non brandedset just says 32 lcd ut3219a
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    hi guys just picked one of these sets up now its been worked on before as in the psu a 17pw26.4 has 3 parts removed the seller comfirmed this basically its the f8oo 3.15 amp cylindrical fuse and th1 and th2 thermistors i gather is there a scheme so i can locate the missing items also is there anything else on these psus that cause these 3 parts to blow cheers guys.
    Re: non brandedset just says 32 lcd ut3219a
    SCH
    Pretty typical is Q813/Q814 to blow.
    If blown also replace: R860, R861, R864, R865, D891, D892, D875 -or- D894 (depending on which is present) and IC830.
    Q803 can also be bad, so check that part.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      spot on tom q814 mdf9n50 q813 mdf9n50 the fuse 3.15 clindrical plus the 2 thermistors ntc 10 0911 thats all i can read on these as blown ic830 fan 7711 can you help me on cpc site tom to find correct parts i thind it hard the best of times cheers vince.
      all the resistor are as per there markings and test ok surface mount diodes not fitted.
        As Vestel love to swap around the parts they use without changing the part # of the board please confirm your set uses the same as on the schematic, especially for the little resistors.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          so far the q814 q813 both are MDF9N50 IC 830 FAN 7711 R860 SAYS 330 ON IT TESTS OK R864 SAYS 103 TESTS OK R861 SAYS 330 TEST OK R865 SAYS 103 TESTS OK not sure how to test fan 7711 may be its ok? the part numbers from the blown thermistors i took of the faulty ones also of the blown transistors also need the fuse as well
            I would always replace all the components indicated, you cannot be sure if they are OK or not.
            Q814,815:
            http://cpc.farnell.com/stmicroelectr...0fp/dp/SC13028
            R860,861:
            http://cpc.farnell.com/_/mc-0-1w-080...20This%20Range
            R864,865:
            http://cpc.farnell.com/_/mc-0-1w-080...10k/dp/RE03951
            C833 (forgot to mention but should also be replaced):
            http://cpc.farnell.com/avx/08055c104...0nf/dp/CA07634
            D891,892 substitute:
            http://cpc.farnell.com/nxp/1ps76sb10...tky/dp/SC11297
            D894 (if D875 installed remove it and install D894 only):
            http://cpc.farnell.com/_/1n4937/diod...365?Ntt=1n4937
            R971 (forgot to mention but should also be replaced):
            http://cpc.farnell.com/multicomp/mck...3ws/dp/RE07411
            You wil have to buy FAN7711 from eBay make sure to get DIP-8 case.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              cheers tom really apreciate yoyr time and help will let you know the outcome.
                Use a lamp tester on it so you don't blow new parts.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  tom one last one having trouble finding the correct thermistors and the 3.15 am cylinder fuse a cheers
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    will do cheers tom
                      Fuse
                      http://cpc.farnell.com/littelfuse-wi...20This%20Range
                      What's written on NTCs?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        ntc 10 0911
                        and the saftey resistor you linked is on back order. will look on ebay for that one i gues.
                          Try this instead
                          http://cpc.farnell.com/multicomp/mck...New%20Products
                          And NTC:
                          http://cpc.farnell.com/epcos/b57235s...20This%20Range
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            all ordered cheers again tom what wattage bulb in my tester do i need its a 32 in set? so bulb should glow dim if alls ok ive never bothered to use one before this time i will haha.
                              I would use a 100W bulb, incandescent type. You don't expect it to power on. On a 26" I just had a flickering backlight and I could see brief pictures but even that is rare.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                cool thanks hopefully its going to be a easy fix paid £10.00 for it of facebook selling site with remote (just noticed says toshiba on it) and stand no marks so hope i can save it haha.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  well you want a laugh guys i took this mans word on facebook regarding this tv as he had said he had taken the psu out and found the three bad parts. well on arrival i got handed the so called faulty tv psu he pointed at the set and then kept going on about the faulty parts anway i took no notice i picked the psu remote and power lead up and he offerd to carry the tv to the car i thaught fine haha. well the moral to the story was the psu doesnt even belong to this set this set still has the psu and all boards inside and the screen is cracked haha WELL I WONT FALL FOR THAT NEXT TIME. ive just stripped it for parts no loss i guess only £10.00.
                                    Ah well bad luck, who does that for £10? Clearly has no life...
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      im still going to repair the psu as you have helped me source the parts also it will help me practice my soldering skills reagrding suface mount parts can i force this psu on tom once repaired to test it? 17pw26.4
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        the parts have come for the 17pw26.4 psu and i have fitted them and put a link tempory across the switch plug can anyone advise which pins i need to link on the psu connector socket so i can see if this psu is now working and yes i will use a bulb tester to save my new parts.
                                        • MartijnG
                                          Thermistors exceeds critical temperature - HP Elitpad 900
                                          by MartijnG
                                          When i started my tablet HP Elitepad 900, i go out of nowhere this error: “One or more system thermistors exceeds critical temperature. System will shutdown in 5 seconds…”
                                          I didn't change everything and it was running fine before. I cant start my tablet anymore, also in bios/boot option the system shutdowns.
                                          Does someone know how to fix this error or where to look at?
                                          Model: HSTNN-C75C
                                          Motherboard: QPJ80 LA-8781P , SPS: 724353-001
                                          Thank you!
                                          Greetings,
                                          Martijn
                                          06-06-2020, 06:23 AM
                                        • BigPete
                                          Panasonic Heatpump Dryer Repair
                                          by BigPete
                                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                          Unfortunately the whole machine has to come apart to fix it.
                                          I have...
                                          11-01-2025, 06:40 PM
                                        • devheart
                                          Samsung PN51F5500AFXZA issue - Power board thermistors cooked?
                                          by devheart
                                          Hi everybody. I recently acquired this 2013 Samsung Plasma TV, model PN51F5500AFXZA for free because it wasn't working. The red LED just continuously blinks when plugged in.
                                          The thermistors on the power board look cooked, with some discolouration of the PCB around them. I've attached an image of the board. The thermistors show as shorted when connectivity tested with multimeter.
                                          I tested all the diodes I could see, they all appear working, no shorts. No bulged caps. Nothing else looks shorted or burnt out. The fuse looks fine and tests shorted with continuity....
                                          01-02-2017, 05:02 PM
                                        • nmbb
                                          Can not find Model/Value of Thermistor.
                                          by nmbb
                                          Machine: Autoclave.
                                          Brand/Model: SANYO MLS-3780
                                          Manual: (Sorry search option not working on this PDF)
                                          Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                                          06-02-2022, 05:55 PM
                                        • platinumsteel
                                          Samsung S20 Ultra Charging Stopped Phone Overheating
                                          by platinumsteel
                                          Hi guys i have a Samsung S20 ultra (SM-G988U) whenever i plug in my charger it throws a Charging Stopped because phone is overheating and it makes a beeping noise. I have seen that there is a THERMISTOR on the sub board for the charging port and if this is broken or loose in any way the CPU will think something is wrong with the port and throw the error. This happened to me after i was reflowing the tuner IC's on the suboard trying to repair a no service half airplane mode issue I was having. I have already ordered a replacement port and a flex cable. But it will take 2 weeks to arrive but in...
                                          02-26-2024, 09:30 PM
