Panasonic SA-BT203 Power Switch Clicking Won't Turn On Issue
  • platinumsteel
    • May 2019
    • 238
    • Trinidad&Tobago
    Hi guys I have a Panasonic blue-ray disc player Surround Sound that is giving me a lot of headache trying to repair. When i press the Power button it gives a Click Click sound but doesn't turn on.I checked Power Supply Board for swollen or bad ESR caps with my ESR Meter and all i found was some swollen caps on the Audio Board i changed with new caps but still the same. Checked the whole board for shorts and there isn't any.I used to have like 3.3v on the Power Switch Button but now i have 20v ... Is that normal? isn't it supposed to be 3.3v on the Power Switch? I am hoping you guys might be able to tell me what IC is supposed to actually break down that voltage from 20v down to 3v.. Is it just a Resistor ?
    There is a website that sells parts for this unit. So i would of liked to determine which part is actually bad so i can order that particular part instead of buying the whole lot of parts for it.
  • Powderfanupnorf
    Dell AL440LX power on switch circuit help required
    by Powderfanupnorf
    Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
    So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
    My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
    06-24-2024, 01:24 PM
  • justice171
    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
    by justice171
    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
    1. Verified that all critical voltages are present:
      • 3.3V and 5V are always present if DC is plugged.
      • 1.8V on the BIOS chip is present.
    2. Checked the power button functionality:
      • When pressed, the voltage drops to 0V, indicating the button is functional.
    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
      • Confirmed connectivity is intact, ruling out issues
    11-26-2024, 12:39 AM
  • claws77
    lenovo flex 5 14itl05 power sequence issue
    by claws77
    hi guys, my motherboard will not start no matter what
    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
    but rest nothing happens no sign of life.
    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
    i have no knowledge of motherboards ....
    10-20-2024, 02:48 PM
  • yaya3gmax
    Laptop Power Issue – Works on Battery, Fails on Adapter Load
    by yaya3gmax
    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
    Symptoms:
    • Laptop works normally on a pre-charged battery.
    • Battery does not charge when adapter is connected.
    • Without battery:
      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
      • Speakers “pop” when power cut occurs indicating harsh sutdown.
      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
    08-21-2025, 07:16 AM
  • grimacelord
    NEC TurboExpress On/Off Power Switch Replacement Help
    by grimacelord
    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
    11-09-2023, 09:49 AM
