LG 42 g3000 white screen
  • fraz101
    • Apr 2014
    • 12
    • uk
    Hi I have a LG 42 G3000 with a fault.
    When I switch the tv on I get a white screen,the audio remains perfect.
    If I tilt the tv back and forth or leave it switched on for 10 minutes the screen normally rectifies itself.
    I have removed the back cover and removed the T Con board to check the ribbon connections,re fitted it and the fault remains.
    Anyone help me out?
    Re: LG 42 g3000 white screen
    42LG3000 or 42PG3000? Entirely different models! One LCD one plasma.
    • fraz101
      • Apr 2014
      • 12
      • uk
      42 LG3000 Lcd
      • Glitcher
        • Mar 2013
        • 673
        • USa
        Does sound like tab bond problems
        • fraz101
          • Apr 2014
          • 12
          • uk
          Could you explain how I'd go about checking/repairing that!?
          • fraz101
            • Apr 2014
            • 12
            • uk
            anyone?
            • anotherdude
              • Feb 2013
              • 488
              • uk
              a search in the forum will show plenty of threads on this, you basically need to do a diy fix on the top of the tab bonds, sometimes it works sometimes it doesn't
              you'll need to remove the lcd front frame too to access the tabs
              • fraz101
                • Apr 2014
                • 12
                • uk
                Is it more likely to be a tab bond problem as opposed to T Con board?
                • anotherdude
                  • Feb 2013
                  • 488
                  • uk
                  be easier than us guessing for you to just test the tab bonds, but as you're leaving it to warm up it will be tab bonds IMO
                  • fraz101
                    • Apr 2014
                    • 12
                    • uk
                    Thanks man, just new on here.
                    I'll have a search on how to test/check tab bonds then.
                    • fraz101
                      • Apr 2014
                      • 12
                      • uk
                      Just to add, this is the fault i'm experiencing
                      https://www.youtube.com/watch?v=Zcd5jz36nN8
                      • fraz101
                        • Apr 2014
                        • 12
                        • uk
                        Has anyone else had this fault and repaired successfully?
                        • fraz101
                          • Apr 2014
                          • 12
                          • uk
                          Just to update
                          The fault was with the left hand corner tab bond.
                          • anotherdude
                            • Feb 2013
                            • 488
                            • uk
                            Just to update
                            so it's fixed?
                            • fraz101
                              • Apr 2014
                              • 12
                              • uk
                              Yes
                              • Braderz
                                • Sep 2018
                                • 19
                                Sorry to re-hash an old thread, but can you explain how you fixed this? I have the same problem, and I believe it to be the top left board, as with a minimal amount of pressure applied the picture goes perfect. It's a TV I previously Gave up on but recently came across the exact same TV with a cracked screen so went for a screen swap tonight, and I'm being led to the same issue.
                                • ducky29
                                  • Dec 2015
                                  • 369
                                  • Europe
                                  Check top left tab
                                  • Braderz
                                    • Sep 2018
                                    • 19
                                    Originally posted by ducky29
                                    Check top left tab
                                    I have, it's definitely at fault. But how do I repair it? It seems to have bowed slightly, and when you press it it helps, but is there a permenant fix?
                                    • ducky29
                                      • Dec 2015
                                      • 369
                                      • Europe
                                      It is really tricky fixing it, check tab bond guides. There are plenty on youtube. You basically place a little piece of rubber between the metal frame and the tabs on the screen.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        https://www.badcaps.net/forum/showth...msung+tab+bond
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • EazyBone
                                          Sharp LC-65Q620U White Screen
                                          by EazyBone
                                          Another TV topic!!
                                          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                          08-21-2024, 12:56 PM
                                        • hcinne
                                          Dell G15 ryzen edition black screen 2 amber 1 white
                                          by hcinne
                                          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                          07-23-2024, 07:56 AM
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
