Sony KDL55EX720 won't turn on
  • Abel Bejan
    Sony Vaio does not turn on, overheats
    by Abel Bejan
    I am quite noob in advanced electronics, however I'm trying to fix a Sony Vaio PCG-71211M laptop mainly because I love old hardware. I don't want to send it to a technician because this computer is not important for me, I want to fix it as a hobby.
    Shortly, this laptop does not display any video output when turned on, no POST, nothing. The keyboard leds are on and I can actually turn Num Locks on and off. Sometimes the laptop turns itself off straight away, sometimes, mostly after some attempts, the laptops enters a loop in which the cpu fan spins very aggressively and the CPU,...
    01-11-2025, 10:11 AM
  • odie34
    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
    by odie34
    I am a hobbyist (not a professional) so please be gentle...
    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
    02-18-2024, 09:11 AM
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • Zetabeta87
    Sony KD-49XF809y doesn't turn on
    by Zetabeta87
    Hi everyone!
    I have a 2018 Sony kd 49XF8096 that suddenly stopped turning on: No LED lights up, and it doesn't respond to the power button or the remote control.
    The power supply delivers 19.45vand I simply tried to check the fuses on the 2 boards (power and main) but everything seems ok. I have no references on where to test the voltage, but somewhere on the mainboard I also detect some, so you can't to understand which card may be to blame.
    Can anyone give me some advice? I haven't found anything online
    Thanks so much!!!
    11-04-2024, 03:18 PM
  • Highvoltagerchelie
    Sony XBR-65Z9D won't turn on after lighting strike
    by Highvoltagerchelie
    Good afternoon. I found this forum as I was looking for troubleshooting information for my Sony z9d. A lightning strike hit very close to the house and did nearly $30,000 in electronics damage. The TV appears completely dead with no status light and no picture. I found the Sony XBR-65Z9D service manual and followed the troubleshooting steps on Pages 21-26. All checks seem normal except DC_OFF_DET check on Page 23 R420 voltage was slightly higher than 3V. It was 3.475V and C418 was slightly higher that the 5V at 5.3V.
    I proceeded to check the Power Board CN6401 connector. With all...
    View and Download Sony XBR-65Z9D service manual online. GN2TR CHASSIS. XBR-65Z9D lcd tv pdf manual download.
    11-30-2023, 04:49 PM
