Panasonic tx-p50xt50b won't turn on for days
  • Mr_Bodgit
    • Dec 2010
    • 47
    • doncaster
    Hi guys, been asked to look as this tv, takes 2-4days plugged in before it turns on!
    Checked psu (didnt want to turn mains off and leave him with no tv) all voltage test points are ok, no sign of any bulging caps, getting a psu off ebay for a quick fix but is there a chance it's the main board and not the psu?
    There's no led when tv is in standby, only when its on so i can't see if its just the standy 5v at fault or if it just won't wake up when told to
    Anyone delt with this issue before?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Panasonic tx-p50xt50b won't turn on for days
    Probably bad caps, even when not visibly bad or bad solder joints.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • tw2005
      • Oct 2011
      • 6458
      https://www.badcaps.net/forum/showth...ght=tx-50xt50b
      • Mr_Bodgit
        • Dec 2010
        • 47
        • doncaster
        Ahh cheers guys, wish he had another tv to use so I could change the part n caps, can't risk leaving him with no tv for days waiting for a psu to turn up if its more than that but once I've replace the board I'll crack on with checking that part out n if it works I'll sell in on ebay :-)
        Rich
        • tw2005
          • Oct 2011
          • 6458
          Rich
          It's a bit young for cap issues, it would be nice if you do have a crack at that Ic to confirm that info. Starting to see a number of posts with all the same problem so would help a few people out down the track,
          • Mr_Bodgit
            • Dec 2010
            • 47
            • doncaster
            The new board is here Tuesday so once I get the old one I'll test it n let you all know
            • Mr_Bodgit
              • Dec 2010
              • 47
              • doncaster
              Right guys, got the board swapped n tv came straight on, tested the old board before swapping, the 5vstby is dead which points towards the above mentioned chip,
              Have any of you guys worked on these chips and where do I start with it?
              Regs
              Richard
              • tw2005
                • Oct 2011
                • 6458
                Follow the notes and replace the IC, that's what I'm hoping. no you will be the first I believe.
                That info I posted not too long ago so up until then , reports of this PSU issue but nothing on that chip.
                the only ? I have is about the IC part itself .
                Why not just follow the tips, remove it and get a new IC as it says. I don't think they're too expensive
                • pajdek
                  Lenovo Y700-17ISK turn on and off
                  by pajdek
                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                  09-20-2023, 02:49 AM
                • platinumsteel
                  Panasonic SA-BT203 Power Switch Clicking Won't Turn On Issue
                  by platinumsteel
                  Hi guys I have a Panasonic blue-ray disc player Surround Sound that is giving me a lot of headache trying to repair. When i press the Power button it gives a Click Click sound but doesn't turn on.I checked Power Supply Board for swollen or bad ESR caps with my ESR Meter and all i found was some swollen caps on the Audio Board i changed with new caps but still the same. Checked the whole board for shorts and there isn't any.I used to have like 3.3v on the Power Switch Button but now i have 20v ... Is that normal? isn't it supposed to be 3.3v on the Power Switch? I am hoping you guys might be able...
                  02-02-2023, 08:13 AM
                • Trol
                  Panasonic TX-55EZ950E wont turn on
                  by Trol
                  Hope you can help me
                  3 weeks ago my Panasonic suddenly blinked red in the power led. So I tried to turn it off and on with the remote, no luck. I then turned it off via the power outlet. After that I tried to turn it on again, but nothing happened. No lights and no picture or sound.
                  Now I have tried different solutions, taking the power for 1 hour - taking the power for one Day - changing power outlet - holding the buttons on the TV down for several seconds, and even minutes. And nothing seems to help, the only thing that happens is that there is a sound, like a relay...
                  03-13-2021, 07:45 AM
                • RdeveLabs
                  MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                  by RdeveLabs
                  To all the members here...
                  Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                  So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                  05-05-2025, 04:59 AM
                • robante15
                  Acer Aspire 4520 won't turn on after reboot
                  by robante15
                  Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                  It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                  The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                  If I remove the...
                  04-06-2024, 06:50 PM
