Sharp LC-52LE640U - DET_PNL12V failure
  • Baldrick
    • Apr 2014
    • 19
    Hi all...
    I've got myself the above mentioned TV and the 'V' is flashing 2 slow/5 fast which supposedly means 'DET_PNL12V failure'. The TV shows zero signs of life aside from the flashing 'V'.
    I've disconnected everything but the 120v from the power supply and used my Fluke to check the pins on the 24-pin connector. I'm only seeing 5v on one pin. That's it.
    From what I've gathered, I need to put a load on it by using 1157 bulbs. Is there a good description somewhere describing how to do this? I see no bulging caps or other signs of failure.
    If anyone can point me in good direction from here, I'd be grateful.
    Thanks.
  • niko1969
    • Oct 2013
    • 3
    • usa
    Re: Sharp LC-52LE640U - DET_PNL12V failure
    Power supply error 2 (*2) D+3.3V error.Most likely you have a problem with hdmi.Check IC1504 and Q1508
    • rswest
      • Aug 2014
      Did you ever find a solution to this problem? My LC-70LE650U does the same thing. Thanks.
      • R_J
        • 9633
        Try disconnecting the 2 ribbon cables from the panel to the T-con board, then power on the tv, It could have a damaged panel.
        • Snwboardr9876
          • Mar 2015
          • 15
          Sorry to bring back such an old post but I have the same exact situation as baldrick. All my voltages are good for a few seconds when first trying to power on then they all disappear except for standby 5 volts and then my standby light flashes 2 slow/5 fast.
          Any luck on a repair or diagnosis?
          • freakaftr8
            • Oct 2012
            • 3743
            Start with what R-J mentioned above your post first.
            Sharp sets like to throw this error when a shorted or cracked panel is sensed.
            • Snwboardr9876
              • Mar 2015
              • 15
              Tried disconnecting one at a time and powering on but still end up with the same outcome. Also same outcome with both ribbons disconnected. Also should mention no bulging caps.
                The panel_12V sounds like the T-CON is not getting the 12V to run.
                Did you check the SMD fuse on the T-CON to see if it is OK and have 12VDC on both ends of the fuse?
                Pictures of the whole back side of the TV that shows all the boards will help.
                • Snwboardr9876
                  • Mar 2015
                  • 15
                  Thanks for the replies guys.
                  That definitely makes sense, I was trying to find a fuse for the T con board but couldn't locate it and I can't find any diagrams online either.
                  These are the best pictures of the boards I could find online. When I get home from work ill take better pictures and one of the whole TV so it shows how they're all connected. I can tell you that other than the main Ribbon wire there's another wire that runs from the board with the component jacks and HDMI ports to the T con board. Would that be the power for it? Like I said ill post better pictures when I get home from work but here's a couple for now.
                  [/URL][/IMG]
                  [/URL][/IMG]
                  [/URL][/IMG]
                    So are you getting 12VDC at connector PD pin 1 and 2.
                    Report the DCV reading of each pin of the connector PD when TV is off and when power switch is activated.
                    Pictures are provided by SHOPJIMMY.
                      Also check the command DCV signal for the PANEL_PWR pin 16 to see if it is present.
                      It looks like Q7120 is the switch transistor that is switched on to supply the 12V panel when PANEL_PWR command signal is present.
                      • Snwboardr9876
                        • Mar 2015
                        • 15
                        Here are pictures of the entire TV as promised...
                        [/URL][/IMG]
                        Okay so I have to admit I'm fairly new to electronics of this sort but I'm an electrician so I'm very teachable.
                        That being said, I'm unsure of how the pins are laid out. I'm guessing if I'm staring at the board that the odd numbers are closer to me? So it's like 1&2 are parallel to each other and then 3&4 and so on? Does it go from the bottom to top or top to bottom?
                        That being said how do I test the pins closer to the board on the inside? The outside pins have the metal that I can touch with my lead but I can't get to the inside ones. And when I disconnect the connector I lose power so I can't test that way I guess.
                          The exposed pins that you can see from the top side of the board are the ODD number pins row,
                          the EVEN number pins row you will have to get to it from the bottom side of the board.
                          Since you can easily get access to pin1 (is also tied to pin 2) to verify if the 12Vdc is present or not first then we can go from there once I see your reading on pin1, black probe of the meter connected to the metal chassis of the TV with TV power switch activated.
                          • Snwboardr9876
                            • Mar 2015
                            • 15
                            Gotcha, okay that's how I figured it went. I have 12V at pin 1 when I hit the power button. Then once the standby light starts flashing I lose it.
                              OK, so the main board does send Panel POWER on signal to turn on the Q7120 to put out 12V to feed the PANEL 12V output pin 1 and pin 2.
                              So now you need to find out if the 12VDC is present at both ends of the SMD fuse with (ref to chassis GND) on the T-CON board.
                              Your picture of the T-CON board is way to blur for me to see the parts clearly.
                              • Snwboardr9876
                                • Mar 2015
                                • 15
                                [/URL][/IMG]
                                • Snwboardr9876
                                  • Mar 2015
                                  • 15
                                  Are these the SMD fuses you're talking about? If so, when I hit the power button I have 12V at the top of the one with a red arrow but nothing at the bottom. Ofcourse I lose the 12V once the standby light starts flashing. I have no continuity on either the fuse with the red arrow and also the blue arrow but I do have continuity on the one in between them.
                                  [/URL][/IMG]
                                    FB4801 is Ferrite Bead inductor.
                                    Some question, see the pictures.
                                    • Snwboardr9876
                                      • Mar 2015
                                      • 15
                                      And the other two with the arrows I drew? If either of them are not the fuses you were talking about then where is it?
                                        See updated post 18.
                                        • npielawski
                                          MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                          by npielawski
                                          I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                          I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                          10-15-2025, 01:53 AM
                                        • puccovelli
                                          Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
                                          by puccovelli
                                          Hi all, I hope this is the right place to post.
                                          I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
                                          I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
                                          1] Could someone confirm what the component that has blow actually is (and where I could get another from).
                                          2] Whether this component is likely to cause the RAM failure issue, and if replacing...
                                          10-11-2025, 06:30 AM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
