Sharp TV LC-40LE600E
  • Kerden
    • Aug 2024
    • 19
    • France
    Hi everyone?!
    My Sharp TV LE-40LE600E have a black screen. It doesn't work anymore
    No sound
    The LED stay red and fixed (no flashing)
    What could I test please?
  • Kerden
    • Aug 2024
    • 19
    • France
    LED Added
    • nomoresonys
      • 12328
      • U.S.
      What happened, one day you turned it on and just a black screen, no problems before that?
      • nomoresonys
        • 12328
        • U.S.
        Tv is circa 2009, try this easy test, heat all the electrolytic capacitors on the powerboard with a hairdryer for a couple minutes, then try the tv, don't wait til it cools down, try it while it's still hot, see if there's any change.
        • nomoresonys
          • 12328
          • U.S.
          Do NOT touch anything with your hands while powerboard is plugged in there are some potentially DEADLY voltages on the hot side of the board and some boards can hold a big charge even after being unplugged for quite a while.
          • nomoresonys
            • 12328
            • U.S.
            report results and we'll go from there or someone else can carry on with helping.
            • lotas
              • Jan 2016
              • 4840
              • Russia
              Try to reprogram the eeprom 24C64, most likely the TV is blocked due to exceeding the number of errors.
              • nomoresonys
                • 12328
                • U.S.
                It could be the eeprom but this is jumping the gun, there's much easier things to try before just assuming it's the eeprom. It's odd how you just presume everyone has the tools to reprogram chips.
                • nomoresonys
                  • 12328
                  • U.S.
                  Try holding volume down and input WHILE plugging in tv, KEEP holding them til a display pops up, after a minute turn off tv, turn it back on and see if it works.
                  • nomoresonys
                    • 12328
                    • U.S.
                    I may have also presumed, did you try a simple reset, unplug tv for a minute and plug it back in and try it, no joy try as #9 post.
                    • nomoresonys
                      • 12328
                      • U.S.
                      Another test that works at times, heat the eeprom with a hairdryer for a minute, then try tv, see if there's any change. This isn't directed at you but here's a reminder. Do follow test procedures how they are written, when directed to use hairdryer by all means use hairdryer NOT heatgun, heatgun can overheat and kill eeprom.
                      • Kerden
                        • Aug 2024
                        • 19
                        • France
                        Yes , exactly this situation.
                        One day , when I turned it on, just a black screen
                        No, no problem before that
                        • Kerden
                          • Aug 2024
                          • 19
                          • France
                          No change, black screen
                          • Kerden
                            • Aug 2024
                            • 19
                            • France
                            Thank you, I have no tool to do this, but I will keep this in mind
                            • Kerden
                              • Aug 2024
                              • 19
                              • France
                              Yes, I have tried this. It just worked once
                              • Kerden
                                • Aug 2024
                                • 19
                                • France
                                I have just tried and the black screen is always there
                                • nomoresonys
                                  • 12328
                                  • U.S.
                                  Staying with easy things first, check all the diodes and resistors on top of the board, google is your friend for how to videos if needed.
                                  • lotas
                                    • Jan 2016
                                    • 4840
                                    • Russia
                                    Why check something, heat something, press something, if the problem is in the eeprom firmware.
                                    • nomoresonys
                                      • 12328
                                      • U.S.
                                      Well lotus, can you prove that the eeprom is faulty? If not then that's why we check other things
                                      Note: admin edit rude section out. Keep it polite
                                      • lotas
                                        • Jan 2016
                                        • 4840
                                        • Russia
                                        I'll see how you can use your narrow-minded direction to find the cause of the malfunction...
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • dmcabs
                                          SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
                                          by dmcabs
                                          Hey guys,
                                          I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
                                          This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
                                          FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
                                          I'm a bit rusty but still have ability to dig right down.
                                          I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
                                          09-21-2024, 11:09 AM
                                        • JunkmanJimbo
                                          sharp lc-65ub30u plays but screen is flashing on and off
                                          by JunkmanJimbo
                                          Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
                                          09-07-2024, 09:45 AM
                                        • STKR123
                                          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                          by STKR123
                                          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                          I wonder if re-flashing the BIOS might be of any use here.
                                          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                          11-03-2024, 06:58 AM
                                        • DrvLikHell
                                          Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                                          by DrvLikHell
                                          Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                                          The...
                                          02-05-2025, 01:44 AM
