UE40D5000 no display or reaction to either remote or touch
  • lotas
    • Jan 2016
    • 4749
    • Russia
    #41
    Well, I don’t know, it’s up to you to decide, the main thing is that the drivers for the programmer are installed and the program for micom firmware is launched.
    • VaporGame
      • Aug 2024
      • 30
      • Poland
      #42
      Originally posted by VaporGame
      I was thinking of trying to do this with wine, (I don't have anything running windows in my home atm) but I think I'll spare myself the pain and just use qemu with a windows installation
      okay so i got everything running, checked my wiring, but it says it failed writing everytime. I am trying to flash the bin provided earlier in the thread.
      • lotas
        • Jan 2016
        • 4749
        • Russia
        #43
        Well, he identified it, can we read its firmware?
        • VaporGame
          • Aug 2024
          • 30
          • Poland
          #44
          I tried that aswell, same issue.
          I have installed all the drivers that were in the provided software. What can i use to debug the problem? The event log isn't very useful.
          Should i have the board be plugged in only into the programmer?
          • lotas
            • Jan 2016
            • 4749
            • Russia
            #45
            Yes, on four wires, try lowering the frequency, reducing the resistor to 600-800 Ohm
            • Diah
              • Feb 2013
              • 6435
              as i said its interest experiment, so i do share what could help...
              CH314 cant responded to changing bautrate as the Scn confirm the terminal SW. this why we need to use another adapter TTL to RS232 Serial Port Digital Converter / we set the CH314 as the driver... then when Soc asking to change bautrate... the RS adapter will response for the change not the CH314 so no error come... but in this case we need to use 3.3V level and power up the Tv during write
              • VaporGame
                • Aug 2024
                • 30
                • Poland
                #47
                Okay so i lowered the resistor to ~660ohm, and it read fine, I'll try flashing.
                It flashed fine, but when i read the contents, they looked okay. Should i try to desolder everything and try to power it?
                • VaporGame
                  • Aug 2024
                  • 30
                  • Poland
                  #48
                  Upon further inspection, what i read back had a lot of things replaced by FF.
                  Messing around some more i got it to write correctly.
                  • lotas
                    • Jan 2016
                    • 4749
                    • Russia
                    #49
                    There is a button to check the contents, as recorded with the original dump.
                    • VaporGame
                      • Aug 2024
                      • 30
                      • Poland
                      #50
                      yea it matched up, should i continue to try and boot the tv?
                      • Diah
                        • Feb 2013
                        • 6435
                        as both of you ignoring what i warren you, here my last to other user who come with same issue and reading this threat
                        you had never write one sector on the flash.. and what you did read are error fake report by SW... time for replacement.
                        • lotas
                          • Jan 2016
                          • 4749
                          • Russia
                          #52
                          Yes, if you passed verification, then unsolder the wires and install it on the TV and check.​
                          • VaporGame
                            • Aug 2024
                            • 30
                            • Poland
                            #53
                            It works!!!! Thank you all for your help, without it I would have never figured this out.
                            How can i mark the thread as solved or something?
                            • lotas
                              • Jan 2016
                              • 4749
                              • Russia
                              #54
                              Well, that's good, what I was talking about!
                              • Diah
                                • Feb 2013
                                • 6435
                                fake.... post photo of the working
                                • VaporGame
                                  • Aug 2024
                                  • 30
                                  • Poland
                                  #56
                                  Lemme put it back together first, its 12am.
                                  • lotas
                                    • Jan 2016
                                    • 4749
                                    • Russia
                                    #57
                                    And what's wrong, if I don't know or doubt, then I'm silent and don't give advice.​
                                    • lotas
                                      • Jan 2016
                                      • 4749
                                      • Russia
                                      #58
                                      Diah never has anything to prove, he will always prove himself.
                                      • Diah
                                        • Feb 2013
                                        • 6435
                                        its not for you or for me.. its for the sake of others users faced same issue.
                                        • lotas
                                          • Jan 2016
                                          • 4749
                                          • Russia
                                          #60
                                          So it turned out the way I described from the very beginning, what happened (MICOM UPDATE) and how to get the TV out of the brick state...
