Samsung PS-42Q97HD Logic Board not giving VS_ON
  • tn245
    • Oct 2013
    • 530
    Hi!
    This TV also had the dubious honour of being the subject of the worst soldering job ever thread, but I thought I'd start another thread for some troubleshooting I need to do unrelated to the shocking repair job discussed in that topic.
    I've got the PSU working when isolated. Jumpering ps_on and with a resistor between std5v and vs_on I get correct voltages including Vs at 205V.
    With everything connected, everything fires up except Vs which stays at 0V, and vs_on which also remains at 0V through the whole start-up sequence. This happens also with any combination of X-main and Y-main connected/disconnected.
    I've removed the main AV board and jumpered the logic board for test patterns. Is it supposed to give the vs_on signal itself in this state? Either way I have tried it with forcing vs_on with the resistor and without. With logic board connected without forcing it, vs_on remains at 0V. With forcing it, it briefly rises to about 1.7V and then drops to 0.7V and Vs spikes to 100V or so and then gradually drops down.
    The two LEDs on the logic board light up and stay constantly lit.
    My guess is I need a new logic board. What are your thoughts?
    Re: Samsung PS-42Q97HD Logic Board not giving VS_ON
    Vs on will rise only if pson is grounded and the connector between logic and power board is connected.
    • tn245
      • Oct 2013
      • 530
      Yup, I've done it that way. Vs and vs-on stay at 0v.
        Do you have 3.3V/5V on that board available at the test points?
        • tn245
          • Oct 2013
          • 530
          Yes I do have 3.3V and 5V at the test points.
          • tn245
            • Oct 2013
            • 530
            Tom I do have 3.3v and 5v at the test points on the logic board.
              Can't think of any further tests. Guess you will have to try a new board.
              • tn245
                • Oct 2013
                • 530
                Will do. Thanks. I guess these are pretty specific to the panel and I have to match numbers exactly. None available at the moment that I can find. Will have to wait for one to come up.
                  One thing you could try if you've got a scope is to test the oscillator. Also, note you cannot put 50" board in 42" set and vice versa
                  • flocko
                    • Nov 2012
                    • 1121
                    board number BN96-06088A can also be used, could help in finding replacement ?
                    • tn245
                      • Oct 2013
                      • 530
                      Thanks for the suggestion flocko. I'll add that part no to my searches.
                      Tom I don't have a scope. Think I might look into getting one at some point though. Are you suggesting other 42" boards might work even with different pba numbers? Or is it the case that you can find boards with the same numbers, but configured for different screen sizes?
                      This board is LJ92-01496A. Any chance LJ92-01454A would work? There seem to be more of them about.
                      • flocko
                        • Nov 2012
                        • 1121
                        well believe it or not i have just got a PS42C96HD with the same problem and the same logic board LJ92-01496A, you can jump the power board to get Vs but no Vs On from logic board also on this one no LED have not had a good look yet just checked fuses and 3.3v and 5v both are there, have not looked for replacement board as could yet find fault,any luck with yours tn245 keep me posted and i will do likewise Flocko
                        • tn245
                          • Oct 2013
                          • 530
                          Ah. I will be curious if you come up with anything. I do have two LEDs lit on the logic board, but otherwise the symptoms sound similar.
                          I have put this one aside for now and am waiting for a chance to grab another board or to come across a broken screen TV with the same board. If you find a fix I would be very happy to hear it.
                          • andyselectronicstuff
                            • Mar 2010
                            • 3
                            Hi Guys, just spotted this thread and thought i would let you all know what the problem is, this ctrl board commonly fails after the "Badcaps" in the power supply go bad, the noise on the data lines/supplies causes the 48pin tsop flash chip to become corrupted, it either gives a blank screen as no VS-on from ctrl board or you can get partly blank screen with digital noise. i keep programmed flash chips in stock for this model and the 42in Q96,C97,C96, should anyone need one just pm me.
                            thanks
                            Andy
                            Andys Electronics
                            • ABMaster
                              • Nov 2015
                              • 5
                              • ITALIA
                              Hi I've replaced alot of Capacitors on power Supply board
                              now have all the voltages on the board
                              but have 2 vertical bars displayed on a black screen ending at the middle of vertical height.
                              is possible is teh logic LS92-01496A ?'
                              thanks for a reply
                              AB
                              • ABMaster
                                • Nov 2015
                                • 5
                                • ITALIA
                                tn245
                                you can find many logic board on e-bay or aliexpress.com
                                but can fin more only searching LJ92-01496A
                                Bye
                                  • Mar 2010
                                  • 3
                                  thanks for a reply
                                  AB
                                  fault symptoms can vary from blank screen with no Vs-on to something like the image in the attached photos when you have very low Vs-on.
                                  replacing just the flash chip on the control board will cure it.
                                  a new programmed chip is available here if anyone ever needs one.
                                  • flexy123
                                    • Dec 2012
                                    • 34
                                    • Spain
                                    wow, excellent, I had an inkling it's something like that, explains why the Logic failed shortly after I repaired the SMPS. Will contact you.
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • ohren
                                      by ohren
                                      09-08-2023, 05:24 PM
                                    • korben_dallas
                                      Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                      by korben_dallas
                                      Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                      I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                      I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                      MY QUESTION:
                                      I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                      02-14-2024, 12:23 AM
                                    • Stephen
                                      A2991 Logic Board issue, 20volts 0 amps help!
                                      by Stephen
                                      Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                      09-10-2025, 03:16 PM
