pn50b650s1f
+ More Options
Posts
    Re: pn50b650s1f
    I'd say a good chance of a loose connector for that part of the panel, doesn't look like a bad panel to me. Also make sure ribbons from control board are seated into the boards correctly.
    • bodaciuos
      • May 2011
      • 43
      Re: pn50b650s1f
      thanks i will try that. i soldered a thin wire on the fuse just to see if it start up. which worked. will this affect anything? just for testing of coarse.
        Re: pn50b650s1f
        If the fuse blew there's a chance the panel is bad, but it's quite rare for one to fail like that.
        • bodaciuos
          • May 2011
          • 43
          Re: pn50b650s1f
          yeah thats what i though. the fuse is there to protect the board i will amagine. any ways i just hope the cable that connects the two together is right. ill try to check the buffer cables this evening. thanks to you both.
          • bodaciuos
            • May 2011
            • 43
            Re: pn50b650s1f
            ok . update i looked at te bottom buffer boards. i didnt see anything visual wrong so i decided to reow the board a little just to see if there was a change. now the red line is yellow .. go figure..
              Re: pn50b650s1f
              You've gone from losing both green and blue to losing only blue for that part; in my opinion, that's progress. Whatever you did, try doing it again. Check ALL connectors on BOTH ends of the control board and buffer boards.
              • bodaciuos
                • May 2011
                • 43
                Re: pn50b650s1f
                thanks tom for the advise. and to keep me going with it. i hate to giving up. but i was going to. update , after all the panel is good. i reflowed the left side lower buffer board with a heat gun . and it work im back to a normal picture. i see how long it will hold up being these tv heat up.... does any one know where i could fine the mini ceramic fuse for this buffer board .. thanks to caeb and tomm for your help.. hope this helps someone else. reading is fundamental. great job guys..
                  Re: pn50b650s1f
                  Make SURE you install the heatsink for the X-buffer if you run the TV for longer than about 30 seconds.
                  What is the rating of the original fuse?
                  • Caleb
                    Smokin IC's
                    • Feb 2013
                    • 645
                    Re: pn50b650s1f
                    The original is an 8 amp, here is a similar fuse on digikey, Its 250v ac 125v dc Tom will that fuse will hold up in that location?
                    Liberating magic smoke one part at a time
                    • bodaciuos
                      • May 2011
                      • 43
                      Re: pn50b650s1f
                      not really sure. of the fuse..
                      • bodaciuos
                        • May 2011
                        • 43
                        Re: pn50b650s1f
                        tom what are the heat sinks your talking about? i dont see any on the boards. is it the metal plate you have to take off to get to them ?
                          Re: pn50b650s1f
                          Yes, the metal plate is the heatsink. It absolutely MUST be installed or failure of the panel is likely.
                          This should work as a replacement:
                          http://www.digikey.com/product-detai...90CT-ND/813068
                          • bodaciuos
                            • May 2011
                            • 43
                            Re: pn50b650s1f
                            well that didnt last for long. i left it on about an hour. and know i have a purple line in the same area . im really nervous about reheating it again. i guess i have nothing to lose. what do you think . is it the heat flow of the board or something else.
                            so i turned t off about 20 minutes turned it back on and know the purple line is gone.. im loosing it..
                            is it possible that i dont have the fuse. will this make a difference ?. HHHmmm; maybe ill wait to get the fuse before i make things worse.
                            • Caleb
                              Smokin IC's
                              • Feb 2013
                              • 645
                              Re: pn50b650s1f
                              What part are you reflowing? If it isn't the ribbon portion some flux added to the joints may give you a better reflow
                              • bodaciuos
                                • May 2011
                                • 43
                                Re: pn50b650s1f
                                i flowed the left side lower buffer the side where the line is located.im assuming that each buffer controls the side it is on . am i right ? ill have to go to RS to get some flux. im just really nervous to melt he plastic connectors. i wish i new where exactly to heat so i dont have to heat the whole board..
                                • bodaciuos
                                  • May 2011
                                  • 43
                                  Re: pn50b650s1f
                                  well i reflowed the board again with flux and it last about an hour. an the purple line returned. im at my wits end. i thought i had it this time. im going to ware out the screws threads. i think, im just not heating it up enough or it just cant be fixed..
                                  • bodaciuos
                                    • May 2011
                                    • 43
                                    Re: pn50b650s1f
                                    UPDATE; so i figured i has nothing to loose. so what i did was, so to not heat the ribbons and tabs, i left the heat sink on. to protect these part. and i was bold enough to heat each set of chips for 30 seconds each. at a low setting on heat gun. and so far so good. the set has been working about 2 hrs. i think i got it. call it lucky . i figured i had nothing to loose . so after 2 week and 150 bucks give or take. and the most important thing .knowledge.. thank guys
                                    • Caleb
                                      Smokin IC's
                                      • Feb 2013
                                      • 645
                                      Re: pn50b650s1f
                                      Once you have the basics down broken TVs seem to appear everywhere. I fixed my first LCD about 8 years ago now I fix several each month. Don't get too discouraged if it fails again there's always another TV to be found. I hope your repair holds for many years, I just gave away the first TV I fixed to my mother In law and its still going strong.
                                      • bodaciuos
                                        • May 2011
                                        • 43
                                        Re: pn50b650s1f
                                        yeah , thanks for your help. i would of gave up. i thought there wasnt a fix for the vertical line., but it seems to be holding for know. my friend want to buy from me but im not sure of the fix. actaully i love the graphics of the tv .for me it looks alot better than the samsung led smart tv ,which cost me a grand. dam i wish i would hae found ths tv 6month ago i could of save a grand or more.. oh well. life goes on .now maybe i could make some of that money back.
                                          Re: pn50b650s1f
                                          Plasma > LED almost always. This will beat any LED TV on picture quality.
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                          • DqMagetz
                                            Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                                            by DqMagetz
                                            Good day!
                                            I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                                            Here are the voltage readings:
                                            • Input – 19V (stable)
                                            • +LCDVDD – 3.3V briefly, then drops to 0V
                                            • EDP_HPD – 3.3V briefly, then drops to 0V
                                            • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                                            • EC BKOFF# – 1.8V briefly, then drops to 0V
                                            • PANEL_OD_EN – 0.3V
                                            Is it possible that the EC chip is corrupted or damag...
                                            07-12-2025, 09:37 PM
                                          • Ven
                                            Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                                            by Ven
                                            Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                                            Issue Description:
                                            1. CPU Overheating to 100°C
                                              • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                                              • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                                              • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                                              • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                                              • Thermal
                                            02-12-2025, 03:57 PM
                                          • spice_disc
                                            Vizio TV M50-C1 reboot cycle and static on screen
                                            by spice_disc
                                            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                            09-08-2024, 02:37 PM
                                          • delir66
                                            How to fine control a brushless dc motor
                                            by delir66
                                            Hi, I'm building a pottery wheel for my wife.
                                            Since it needs to reverse direction and have a nice control over rpm, I decided to pick a diy electric scooter motor.
                                            It operates at 48v and comes with a controller.
                                            It has three wires for speed control
                                            -5v
                                            -gnd
                                            -signal.
                                            The problem is that if I use a 100k pot, motor starts spinning when 1.4v and will get to max revolutions at 3.4v. With this 2v range, the potentiometer is not really ideal, as it will change suddenly rpm with the slighlest touch.
                                            I need something...
                                            12-07-2022, 11:00 AM
