Dead dps-162kp-1 powerboard
This topic has been answered.
The r7900 was blown, R7902 gave bad reading, the C7901 wasn't blown, but replaced (wanted to check out of cirquit, but fell on the ground and lost it some where in my barn) d7950 was shorted. Yesterday I replaced the ic with new one. Nothing changed.The A6069H gets the vcc startup voltage on pin5 from an internal startup cell inside the ic, so you either have a short on pin5 or the new ic is bad, also replace C7918
Pin 5 must have at least 15.3vdc for the ic to start
Why did you replace r7900, R7902, C7901, d7950 ? were they bad, as that would give an idea what may have happened
Cap 7918 and D7906 did look fine in circuitry, I Wil remove them and check them later on
Thanks for the replyLeave a comment:
Why did you replace r7900, R7902, C7901, d7950 ? were they bad, as that would give an idea what may have happenedLast edited by R_J; 08-31-2024, 08:07 PM.Leave a comment:
once i faced dead dps-162kp after repairing all parts on primary it remain dead.. then after taking the main transformer outside the circuit i found there are cut between the coil and standing pins.
I have a dps-162kp-1 runtka932wjqz powerboard wich has no power at all on the cold side.
I replaced ic7903, r7900, R7902, C7901, d7950.
Checked the diodes around the chip and also the caps.
On the ic pin 5 no voltage, pin7-8= 315V
On the T7901 pin 1-4 no voltage, pin 2-3=315V
Anybody have any idea where to look further?
Any help is welcome
Thanks Danny from holland4 PhotosTags: None
by craig1410Hi,
My wife's 2019 MBP died a couple of weeks ago and I have been trying to figure out what is wrong with it. I have an electronics background and equipment but never tried to diagnose a modern MBP before. I have the board view and schematics already and have been climbing the learning curve steadily!
Initial fault was no power with USB ammeter showing 5.19V @ around 12 to 35ma. I won't go into all the initial debug I did because ultimately I found R7900 to be high resistance when it should have been a 0ohm link.
So, going from the power sequence... -
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... -
by disorderhello guys,
i need help to repair a edm-033 ps2
history : as always hdmi port and usb ports destroyed after unplugged
after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
so i changed it
now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
i don't see any projection of liquid metal on pcb.
Hello everyone hope all doing well!
I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...3 Photos -
by BetonHi guys!
I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
I have a bench PSU and if I try to inject voltage the voltage... - Loading...
