VT420M zombification
  • SirDaddySir
    • Mar 2014
    • 5
    Trying to bring this thing back from the dead, and I am new to LCD repair but I have fixed some things before. I am hoping to attempt a component-level repair but I need to narrow down the issue a bit.
    This Vizio VT420M (ccfl) was a pawn shop as-is buy: "no sound, HDMI input only". (I don't care about the sound, but it never provided sound from either speaker or output jack. Getting it home, I was able to use all video inputs and even the digital tuning was fine. Score!)
    A month later, in the middle of a show, the picture froze and scrambled into the repeated artifacts I have now seen as typical of bad TCon. I restarted the tv and show, and about 30 seconds later the same thing happened. Tried again, and after the freeze, the backlights went and it was done trying.
    Symptoms: No backlight, no picture, and (probably) no sound.
    My findings are:
    In the past, someone had cut/badly patched one set of speaker wires (presumably to check out the sound problem), they may have been shorted somewhere inside their cocoon of elec. tape.
    Capacitors look fine. Everything visible looks fine.
    Voltage comes out of the PS in its various forms. Standby 5v is fine and logo lights up with power button. PS_on gets 3 volts or so. My 12v is only at 11.4v.
    Saw nothing on the flashlight test.
    BL_on (labeled O/F on this board) gets 0v. When jumpered to the 5v, the backlights are bright, responsive, and alluring.
    LVDS wires test to 0v or 1v, no real power seems to be heading to the TCon. TCon fuse has continuity but shows 0v.
    I only found 2 regulators on the main board, one was 5v-3.3v-0v and the other was a fixed ...09 that read 11.4v-0v-9v.
    I can provide more details if needed.
    So is it the weak 12v of the power board? Or the TCon disabling everything on a whim? Or the main board stepping on the necks of my dreams in unabashed mockery? And where do I splash the solder to make the pictures show up again?
    Thanks.
    Re: VT420M zombification
    Pictures of the main board?
    • SirDaddySir
      • Mar 2014
      • 5
      Let's see if these will do. And one of the power board as well. I'm still waiting to hear there's an easy fix for all my troubles on that side.
        Hmm, there are more than one version of your model, one has power supply-inverter combo, one does not. You have the combo one.
        The 12V is not tightly regulated power supply, it is used mainly for sound.
        http://www.shopjimmy.com/catalogsear...q=Vizio+VT420M
        It does sound like you do have main board problem since it is not sending out the BL_ON either, and it also not sending the signal to turn on the switched MOSFET (on the main board) to supply the B+ to the T-CON.
        • SirDaddySir
          • Mar 2014
          • 5
          So is it failing to provide the BL_on because the B+ is missing? Vice versa?
          Which mosfet? Is there somewhere I can stick my probes?
          Oh, it may have no significance, but I also noticed that the two metal cages on the main board, if I leave the tv "on", the bottom one gets warm and the top one, by the LVDS connectors, stays cold.
            Without the diagram it will be real difficult to trace out the circuits.
            • SirDaddySir
              • Mar 2014
              • 5
              After installing a used mainboard, the backlight and picture returned. Probably the sound, too.
              As for the original mainboard: I noted before that the top cage was staying cold on the original board. On the new one, whatever is in there warmed it up appropriately, so its on the same circuit as my mystery problem. I may go spelunking in there and see what's shaking once I'm done catching up on my show.
              • mecha1166
                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                by mecha1166
                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                11-25-2024, 05:22 PM
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:30 PM
                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
