Panasonic TX-55EZ950E wont turn on
  • Trol
    • Mar 2021
    • Denmark
    Hope you can help me
    3 weeks ago my Panasonic suddenly blinked red in the power led. So I tried to turn it off and on with the remote, no luck. I then turned it off via the power outlet. After that I tried to turn it on again, but nothing happened. No lights and no picture or sound.
    Now I have tried different solutions, taking the power for 1 hour - taking the power for one Day - changing power outlet - holding the buttons on the TV down for several seconds, and even minutes. And nothing seems to help, the only thing that happens is that there is a sound, like a relay that's turning on, but still no light in the power led.
    I have asked Dr. Google, and he suggests that it is the power board there's failing.
    Has someone here experienced the same error, and if so, how did you manage to get in order again? Has anyone here switched the power board himself.
    I have also mailed Panasonic Support, but there was not much help from them: Have you plugged it in the power socket o_O. And they said that since my TV was 2 1/2 Years old, there was no warranty (Yes I know) so all in all bad luck.
    Follow up. I ordered a used power board, and have just replaced it, but with no luck. It's the same, when I turn on the powerswitch there comes a click, and no more. No light in powerled and no sound whatsoever.
    Have some of you any idea of what I can try, or should I trash it. Hopefully not.
    Regards Troels from Denmark
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Panasonic TX-55EZ950E wont turn on
    Do you have a blink pattern that can help to identify the fault. Page 31 of manual.
    Service manual available here and could be of some help.
    https://tel-spb.ru/tv/panasonic-tx-55ez950e
    • Trol
      • Mar 2021
      • Denmark
      No unfortunately not. As I mentioned, there is no light in the powerled. There was only fluctuating red light, when I noticed it, and after I switched off the TV there was no more light.
      And I have found the repair manual with the blink codes. All the other tings in the repair manual is gibberish to me.
      But anyway, thank you for your willingness to help.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        This is an OLED set which unfortunately I don't know much about.
        You could try reloading the firmware via USB and see if that helps.
        Diah could probably offer you some suggestions since I believe that he is up to date with OLED sets.
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • masoksian
          Dell latitude e7470 not turn on .power buton on off and Run Power problem
          by masoksian
          I am dealing with the problem of turning on and off my Dell e7470 notebook.
          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
          The system does not turn on, there is no post.
          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
          The problem continues in the same way.
          I tried to turn on the Fn key, nothing came to the screen....
          02-15-2025, 12:08 PM
        • platinumsteel
          Panasonic SA-BT203 Power Switch Clicking Won't Turn On Issue
          by platinumsteel
          Hi guys I have a Panasonic blue-ray disc player Surround Sound that is giving me a lot of headache trying to repair. When i press the Power button it gives a Click Click sound but doesn't turn on.I checked Power Supply Board for swollen or bad ESR caps with my ESR Meter and all i found was some swollen caps on the Audio Board i changed with new caps but still the same. Checked the whole board for shorts and there isn't any.I used to have like 3.3v on the Power Switch Button but now i have 20v ... Is that normal? isn't it supposed to be 3.3v on the Power Switch? I am hoping you guys might be able...
          02-02-2023, 08:13 AM
        • oldschoolgamer
          Panasonic TX-50EX700B Won't Power On
          by oldschoolgamer
          Hi. I have a Panasonic TX-50EX700B which hadn't been used very often for some time. Recently it started getting used a little more often, until one day it just refused to power on with the red LED blinking 13 times. Upon researching, it turned out it apparently had something to do with the 5v power line, so I assumed it was probably the power supply.
          I purchased a power supply for the TV from a seller that claims that it works fine and was just taken from a TV with a broken screen. After fitting the new power supply and trying the TV, I was greeted with the power LED being red for...
          10-26-2022, 04:15 PM
          After all of...
          07-13-2024, 08:14 PM
