Vizio VO47LFHDTV30A Dead Set
  • JMHammond
    • May 2013
    • 5
    This set has a 0500-0407-0680 (DPS-280LP) power supply. Through troubleshooting I found Q901 N-ch Power FET shorted which I replaced, along with R908 an SMD resistor open. The value of this resistor was blown off the top so I have no idea of the value. I have searched for a schematic for this supply to no avail. Does anyone have a schematic from which they could give me the value of this resistor(R908). Thanks much for any help. JMHammond
  • ej207
    • Oct 2014
    • 9
    Re: Vizio VO47LFHDTV30A Dead Set
    i would love this as well. same problem
      Q901 is for the STBY Power supply so it means that the SMD SMPS IC is more likely to be damaged also which you should replace otherwise you new MOSFET will be damaged. There may a fusible fuse that feed the B+ to this STBY section.
      Can we see good clear pictures of you board both sides (the whole board, and also in 1/4 section so I can easily see the traces to trace out the connection)
      The resistor that burn up may be for the Gated drive R/D network, also need to find out of there is <1 Ohm resistor connected to the Source pin that needs to be check to find out if it also went open circuit when the MOSFET shorted out.
      This is the same board as yours?
      http://www.shopjimmy.com/vizio-0500-...wer-supply.htm
      • ej207
        • Oct 2014
        • 9
        First off apologize for thread highjacking, but we may have the same problem.
        I tested all the pins to the bottom right of the board and no voltage?. Weird, and I made sure my multimeter was O.K. by testing other devices, even the wall outlet haha. Would this be a bad voltage regulator?
        Quick history on the board, previous owner which is an old friend of mine replaced two resistors
        • R901
        • R601
        I'm not sure when to the time it broke on me, probably a few months? But my girly and I was just watching the TV and it shut off, and i get no power led's nothing its completely dead. I have fixed some TV's in the past that just had the obvious blown caps. Here is some pics of the boards, which are exactly what you posted above.
          @ej, it will be better for you to start another thread so it will be confusing when two people are asking the questions.
          • tinkerer973
            • Nov 2014
            • 14
            It would seem I have a similar problem with this PS board. I have voltage all across the board till I get to the secondary section, then I have nothing. I'm unsure of whether I just lost the 5v stby and the rest is fine, or if there are larger scale issues. I'm not sure where to begin from there. I have some electronics knowledge, I repair radio gear form time to time, but this is beyond what I'm used to working with. Hopefully someone can give me a hand getting this set fixed, Thanks
              @tinkerer: Same exact model power supply and TV model? It may be better to start a new thread with make and model.
              • masessum
                • May 2012
                • 8
                In reference to the Delta power supply DPS280LP with the open R908 smd resistor in the standby 5V circuit, according to Fuji Electric's PDF on the Regulator controller IC FA5571, two example circuits show it as 22 Ohms. It worked for me!!
                • trixter
                  • Mar 2011
                  • 13
                  Currently working on this board. What are the ohms of R901/601? They are the same. From looking at the colors it is Red Red Silver Gold Silver. When I try to look this up I can't find a resistor with the third strip as Silver. I can see that one of the resistor is damaged. There is no reading across it.
                    0.22 Ohm MOX Flame proof type, if I am correct, it is also fusible resistor so if they are open circuit then you more likely have shorts circuit somewhere. I cannot clearly see them in the pictures.
                    • trixter
                      • Mar 2011
                      • 13
                      Needed that info. I used a 22 ohm resistor. plugged it in and sparks flew and burnt up those resistors.
                      • slidewire
                        • Feb 2011
                        • 10
                        In mine, the same board, R908 was also open, it had "60A" on top which crosses to 412 Ohms.
                        • DarinC
                          • Jun 2021
                          • 5
                          I tried this with the standard component set from Shop Jimmy. I think I needed Q901 which the set didn't include.
                          • Iain P
                            Vizio E65-F0 really dead
                            by Iain P
                            Hi everybody!
                            I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
                            So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
                            I decided to check the voltages coming off the power supply they are as follows:
                            connector CN201
                            pin 1 (18vsb1)...
                            02-23-2023, 11:32 AM
                          • jinu_j
                            by jinu_j
                            Hi
                            05-03-2025, 10:51 PM
                          • mikey5791
                            Need help to replace burned resistor in 350w atx psu
                            by mikey5791
                            Hi to all forum members,
                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                            12-26-2024, 04:55 AM
                          • catnapped
                            Dead Vizio D40u-D1
                            by catnapped
                            Recently had my bedroom Vizio D40u-D1 apparently die while it wasn't being used. Noticed the power LED flashing, figuring maybe a software upgrade, but attempting to turn it on proved that wasn't the case. When powered on, the power LED will flash a bunch of times after about 2 minutes then turn off again. Definitely is no picture even with a flashlight on the screen. Had the opportunity to open it up over the weekend. Doesn't apper to be anything out of the ordinary visibly inside, nor any odd smells of escaped magic smoke. Readings from the connector in the corner of the power supply board...
                            04-02-2024, 08:55 AM
