LG 42PJ550 Click
  • anotherdude
    • Feb 2013
    • 488
    #41
    Re: LG 42PJ550 Click
    Originally posted by tom66
    The letters after the normal product code sometimes relate to the country so that might be Norway for example. It might affect Freeview but from what I remember that can be changed in the user menu.
    thanks tom, didn't fancy breaking something
    as generally on here if you say it's no good or not to try the majority listen so thats good enough for me
    • anotherdude
      • Feb 2013
      • 488
      #42
      why are some ebay sellers so incompetent?
      wasted 3 days waiting on a part for it to be out of stock, annoying
      this will be fine as a alternative yes?
      http://www.ebay.co.uk/itm/350972139933
        • 31187
        no nand/flash device means it's looking for a usb-stick with the firmware file on it.
        • anotherdude
          • Feb 2013
          • 488
          #44
          I get no usb activity at all when powering up
          but what would the file have to be named?
            • 31187
            no idea - usually whatever it's named when you get it in the zip file.
            if you get no usb activity, is the usb port powered?
            if not then maybe your missing some of the switched 5v.
            • anotherdude
              • Feb 2013
              • 488
              #46
              from what I can tell all appear fine just the mainboard is at fault, I can't find any info at all about the message in teraterm looked on lghack and a few others
              from what I can tell if the mainboard is at fault the usb port will never get power but I guess i'll find out tomorrow as the mainboard has been sent out today
              also looking through lghack and others recovering a bricked board isn't done by usb but from inside the linux system on the board via teraterm
                • 31187
                internal comport?
                • anotherdude
                  • Feb 2013
                  • 488
                  #48
                  internal comport?
                  rs232, tried with a standard cable and with a modded 3 wire cable same results out of both
                  • anotherdude
                    • Feb 2013
                    • 488
                    #49
                    just to finally clear this one up
                    new board arrived this morning just fitted and working fine once again, have gone for a firmware update to hopefully prevent any future problems
                    • sordids999
                      • May 2013
                      • 2158
                      #50
                      Hi can anyone point me into the right direction to test patterns or maybe jump the main board i have also the fault of clicking
                      Legend pins on Psu are as follows
                      17V 17V
                      GND GND
                      5.1V 5.1V
                      ERR_DET 5.1V
                      GND GND
                      GND GND
                      STBY STBY
                      AC_DET RL_ON
                      AUTO_GND M_ON
                      thanks pictures uploaded
                      UPDATE: sorry wrong area mines a 50PJ550
                      • Asxetos21
                        Dell Latitude 5511 audible electrical noise
                        by Asxetos21
                        I have a Dell Latitude 5511 laptop, and lately, a faint but clearly audible electrical (crackling) noise comes from the motherboard, similar to the random clicking coming from a mechanical hdd's heads moving inside it.
                        The laptop shows no signs of malfunction, and clearly this is electrical not mechanical, so my suspicion goes to a dodgy component in the power rails (a capacitor or a coil?). I fear this could develop into a serious damage.
                        Any advise on how to narrow it down?
                        The schematic is available here:
                        Dell Latitude 5510 5511 - Precision 3551 FDV50 FDV51 LA-J282P...
                        03-03-2025, 09:53 AM
                      • Capestang
                        Yamaha DSP-AX861SE Sub problem
                        by Capestang
                        I really hope someone will be able to help me?
                        I have recently moved house and dismantled a working 5.1 home cinema
                        system. Unfortunately when putting it back together again I get no
                        sound out of the sub, I'll try and give you as much (probably too much)
                        information to hopefully allow you to sort my problem, or at least
                        point me in the right direction.
                        * My system consists of a Yamaha DSP-AX861SE AV receiver connected to
                        various sources and outputting through speaker cables to 4 x Monitor
                        Audio Radius 90s, 1 Radius 225...
                        01-24-2023, 04:00 AM
                      • jimanez11
                        MSI PS63 Modern MS-16S1 - No Power
                        by jimanez11
                        Have a MSI PS63 Modern with a board number of MS-16S11. Havent been able to find schematics or boardview for this machine, but would love to try to get it fixed.
                        When the power button is pressed, the machine attempts to boot - keyboard backlight turns on, then there is an audible click and the board reverts to a power off state. Press the power button again and the same thing happens. Have pulled the board from the machine trying to locate the clicking noise by sound, but it appears to be coming from everywhere on the board and I cant pinpoint its location.
                        The board...
                        03-10-2022, 04:39 PM
                      • rutgerv
                        Acer Swift 3 SF314-42 not powering up
                        by rutgerv
                        Dear all,
                        For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
                        The issue with the Acer laptop is the following:
                        It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
                        08-02-2024, 06:59 AM
                      • Loz2212
                        LG 42PJ550 continuously clicking?
                        by Loz2212
                        Hi guys,
                        I've got a LG 42PJ550 that went down on me over the weekend. The symptoms are it just keeps clicking and won't start. It was intermittent for a few hours and would cycle on and off and randomly start. Now it won't start at all.
                        I bought a repair kit which included 2 x 22ohm resistors for R927 & R929, a voltage regulator for IC301 and a diode for D304. I'm also waiting for some SMD resistors to arrive which is another 'known fix'.
                        I'd like to bow to the alter of the experts here and ask your thoughts... any voltage checks I can do to narrow...
                        11-19-2019, 03:57 PM
