Samsung UN46D6000SF LED Backlight
  • sprocket
    • Jul 2009
    • 47
    This was given to me and I have no history at all
    When first plugged in, the standby light comes on and blinks 5 times and goes out
    I can see the back light come on fairly bright through the holes in the back panel
    then go out and back on dimmer and stay on but the standby light goes out
    I can turn it off with either console or remote and back on where it will repeat the above
    I have no OSD just a black screen so I can't hook it up to a signal but tried to turn the sound wide open so as to hear a noise but hear nothing
    I'm thinking it should show the Menu (OSD) with no source hooked to it
    I replaced both Main and Power Supply board with no change
    If I unhook power line from PS to Main, the back light stays on much brighter and looking through all the holes in the back, seem to be equally bright
    Could my problem be the TCON board
  • sprocket
    • Jul 2009
    • 47
    Re: Samsung UN46D6000SF LED Backlight
    Well, I replaced the TCON board and no go
    I have no picture, or sound. the standby just blinks 4 times and nothing else
    At the plug going to the LEDs, I have on the 4 wires 62-149-149- 267 volts to ground, is that normal
    • mmartell
      • Oct 2013
      • 3189
      This is strange. Your backlights are behaving as expected. Bad LVDS cable ?
        • 31183
        no, he would still have sound.
        probably a missing voltage somewhere.
        • tibimakai
          • Jan 2012
          • 3680
          I had a D series TV(3D smart) a while back and I know that this series suffers from bad panels.
          Try removing the ribbon cables going to the panel, one at a time. I'm suspecting a shorted panel.
          Mine it was like that, when one of them it was removed on the other half screen I had image.
          I won't be picking up D series TVs anymore, I will stay away from them, they have bad panels.
          • sprocket
            • Jul 2009
            • 47
            tibimakai
            Thanks for the come back, but that showed no change
            • Dblock 802
              • Jun 2016
              I. Having a problem with same model tv, black picture no sound. Standby light will blink 5 double blinks 2 "regular blinks" 1 long blink. Anybody have any idea? I looked online and saw something about changing caps but looking at board online don't know what caps they could be . Any help much appreciated
                Please show us the pictures of the whole back side of the TV so we can see all the boards and how they are connected together, then good straight shot pictures of the power supply board.
                • Dblock 802
                  • Jun 2016
                  Ok thanks I will do that, the tv is at my inlaws house and should be going soon to look at it and will post pics. I wonder why Samsung does not provide us with a code list as to what the specific blinks means , as I'm sure they all mean something?
                  • mmartell
                    • Oct 2013
                    • 3189
                    They have no meaning for Samsung.
                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                      I am comparing them to a brand new one that I installed
                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                      I going to let it run for several days before I remount back on the wall next to the...
                      09-05-2024, 06:48 PM
                      09-07-2024, 05:50 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • Kaar3l
                      Samsung QLED QE65Q7FNAT only standby light
                      by Kaar3l
                      TV: Samsung QLED QE65Q7FNAT
                      PSU: BN4400940A
                      MB: BN94-12832K
                      I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                      09-24-2024, 01:35 PM
                    • marcinq
                      Samsung UE60KS7000 No Standby Light
                      by marcinq
                      I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                      I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                      05-26-2025, 11:36 AM
