Polaroid 42" help
  • Twins_Guy
    • Feb 2014
    • 28
    Polaroid 42" help
    I just picked up a 42" polaroid model TLX-04244B and the dump, it looks brand new it still has the plastic wrap on the sides and the 42" sticker in the corner of screen. when I plug it in the red light comes on, I push the power button blue light comes on then it clicks then blue light flashes 6 times then stays blue. I get nothing coming on the screen, all the caps look good, does anyone know what the 6 flashes mean?
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Polaroid 42" help
    Most common failure on this set seem to be the inverter circuits. Youtube has this video
    Liberating magic smoke one part at a time
    • Twins_Guy
      • Feb 2014
      • 28
      My power board does not look like that one in the video, here is a couple pics. is is possible to check the voltage of caps to see if there is a bad one? I went along and was getting readings on some and then one did not read anything and the ones after did not as well. could the one that read 0 be bad?
        Pictures of the whole back side of the TV so we can see all the board. Check the DC voltage at the PSON pin when TV if off and when power switch is activated, use the chassis as the ground ref point for the meter. Please also read the basic LCD troubleshooting guide. This is the same power supply used in VIZIO TVs.
        • Twins_Guy
          • Feb 2014
          • 28
          Reading at pson is .17-.18 when off and 5.08 when on
          • Caleb
            Smokin IC's
            • Feb 2013
            • 645
            That indicates the main is sending the signal to switch on the power supply. what other voltages are present on the power board? It looks like your board is supposed to have 12v and 24v in addition to the 5v you already tested. What are the voltages on those pins when the pson is at 5v
              So you do have PS_ON, next we need to find out if the PFC Voltage booster circuit is working or not, you will have to get to the two pins of the main filter cap (the 450VDC Black cap under the heat sink), the voltage on the two legs should be about 370~400VDC when TV is powered up. The 12V/24V SMPS require this PFC voltage to run.
              • Twins_Guy
                • Feb 2014
                • 28
                The pins at 12v is 11.83 and 24 dont read anything. It reads a 1. On the left of the meter
                  Try moving your meter to the next highest range, probably 200V. (24V is out of range for 20VDC range.)
                  • Caleb
                    Smokin IC's
                    • Feb 2013
                    • 645
                    I would try removing the connectors to the inverters one at a time and see if your 24v comes back, and Budm wants to know if the pfc is working.
                      There are three 24V output connectors: 24VA, and two 24VI. You must use the Ground pin of each connector for testing the output voltages just to be sure cause some time the Ground for 24V is not tied to the common ground of the power supply outputs.
                      Since you are getting the 12V, the 24v must be working since they are generated by the same power transformer.
                      • Twins_Guy
                        • Feb 2014
                        • 28
                        so I moved it to the 200 on the DCV and I get 24.8 and I have to use the 1000 and I get 535 on the big black cap.
                          "I get 535 on the big black cap" That cannot be right, are you measuring right at the two legs of the cap?
                          So you are getting 24VDC at all 3 connectors, if that is the case, the power supply is OK.
                          Need to look at voltages and signals at the inverter boards next if the 24V feeding the inverter boards are OK.
                          • Twins_Guy
                            • Feb 2014
                            • 28
                            I took the reading right were they are soldered on the board, yes I am getting 24.8 at all 3
                            so how do I check the inverter boards?
                              Remove the black covers so you can closely inspect the board for any blown fuses or components. Take good closed up pictures of the boards and around the connectors so we can see if it has any labels for the pins of the connectors.
                              If you can see the P/N on the boards, report that also.
                              • Twins_Guy
                                • Feb 2014
                                • 28
                                Well now I did it.. while checking the voltages the board moved and shorted out on the frame. big spark and now nothing, so I think I will just need to get a new board if I wanna get this one going,ugh..good thing I got it for free. I can see were the short was but nothing looks blown. Dang it.
                                  You may have blown the main AC fuse.
                                  • Twins_Guy
                                    • Feb 2014
                                    • 28
                                    I tested it and there is continuity through it.
                                    • Twins_Guy
                                      • Feb 2014
                                      • 28
                                      So I did not know there was a fuse were the cord plugs in to the tv, I thought it was just the one on the board anyway, I was messing around this morning and found it...duh, anyway I got power back now, still getting the 6 blinking blue light, how come I cant seem to find what that code means..lol I cant be the only one that this has happened to.
                                      • Caleb
                                        Smokin IC's
                                        • Feb 2013
                                        • 645
                                        If you've got access to a ring tester you can ring all the inverter transformers, they are a very common failure on these sets. You can try to test them using an ohm meter as well, test them all and look for the odd one out. I built this one for less than 10$ it has been a great meter for finding faults in inverter transformers.
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                        • esqmooo
                                          HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                                          by esqmooo
                                          I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                                          03-07-2025, 05:55 AM
                                        • Tomylee
                                          Nintendo 2DS XL – Orange light, no blue light, signs of overheating
                                          by Tomylee
                                          Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
                                          Here's what I've observed:
                                          All ribbon cables are properly connected
                                          Battery is present and in good condition
                                          No reaction even with screens disconnected
                                          There's a visible burn mark / overheating sign on the metal shield, right above the CPU
                                          I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
                                          06-26-2025, 02:33 PM
                                        • CraigR
                                          Hp x360 15-u499nr power light flashes continuously.
                                          by CraigR
                                          I have an Hp x360 15-u499nr laptop with a continuous white blinking power light. The laptop does turn on. The light flashes with just the battery and if I disconnect the battery and just use the power cord it still flashes and with both connected it still does. I have updated the bios and tried a hard reset with battery unplugged and power cord unplugged and holding down the power button for 60 seconds. I can't think of what else to try.
                                          09-16-2024, 06:12 PM
                                        • Egidio85
                                          Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                          by Egidio85
                                          Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                          the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                          the fan does not start.
                                          I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                          any advice on what to check?
                                          06-10-2025, 05:00 AM
