Sharp TV LC-40LE600E
  • nomoresonys
    • 12331
    • U.S.
    #41
    Originally posted by lotas
    You get 165v when the network is 120v, and when the network is 220v (France), then 165v will not be there, but 310v-320v
    Ah, yep, my bad. 220 Europe, 120 North America, forgot what country I was dealing with for a minute there.
    • Kerden
      • Aug 2024
      • 19
      • France
      #42
      I don't find the eeprom 24C64
      Where is it please?
      • Kerden
        • Aug 2024
        • 19
        • France
        #43
        EEPROM : (IC8455)
        • lotas
          • Jan 2016
          • 4899
          • Russia
          #44
          Where is it please?
          It is located on the back of the board.
          • Kerden
            • Aug 2024
            • 19
            • France
            #45
            Found, thanks
            If I want to test or re-write the eeprom, what tools do I need ?
            Any model to rate?
            I need the TV program too
            • lotas
              • Jan 2016
              • 4899
              • Russia
              #46
              Found, thanks
              Any model to rate?
              You need the cheapest, simple CH341A + programmer (adapter for 24C64 sop-8), find it and read the contents of the eeprom and save it as dump and I will send you a working dump eeprom, which you will need to write down...
              • Kerden
                • Aug 2024
                • 19
                • France
                #47
                Will I need to unsold​ the eeprom? or can it be done in-circuit?
                • lotas
                  • Jan 2016
                  • 4899
                  • Russia
                  #48
                  I personally don’t use a clothespin (there may be errors when reading, writing, loss of contact...) I always unsolder it from the board, program on the adapter and solder it back, well, you can try using a clothespin, read the dump eeprom several times and compare their checksums , if they are all the same, then try and write my dump into it...
                  • sefoster
                    Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                    by sefoster
                    I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                    11-20-2022, 09:29 AM
                  • dmcabs
                    SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
                    by dmcabs
                    Hey guys,
                    I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
                    This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
                    FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
                    I'm a bit rusty but still have ability to dig right down.
                    I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
                    09-21-2024, 11:09 AM
                  • JunkmanJimbo
                    sharp lc-65ub30u plays but screen is flashing on and off
                    by JunkmanJimbo
                    Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
                    09-07-2024, 09:45 AM
                  • STKR123
                    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                    by STKR123
                    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                    I wonder if re-flashing the BIOS might be of any use here.
                    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                    11-03-2024, 06:58 AM
                  • DrvLikHell
                    Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                    by DrvLikHell
                    Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                    The...
                    02-05-2025, 01:44 AM
