Vizio L32 I have the amber standby light and pushing power button gives me the green light but that's it no picture, sound or anything. inspecting the power board I see no bulged caps or anything burnt looking. Not sure what the voltages are to be as they are not marked on the board next to the plug like most. Not sure where to start on this one.
Vizio L32 green & amber that's it.
Re: Vizio L32 green & amber that's it.
The two white connectors on the left side of the power supply board have Voltage and labeling on them, post the pictures of those two connectors. What is the full model number of the TV?Last edited by budm; 03-12-2014, 03:32 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
What DC V do you get at the REMOTE (PS_ON) pin when TV is OFF and when power switch is activated? Chassis ground will be your your ground ref. point.
Also post the pictures of the whole back side of the TV so we can see how the boards are connected together.Never stop learning
PS_ON is same as REMOTE on this PSU.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
So main board is turning on PSU. What do the 5V,12V and 24V of the PSU do then? Do they become active?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK, so the REMOTE (PS_ON) is OK, so find out if the PFC Voltage booster is working or not by measuring the DC Voltage RIGHT AT THE TWO PINS OF THE MAIN FILTER CAP (450VDC Black cap laying on its side). It should have around 370~400VDC when power switch is activated. Do not touch anything with your hands
CN2 is the output connector that feeds the 24V (V3), DIM, and bl_on signals to the inverter board.
This is what I believe you have on your board.Attached Filesif you find these attachements useful please consider making a small donation to the site
So no 24VDC on V3 at all?
Good CLEAR pictures of the bottom side of the power supply board is needed, also still need the back side of the TV as requested.
http://www.shopjimmy.com/vizio-0500-...upply-unit.htmLast edited by budm; 03-12-2014, 05:18 PM.Never stop learning
OK, I need closed up pictures of the 24v section (bottom side), I will have to trace out the circuit to see how they are connected, also need the P/N of those two SMD ICs.
Also closed up on the top side of the 24V section.Attached Filesif you find these attachements useful please consider making a small donation to the site
ok the smaller chip looks like L65610 and under it is EZ516 then the longer chip has on it L6598D and under is 992448 I also looked at the other chips and the rest have on them S66841SZ and under is KZA033705160 I did a scan of the bottom I hope it's better.Attached Filesif you find these attachements useful please consider making a small donation to the site
IC spec for L6598 SMPS. I did not have to time to trace out the board yet.Attached Filesif you find these attachements useful please consider making a small donation to the site
OK, check the value of the three lytics cap for value and the ESR.
Check the value of the Poly cap (grey cap).Attached Filesif you find these attachements useful please consider making a small donation to the site
by shahnldGood Day.
I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite... -
Assuming...7 Photos -
by jimjoe123I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
Then each time... -
This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-12-2024, 02:00 PM
This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD,...09-07-2024, 03:10 AM
- Loading...
