Maxent mx-42xm11 repair
  • OuchCharlie
    • Mar 2014
    • 3
    • US
    Hey everybody
    I have an old Maxent mx-42xm11 that I'd like to repair and was wondering if anyone could help me diagnose the problems.
    The first problem is the TV takes about 10 minutes to warm up. About 7 minutes after being turned on, it starts to flash the picture. Once it's warmed up it works normally.
    The other problem is there are red, green and blue dots that are constantly flashing on the screen. These are on the picture even once it's warmed up. I'll attach a picture so y'all can see what I'm talking about.
    If anyone knows what might be causing these issues I'd be very thankful for the help.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Maxent mx-42xm11 repair
    Probably best to open it up and post some pictures of the boards. The issue could very well be bad caps by the symptoms you described.
    • wills123
      • Jan 2014
      • 72
      • england
      a heat gun may also be useful to pinpoint areas causing issues if nothing obvious is seen
      • SteveNielsen
        Retired Tech
        • 2327
        Bad solder joint also comes to mind.
        • Nascar
          • Sep 2010
          • 10
          I am very Interested in the out come of this issue as i have the exact same model
          Mine after the same amount of time flashing from not on at first to the screen the original poster posted (coloured scrambled) then to solid blue as it is supposed to do. So i played a film on it and as it was playing sometimes it would flicker for like 2 seconds every so often but worked in general i am leaning toward the power supply or the main board but im not sure on anything at this point i see no bad caps or anything burnt was thinking about using the heat method but since it works after letting it blink off and on for approx 7-10 mins (warming up) and then work not sure heat would be the thing to use
          This thing weighs a ton it is very heavy to work with please keep that in mind
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • CyberPhoenix
            Issue with picture quality of Sony bravia TV
            by CyberPhoenix
            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
            01-22-2024, 02:08 AM
