Help with Vizio E320VA power board
  • Mark67
    • Apr 2014
    • 4
    Hello, I'm hoping for some help. I have a Vizio (E320VA) that lost it's picture right after a nearby lighting strike. No other components were effective. So I scanned the internet for some education. And this forum had the best detailed explanations, by far.
    So here's where I'm at: I visually inspected all three boards and everything appears fine on all three. So then I dove into the power board,( the first in the line of the components that would've taken the spike?) and took voltage readings at the 13-pin connector. Here's what I found (in the tested value column:
    label tested value
    black on/off 1.1
    brown PDIM 2.07
    Red 12+ 12.02
    orange 12+ 12.02
    yellow gnd 0.01
    green gnd 0.01
    blue gnd 0.01
    purple 24+ 25.24
    gray 24+ 25.24
    white PS-ON 5.02
    black 5+ 5.2
    brown 5+ 5.2
    red ACO 0.01
    So to my un-educated mind, the board would seem to be doing it's job? Its the pins without a posted value that I'm uncertain about.
    And of course, IF the board is good, what's my next step?
    I am comfortable poking around this stuff, and am anxious to see if I can find a solution that doesn't involve buying a whole new set.
    Any input on the reading I posted here would be greatly appreciated.
    Mark
  • Ltank
    • Jun 2013
    • 776
    Re: Help with Vizio E320VA power board
    I tried to look up service manual but no luck, wanted it confirm the Black on/off, PDIM,
    PS-On and ACO voltages. If they are correct then the Power supply voltages look good. Did the backlights turn on? If the backlights turn on then the inverter and bulbs are good. Do you have sound? Lots of times I see damage to the main board at the HDMI ports when lightning damages set. Try another HDMI port.
    • Mark67
      • Apr 2014
      • 4
      Hi Ltank,
      Thanks for the effort of looking for the service manuals. Those are my question items too.
      As for your next question, there is nothing when I turn the set on. The vizio logo in the front lights up, there is a blue light I can see from the back side, that comes from what I think is the inverter. That's it. No menu on screen, no sound, not even hissing. Perhaps I'll mess around some more with it this evening. The natives are getting restless.
      • Ltank
        • Jun 2013
        • 776
        Alot of times strikes take out the ports that are connected at the time. HDMI ports in particular. Measure the voltages at the voltage regulators on the main board. Find out what one might be missing or shorted to ground. I would look at the 3.3 volts on the main board. Alot of HDMI chips use this voltage. Main boards have limitations that the average tech can repair due to sometimes to parts availability. Some can be very tedious to remove and replace.
        • Mark67
          • Apr 2014
          • 4
          Thanks, I'll go check that right now.
          • starmatter
            • Jun 2017
            • 9
            I too am experiencing power problems with mi VIZIO E320VA. My wife tells me that she heard a pop sound followed by a complete power down. I have measured the AC voltage across the main fuse and it reads approx. 110VAC. I then proceeded to measure the DC voltage as suggested above. I get absolutely nothing on all pins. There may have been a lighting strike but we really can't recall. The symptoms are no picture, no sound and no lights.
            Thanks,
            pw
            • dskall
              • Oct 2016
              • 2905
              • usa
              Need good clear straight on pictures of back of tv with cover off and each board.
              • starmatter
                • Jun 2017
                • 9
                Here are some pictures(attached).
                Thanks,
                pw
                  What is the status of the 'VIZIO' indicator lights? Amber when TV is OFF and White when power switch is activated?
                  • starmatter
                    • Jun 2017
                    • 9
                    VIZIO indicator light is dark and never turns on at all like it did before.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Have you checked the fuse F901 for continuity.
                      What voltage do you have with the meter probes connected to each pin of the large capacitor C926.
                      • starmatter
                        • Jun 2017
                        • 9
                        The fuse F901 shows good. I don't see a C926 but I do see a rather big one C920. I got different readings between different meters for some reason. I have two cheep ones and a more expensive one. ALL three of them read the same between the fuse F901 & ground which is roughly 110-120VAC. But between the + side of C920 & ground my two cheep meters agree at roughly 120VAC but my more expensive one reads around 74VAC.
                        Thanks for your help!
                        pw
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          You read the large capacitor across the terminals in dcv
                            pw
                            You are making Voltage measurement in the Primary hot side of the circuit so do not use chassis GND as the GND ref. for the meter, you need to use the negative leg of the main filter cap as the GND ref for the circuits in the primary side. The fuse is good otherwise you will not get any DCV on the output connectors in the cold side of the circuit.
                            Main filter cap C920 should have 380~400VDC between the two legs of the cap.
                            Fusible resistor R801 is good, showing <1 Ohms or so?
                            Right now I would say you do have main board problem because you are not getting VIZIO logo on the bezel to even come on.
                            • starmatter
                              • Jun 2017
                              • 9
                              Thanks for clarifying that ground reference point. Those measurements left me scratching my head. Now that I'm measuring VDC between the pins of C920 all three of my meters agree with the result being approx. 160-168VDC.
                              R801 is good showing <1 Ohms.
                              When you say main board which board are you talking about?
                              Paul
                                The big green board with the input/output connectors.
                                Right now the DCV on the main cap should be close to 400VDC if the PFC Voltage booster is working, so you have more than one bad boards.
                                BTW, Does PS-on Voltage change state at all when the power switch is toggle on-off?
                                • starmatter
                                  • Jun 2017
                                  • 9
                                  I saw no voltage change on the large cap during power on/off. What's weird is when I probe the large cap for voltage I see higher numbers 400 to 500VDC but then it immediately drops to around 160VDC.
                                  What or where is the PFC Voltage Booster?
                                  • tvtanner
                                    tvtanner
                                    • Feb 2014
                                    • 70
                                    • usa
                                    Thanks,
                                    pw
                                    Hi- the only way you can measure voltage across fuse is because its bad. its open. burned out. Before you replace fuse check for short. usually its a rectifier.
                                    • starmatter
                                      • Jun 2017
                                      • 9
                                      Oh thanks for clarifying this for me. I meant to say that I probed both ends of the fuse with ground. I just measured continuity across the fuse and got 0 Ohms.
                                      • starmatter
                                        • Jun 2017
                                        • 9
                                        So does anyone believe this TV is worth repairing? Is it worth replacing all boards?
                                        Thanks,
                                        Paul
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
