Sony KDL55EX720 won't turn on
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony KDL55EX720 won't turn on
    That one it was a 46EX400.
    You are suspecting a mainboard also?
    I will try to power the T-Con too and see what will happen.
    I would like to be sure, that the panel is OK, before I would purchase a mainboard.
    I was told, that the TV has a 5 blink error code and actually it was completely dead, something sounds fishy here. Maybe the TV technician did something to it before he returned the TV? The switch/IR sensor/LED board was disconnected from the mainboard when I opened the TV. I'm wondering why?
      If someone worked on it before you, then you really have to look real close at everything to make sure all the wires and connectors are back in place, no bad solder joints/bridge, etc. Something was done that caused it to be dead instead of seeing the original symptom of 5x error code.
      • tibimakai
        • Jan 2012
        • 3680
        The owner of the TV, took it at a repair shop, most likely to evaluate the problem, I don't think they really did much to it. They said, that it will cost him $350 and he did not want to repair it, so he sold it.
        Do you think that the 4.4V standby voltage can not cause any issues? It suppose to be 3.3V.
        Another thing is, that the LED doesn't even turn on, that is controlled by the mainboard, no? That could be another sign, that the mainboard has some issues.
        Maybe the technician swapped out the mainboard with a bad one and that is why it doesn't show the original problem. Just a thought.
          • 31187
          i suspect you have a shorted diode or voltage regulator.
            It's plausible if the 4.4V is too high for a 3.3V standby it's damaged the main board.
            • tibimakai
              • Jan 2012
              • 3680
              At the diode at the standby transformer, the voltage is 4.27V, but at the output of the NJM2884U1-33 is the same thing. With everything connected, it shows 4.4V.
                • 31187
                that NJM2884U1-33 is probably shorted.
                http://www.datasheetdir.com/NJM2884U1-33+LDO-Regulators
                  Yes I've had a shorted regulator before. And in my case 5V shorted to 3.3V and damaged the CPU, so I needed new main board.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    So, I will order a new VDO and see what will happen after that, but most likely I will need another mainboard.
                    Thank you guys, I will let you know the outcome.
                    2nd 3D TV!
                      Missed a 42" LG 3D plasma for auction recently. I've not done one yet, I want to see what all the fuss is about.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        For this one I paid the most, $180 without stand and remote. I had to drive 80 miles too, one way. It's very slow this business. I'm picking up Kenwood double dins, home theater receivers, monitors.
                        I had a nice 46" Samsung D series 3D, but the panel it was shorted at one side.
                        Stay away from the D series, to many problems with the panels.
                          • 31187
                          i wouldnt touch plasma's
                          i'v seen too many samsung ones that have a chain reaction taking out several panels when the screen fails or gets smashed.
                            I've just finished my 7th Panasonic plasma.
                            PZ80 (this one was a PZ85), these are AWESOME sets. And one very, very common issue which takes about an hour to fix. (10 blinks / 2 blinks MC module fault.) Picture quality - awesome. So, so bright, brighter than an LED TV, whilst having great overall performance.
                            Older Samsungs such as C96,97/Q96,97 etc, agreed, chain reaction, so I only get those free or very, very cheap. I got one free and fixed it, but it had sparklies all over the screen, which isn't fixable on older Samsungs.
                            The newer plasmas though aren't too bad, especially LG & Samsung, where the parts are available and fixes are reasonably easy. Just fixed a 42" LG PQ3000, bad PSU FETs, and a 42" LG PG3000 with blown upper buffer. Both cost less than £20 to fix.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              How could I turn on the LEDs?
                              Here is the G8 board, which seems like it's a secondary power supply feeding the LED driver board.
                              http://www.shopjimmy.com/sony-1-474-302-11-g8-board.htm
                              I would like to see the screen, that it's OK, before I would order the mainboard.
                                • 31187
                                led's?
                                if you mean the tubes,
                                you need to have 12v going into the invertor,
                                then just put 3-5v on the p-on / lamp pin.
                                why? just getting the lights on wont tell you if the panel is bad.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Yes Leds, this is a thin 3D TV.
                                    • 31187
                                    well same thing,
                                    you need power to the led driver board,
                                    and a "power-on" signal.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      That is my question, how do you do it on this TV? It's bit different, then other TVs that I have worked on.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Any ideas on how to turn on the LEDs?
                                        I'm attaching the pictures from shopjimmy.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          Bud, I have applied 3.3V at the T-Con_On and it turned on.
                                          All the right voltages are at the G8(small PS), but at the output connector, there is no LED_VCC.
                                          There are two pairs of diodes, at the output of the transformer and I'm not getting any voltage there.
                                          There is a LED_On pin there, but I don't understand what should I do with that?
                                          I have applied 3.3V, but the LED_VCC did not turn on.
                                          Pictures are just for reference only, they are not clear enough.
                                          At G8 board at connector CN6601 there is 12.71V, at CN6600 there is 391V, at CN6701 there is Reg_12V= 12.71V, BL_Err= 0.003V and ACC_OFF_DET= 4.4V.
                                          Any help would be appreciated.
                                          • Abel Bejan
                                            Sony Vaio does not turn on, overheats
                                            by Abel Bejan
                                            I am quite noob in advanced electronics, however I'm trying to fix a Sony Vaio PCG-71211M laptop mainly because I love old hardware. I don't want to send it to a technician because this computer is not important for me, I want to fix it as a hobby.
                                            Shortly, this laptop does not display any video output when turned on, no POST, nothing. The keyboard leds are on and I can actually turn Num Locks on and off. Sometimes the laptop turns itself off straight away, sometimes, mostly after some attempts, the laptops enters a loop in which the cpu fan spins very aggressively and the CPU,...
                                            01-11-2025, 10:11 AM
                                          • odie34
                                            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                            by odie34
                                            I am a hobbyist (not a professional) so please be gentle...
                                            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                            02-18-2024, 09:11 AM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • Zetabeta87
                                            Sony KD-49XF809y doesn't turn on
                                            by Zetabeta87
                                            Hi everyone!
                                            I have a 2018 Sony kd 49XF8096 that suddenly stopped turning on: No LED lights up, and it doesn't respond to the power button or the remote control.
                                            The power supply delivers 19.45vand I simply tried to check the fuses on the 2 boards (power and main) but everything seems ok. I have no references on where to test the voltage, but somewhere on the mainboard I also detect some, so you can't to understand which card may be to blame.
                                            Can anyone give me some advice? I haven't found anything online
                                            Thanks so much!!!
                                            11-04-2024, 03:18 PM
                                          • Highvoltagerchelie
                                            Sony XBR-65Z9D won't turn on after lighting strike
                                            by Highvoltagerchelie
                                            Good afternoon. I found this forum as I was looking for troubleshooting information for my Sony z9d. A lightning strike hit very close to the house and did nearly $30,000 in electronics damage. The TV appears completely dead with no status light and no picture. I found the Sony XBR-65Z9D service manual and followed the troubleshooting steps on Pages 21-26. All checks seem normal except DC_OFF_DET check on Page 23 R420 voltage was slightly higher than 3V. It was 3.475V and C418 was slightly higher that the 5V at 5.3V.
                                            I proceeded to check the Power Board CN6401 connector. With all...
                                            View and Download Sony XBR-65Z9D service manual online. GN2TR CHASSIS. XBR-65Z9D lcd tv pdf manual download.
                                            11-30-2023, 04:49 PM
