UE40D5000 no display or reaction to either remote or touch
Are there any cheaper options? I probably will rarely if ever use a programmer like that again, I don't care about speeds or anything I just need something that gets the job done. For the price of either of those where i live i could get a new mainboard.Comment
It's pretty hard to find even CH341A for less than 15 dollars, so as you can see it's just not worth the effort.Comment
I see where theyre availabe from china via ebay for about 7 dollars, always involves a wait period tho.Last edited by nomoresonys; 08-29-2024, 04:41 PM.Comment
I should get 24H delivery so I can start flashing it tomorrow. I would order it from aliexpress if i didn't care about time but i really just wanna get this done quick.Comment
Hi Vapor, i agree with 1st message of Lotas (except for the vga pins, them are TX, RX, GND, but it doesn't matter here), don't buy a ch341a, it's totally useless unless you are an engineer with software skills and much, much, much free time.. micro controller its not an eprom with a common language, it needs serial commands specifically for that chip, plus the chip is chinese or the like so difficult maybe for datasheet.. maybe i'm not right 100%, maybe the serial commands are not as complex as i said.. if i had time i would start a test programming with serial monitoring and gave to you the log to semplify your pc programming job, but i have no time and maybee not so wish, sorry, maybe we meet online this winter, byeLast edited by Davi.p; 08-29-2024, 04:49 PM.Comment
You are behind the times, anything is possible if you try...Hi Vapor, i agree with 1st message of Lotas (except for the vga pins, them are TX, RX, GND, but it doesn't matter here), don't buy a ch341a, it's totally useless unless you are an engineer with software skills and much, much, much free time.. micro controller its not an eprom with a common language, it needs serial commands specifically for that chip, plus the chip is chinese or the like so difficult maybe for datasheet.. maybe i'm not right 100%, maybe the serial commands are not as complex as i said.. if i had time i would start a test programming with serial monitoring and gave to you the log to semplify your pc program job, but i have no time and maybee not so wish, sorry, maybe we meet online this winter, byeAttached Filesif you find these attachements useful please consider making a small donation to the site
Sooooooo, the programmer WAS supposed to arrive last Friday, but it just didn't. I have it now though.
I wanted to say that I may not be a engineer but i do have some software skills and a bunch of free time. Iirc the microcontroller was pretty well documented. Thank you for your concerns though.Hi Vapor, i agree with 1st message of Lotas (except for the vga pins, them are TX, RX, GND, but it doesn't matter here), don't buy a ch341a, it's totally useless unless you are an engineer with software skills and much, much, much free time.. micro controller its not an eprom with a common language, it needs serial commands specifically for that chip, plus the chip is chinese or the like so difficult maybe for datasheet.. maybe i'm not right 100%, maybe the serial commands are not as complex as i said.. if i had time i would start a test programming with serial monitoring and gave to you the log to semplify your pc programming job, but i have no time and maybee not so wish, sorry, maybe we meet online this winter, bye
I'll attach some pics of the programmer, and the documentation and software i got with it. (The documentation is in polish but there is probably a English version somewhere)Attached Filesif you find these attachements useful please consider making a small donation to the site
5 PhotosComment
where exactly do i wire the resistor? Also my board came with a jumper placed, do i remove it? It looks like it switches modes but its in chinese, one says something and the other has TTL and something.
Also the schematic you provided provides 3.3v (which i also have from the programmer if needed) instead of five, and the resistor there is 2.2kom.Comment
The resistor should be set to 1 kOm, we don't need to supply 3.3v, there is a 3.3v LDO on the board, which powers the controller, and we supply these 5v from the programmer, we need them to reset the controller. Connect like this.
There is no need to remove the jumper, it must be set to 1-2 pins, and you must first install the drivers for the programmer.Attached Filesif you find these attachements useful please consider making a small donation to the site
I was thinking of trying to do this with wine, (I don't have anything running windows in my home atm) but I think I'll spare myself the pain and just use qemu with a windows installation
There is no need to remove the jumper, it must be set to 1-2 pins, and you must first install the drivers for the programmer.Comment
by trepachkaI am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
by ProttHello,
I have a question that's driving me a bit nuts recently.
Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
- I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
- In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board... -
This specification for the Dynabook Portege X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR boardview and X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 05:50 AM
This specification for the ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To boardview and 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard...09-07-2024, 02:50 AM
This specification for the Fujitsu LIFEBOOK LIFEBOOK U7411 Intel Core i5-1135G7 35, 56cm 14Zoll FHD non-touch ePrivacy 1x16GB 512GB SSD LTE W10P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7411 Intel Core i5-1135G7 35, 56cm 14Zoll FHD non-touch ePrivacy 1x16GB 512GB SSD LTE W10P boardview and LIFEBOOK U7411 Intel Core i5-1135G7 35, 56cm 14Zoll FHD non-touch ePrivacy 1x16GB 512GB SSD LTE W10P schematic. Our users have donated over 1 million documents which are being...09-07-2024, 12:10 AM
- Loading...
