
                                            * Activating Self Check according to service manual using IR Blaster (we have no remote unfortunately)...
                                            09-10-2023, 11:10 PM
