Hisense 55H6570F boots, loads then shuts down -
  • nickgronk
    • Apr 2021
    • 32
    I have a Hisense 55H6570F that gets the the boot loading screen for android and then shuts down. Oddly I hear a crackle on the mainboard as shown in the picture - nothing looks blown. The tv will boot every time, but when it reaches the loading statge of the anroid logo you can hear crackling on the board and it shuts down. What am I looking for (other than buying a new set) ? Inside the square is where I hear the crackling
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4330
    • Italy - Milan
    This is a varistor, lift and bend it , you'll see a burn hole, desolder it, retest the tv, if it boots properly replace with same params the component
    • lotas
      • Jan 2016
      • 4602
      • Russia
      This is not a varistor, but a thermistor for soft starting. Without it, the power supply won't even turn on.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4330
        • Italy - Milan
        yes watching better the prints on the body it has no varistor data, and also pcb says Resistor thermal , anyhow must be turned and watched
        • Diah
          • Feb 2013
          • 6374
          reboot at android system never being what you are thinking... eMMC or LED BL.. start with BL. cut the cable of LED - and put in filament normal lamp . check if the set remain on.
          • jssamp
            • Jan 2022
            • 22
            • U.S.
            Did you ever get your TV fixed? It's been a few years so you might not even be hanging around anymore.
            • nickgronk
              • Apr 2021
              • 32
              Did not fix. The issue with these sets is the memory chip, as explained, has a lifespan. The only way to repair is to program and install a new mem chip. I found this video which explained the process. He repairs the boards for 200$ +, I sent this tv straight to recycling.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4330
                • Italy - Milan
                Do not trust blindly videos and opinions, the crackle can say something, if no relays are present it must not produce any suspicious sound, in your photo, remove one leg of the yellow varistor, then re test..
                • nickgronk
                  • Apr 2021
                  • 32
                  It was a two fold problem. That crackle but also the error message of "storage space running out" and the reboot.
                  • jssamp
                    • Jan 2022
                    • 22
                    • U.S.
                    I have a Hisense H6570G. It had similar symptoms. It would turn on and get to the Android load screen, and sometimes it would get all the way to the start page, but then it would shut off. If I left it off longer before trying again it would stay on a bit longer before shutting down. The behavior led me to suspect an over heating issue, likely a bad capacitor. I opened it up to diagnose the problem and on visual inspection I noticed two capacitors with bulged tops. The location is circled in red below. The other image includes the caps I removed. They are Jianghai JH CD266 series with values 10 μF, 350 V. Itested them with my LCR meter and got in the neighborhood of 6 pF on one. The other was in the nF range. I didn't have replacements in stock so I ordered them. After I get them replaced I will post the results in case any body else has the same problem.
ID:	3550386 Click image for larger version
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4330
                      • Italy - Milan
                      You could have given it a chance by fixing the PB stage and then let the tv work, i heard in another place of an Android tv that self restored its bad structure after leaving it on for several hours..
                      • jssamp
                        • Jan 2022
                        • 22
                        • U.S.
                        It's now a couple of weeks since I replaced those two caps on my HiSense H6570G and it has been working well. Except many of the shows on it are really dumb. I don't know how to fix a TV so that it doesn't play stupid shows. 😉
                        • EazyBone
                          Hisense 75h8f shutting off
                          by EazyBone
                          This TV turns on you see the Android logo it loads goes to home screen will stay on the home screen for about 30 seconds to a minute roughly and then clicks the relay on the PSU and shuts off.
                          It's a q LED and I've tested the LEDs to the best of my ability using the ribbons and an LED tester and they are all 22 volts on all three channels of the ribbon. I do know LEDs failing and cause this issue. I don't think it's this but maybe.
                          Have disconnected 3/4 on both sides of the ribbon and one half on each side of the ribbon and the entire panel itself. And it does the same...
                          02-02-2025, 10:30 PM
                        • Coolgoodman
                          Faulty Hisense 85Q6NAU TV
                          by Coolgoodman
                          85” Hisense TV
                          Greetings,
                          Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                          Dear TV technicians of forum, I hope this message finds you well.
                          I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                          I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                          07-24-2025, 03:02 AM
                        • Jenzo
                          Apple A1706 - Boots and shuts off
                          by Jenzo
                          Hey everyone,
                          Working on a macbook A1706, board number 820-00239-A.
                          When trying to turn it on you hear the chime, but get no image whatsoever, and after about 10-15 sec it'll turn off (monitoring usb amp meter, it goes back to 15v 0a. I'm using a 45W charger btw, can't find my 85W atm).
                          As far as I can tell all 3V3 an 5V lines come up, up until S0, and then go back to 0V. G3H stays stable at 13V.
                          Put it under the thermal cam, only L7030 gets a little hot (35c), but nothing out of the ordinary.
                          Where do I go from this? I'm...
                          10-11-2022, 11:16 AM
                        • ShahZaib Ghumman
                          Can I Swap Screens Between Two Hisense 75” QLED TVs?
                          by ShahZaib Ghumman
                          Hey folks,
                          I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                          A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                          So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                          03-25-2025, 10:59 PM
                        • huzo
                          HP Omen shuts down when loading OS
                          by huzo
                          The model is 15ec-1061nm
                          Board number is DAG3EDMB8D0​
                          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                          10-29-2024, 12:05 AM
